Home » Eclipse Projects » Rich Client Platform (RCP) » How to restore edit location of recently closed editor?
How to restore edit location of recently closed editor? [message #636972] Wed, 03 November 2010 11:44 Go to next message
I have an editor input which is of type IURIEditorInput which I use to open different types of packaged editors (java,python,xml,text,etc) or system editor. I need the ability to save and restore the edit position of the files opened in these editors and am having a bit of trouble figuring out how to. I am thinking that IMarker is the way to go by getting a marker before they are closed, store it in my editor input, then after they are opened, use IDE.gotoMarker(part,marker) to restore my state. The problem I'm having is creating the marker before they editors are actually closed. Any ideas how to do this? I want to restore the editor as if it was never actually closed.
Max
Re: How to restore edit location of recently closed editor? [message #636981 is a reply to message #636972] Wed, 03 November 2010 12:21 Go to previous messageGo to next message
I'm not entirely sure I should be using IMarker in this case as the file's I'm opening to edit are not contained in the "Workspace" and it seems IMarker can only be used for workspace resources. Can anyone verify that is the case? Does anyone know of any other way to get and restore edit position on a generic text editor?
Max
Re: How to restore edit location of recently closed editor? [message #637003 is a reply to message #636972] Wed, 03 November 2010 13:50 Go to previous messageGo to next message
Are these editors that you have written? Or are you trying to apply
this more generally to eclipse editors in your application?
If you write the editor, then you can save state information in the
dispose() method. You don't have to use markers, you can save
information in
org.eclipse.ui.plugin.AbstractUIPlugin.getDialogSettings() for your
plugin (if you are a UI plugin) or just save it (in any format you like)
in org.eclipse.core.runtime.Plugin.getStateLocation()
If you are talking about other editors, it is harder because
org.eclipse.ui.IPartListener2.partClosed(IWorkbenchPartRefer ence) is a
post-close event. Some of these (like the text based editors) will try
and save their cursor location if the editors are open on shutdown (so
they are re-opened when the app is restarted), but they won't do it on
simple open/close.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to restore edit location of recently closed editor? [message #637007 is a reply to message #637003] Wed, 03 November 2010 14:11 Go to previous messageGo to next message
Thanks for the reply!
These are eclipse editors I'm trying to retain the state of. The problem isn't when to do it, I have that all set up, since this is for a special case that I control. The problem is how to get at the data I need to save (it will all be stored in memory, no need to preserve after shutdown).
Here is my code for when I'm going to save the state:
        for (IEditorReference ref : page.getEditorReferences()) {
            IEditorPart part = ref.getEditor(false);
            IEditorInput input = part.getEditorInput();
            if (input instanceof LocalizationEditorInput) { // my custom editor input
                LocalizationEditorInput lInput = (LocalizationEditorInput) input;
                // TODO: Figure out how to store edit position
This is what I have access to and this is where I need to get something from the editor that I can use to restore the position
Max
Re: How to restore edit location of recently closed editor? [message #637016 is a reply to message #637007] Wed, 03 November 2010 14:48 Go to previous messageGo to next message
For Parts that are org.eclipse.ui.texteditor.ITextEditor you can get
that information, at least some of it. I noticed that interface has
methods that can highlight and move the cursor.
PW
Paul Webster
Re: How to restore edit location of recently closed editor? [message #637021 is a reply to message #637016] Wed, 03 November 2010 15:29 Go to previous messageGo to next message
Hmm, I gave it a shot and it is always returning null...
Looking into the code, it goes into AbstractTextEditor.getHighlightRange() which ends up calling SourceViewer.getRangeIndication() which attempts to get the Position from the AnnotationModel passing in fRangeIndicator and that always returns null. Is there anything I have to do to get this to work that you know of? I'm not familiar with AnnotationModels or Attachments
Max
Re: How to restore edit location of recently closed editor? [message #637023 is a reply to message #637016] Wed, 03 November 2010 15:29 Go to previous messageGo to next message
You can restore the cursor position for text editor instances with the help of a part listener. Here is the code which might help you
	private Map<Object, Point> restoreLocations = new HashMap<Object, Point>();
	public void partClosed(IWorkbenchPart part) {
        if (part instanceof ITextEditor && part instanceof  IEditorPart) {
            IEditorInput editorInput = ((IEditorPart)part).getEditorInput();
            if (editorInput instanceof IURIEditorInput) {
            	ITextSelection selection = (ITextSelection) ((ITextEditor)part).getSelectionProvider().getSelection();
            	restoreLocations.put(((IURIEditorInput) editorInput).getURI(), new Point(selection.getOffset(), selection.getLength()));
	public void partOpened(IWorkbenchPart part) {
            	ITextEditor textEditor = (ITextEditor)part;
            	Point point = restoreLocations.get(((IURIEditorInput) editorInput).getURI());
            	if (point != null) {
            		textEditor.selectAndReveal(point.x, point.y);
Re: How to restore edit location of recently closed editor? [message #637025 is a reply to message #637023] Wed, 03 November 2010 15:44 Go to previous message
Worked like a charm, thanks for all the replies everyone!
Max
Previous Topic:Eclipse editor latin2 characters
Next Topic:Building RCP application
Current Time: Sun Jul 27 13:48:20 EDT 2025
Powered by FUDForum. Page generated in 0.04708 seconds
