Home » Archived » BIRT » Cascading report parameters
Cascading report parameters [message #637197] Thu, 04 November 2010 10:48 Go to next message
I have the following situation:
In one dataset called Projects and I have two attributes in it: leader, project
In second dataset called People and I have two attributes in it: projects, people
When I build cascading parameter group based on single dataset (Projects), and create two parameters in it (leader,project1), I get all projects for specific leader.
then, I want to build another cascading parameter group based on single dataset (People), and create two parameters in it (project2, people).
Is there possible that somehow I use project1 parameter value as default value for dataset People (project2 parameter should use this value), and in that way I can get peoples in that projects?
Example:
In first cascading group, If I choose Leader1, I get Project1, Project2,Project3...
Then, If I choose Project2 from second parameter in this group, I get Man1, Man2, Man3 in second cascading group assuming that Man1, Man2, Man3 belong to Project2.
If my question is not understandable, let me know.
Regards, and thanks,
Re: Cascading report parameters [message #637261 is a reply to message #637197] Thu, 04 November 2010 14:00 Go to previous messageGo to next message
could you not just create a joint dataset with both datasets and put all
the parameters in the same cascade or use a multi-dataset cascade?
Jason
On 11/4/2010 10:48 AM, mkrivic wrote:
> project
> projects, people
> Example:
Re: Cascading report parameters [message #637292 is a reply to message #637261] Thu, 04 November 2010 17:55 Go to previous message
Jason,
thanks for reply. I came on same idea after posting this topic, but I wasn't able to post that I succeeded with joined datasets till now.
Thanks again, regards,
Previous Topic:Font size handling in IE different
Next Topic:Pie, Line and Bar Charts
Current Time: Sun Jul 27 11:51:25 EDT 2025
Powered by FUDForum. Page generated in 0.05684 seconds
