Home » Eclipse Projects » Rich Client Platform (RCP) » Reading Command Line Parameters in RCP App
Reading Command Line Parameters in RCP App [message #637240] Thu, 04 November 2010 12:58 Go to next message
I tried searching the forum, but most of the command line topics were on starting eclipse.
I have an RCP app that works well. One of my views needs to access the command line parameters given to the RCP application when it is started.
In this particular case, I need to turn some logging on or off based on a command line parameter.
How can a view in my RCP app access the command line parameters that are provided when the app is launched?
Herb Miller
Re: Reading Command Line Parameters in RCP App [message #637266 is a reply to message #637240] Thu, 04 November 2010 14:37 Go to previous messageGo to next message
inside your RCP app, you should simply get your commandine and
applications args with:
Platform.getApplicationArgs()
and
Platform.getCommandLineArgs()
Greetings
Heiko
Am 04.11.2010 17:58, schrieb Herb Miller:
> starting eclipse.
> Herb Miller
Re: Reading Command Line Parameters in RCP App [message #637402 is a reply to message #637240] Fri, 05 November 2010 07:50 Go to previous messageGo to next message
In addition, they're available in your application start(*) method:
args = (String[]) applicationContext.getArguments().get(
IApplicationContext.APPLICATION_ARGS);
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Reading Command Line Parameters in RCP App [message #637463 is a reply to message #637402] Fri, 05 November 2010 12:00 Go to previous message
Thanks for both answers. I will give them a try.
Herb
Previous Topic:Anyone know how to get icons for common file types?
Next Topic:export of RCP app stops before completion
Current Time: Wed Jul 23 18:30:35 EDT 2025
Powered by FUDForum. Page generated in 0.04259 seconds
