Home » Archived » BIRT » Cascading parameter default value problem(BirtDateTime.year(BirtDateTime.now()) type mismatch)
Cascading parameter default value problem [message #636844] Wed, 03 November 2010 01:24 Go to next message
I am trying to create a cascading parameter group and set e default value for a parameter type integer from BirtDateTime.year(BirtDateTime.now()).
This function returns integer, but I am getting a data type mismatch.
Unfortunately I cannot attach a screen shot at this time.
Re: Cascading parameter default value problem [message #636997 is a reply to message #636844] Wed, 03 November 2010 12:58 Go to previous messageGo to next message
Can you post the report and version you are using? Your syntax works on
my report. You could also try:
parseInt(BirtDateTime.year(BirtDateTime.now()));
Jason
Re: Cascading parameter default value problem [message #636998 is a reply to message #636844] Wed, 03 November 2010 13:04 Go to previous messageGo to next message
How can I post the report if I cannot attach files to my message?
Re: Cascading parameter default value problem [message #637011 is a reply to message #636998] Wed, 03 November 2010 14:23 Go to previous messageGo to next message
Try selecting the xml view and cut and paste the xml into the message or
just email it to me at jasonweathersby at windstream dot net.
Jason
Re: Cascading parameter default value problem [message #637211 is a reply to message #636844] Thu, 04 November 2010 11:38 Go to previous messageGo to next message
Here is the project code.
Try to change the default value of the parameter Year to
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22" id="1">
    <property name="createdBy">Eclipse BIRT Designer Version 2.6.1.v20100902 Build &lt;2.6.1.v20100915-1750></property>
    <property name="units">in</property>
    <property name="iconFile">/templates/blank_report.gif</property>
    <property name="bidiLayoutOrientation">ltr</property>
    <property name="imageDPI">96</property>
    <parameters>
        <cascading-parameter-group name="Start" id="618">
            <property name="dataSet">year</property>
            <property name="dataSetMode">single</property>
            <parameters>
                <scalar-parameter name="Year" id="619">
                    <property name="valueType">dynamic</property>
                    <property name="isRequired">true</property>
                    <property name="dataSetName">year</property>
                    <expression name="valueExpr">row["year"]</expression>
                    <property name="dataType">integer</property>
                    <property name="controlType">list-box</property>
                    <property name="fixedOrder">true</property>
                    <structure name="format"/>
                </scalar-parameter>
            </parameters>
        </cascading-parameter-group>
    </parameters>
    <data-sources>
        <script-data-source name="Script" id="562">
            <method name="beforeOpen"><![CDATA[1;]]></method>
            <method name="beforeClose"><![CDATA[1;]]></method>
            <method name="afterOpen"><![CDATA[1;]]></method>
            <method name="afterClose"><![CDATA[1;
]]></method>
            <method name="close"><![CDATA[1;]]></method>
        </script-data-source>
    </data-sources>
    <data-sets>
        <script-data-set name="year" id="613">
            <list-property name="resultSetHints">
                <structure>
                    <property name="position">0</property>
                    <property name="name">year</property>
                </structure>
            </list-property>
            <list-property name="columnHints">
                <structure>
                    <property name="columnName">year</property>
                </structure>
            </list-property>
            <structure name="cachedMetaData">
                <list-property name="resultSet">
                    <structure>
                        <property name="position">1</property>
                    </structure>
                </list-property>
            </structure>
            <property name="dataSource">Script</property>
            <method name="open"><![CDATA[flag=0;]]></method>
            <method name="fetch"><![CDATA[if (!flag) {
	row["year"] = 2001;
	flag = 1;
	return truel
}]]></method>
        </script-data-set>
    </data-sets>
    <styles>
        <style name="report" id="4">
            <property name="fontFamily">sans-serif</property>
            <property name="fontSize">10pt</property>
        </style>
        <style name="crosstab-cell" id="5">
            <property name="borderBottomColor">#CCCCCC</property>
            <property name="borderBottomStyle">solid</property>
            <property name="borderBottomWidth">1pt</property>
            <property name="borderLeftColor">#CCCCCC</property>
            <property name="borderLeftStyle">solid</property>
            <property name="borderLeftWidth">1pt</property>
            <property name="borderRightColor">#CCCCCC</property>
            <property name="borderRightStyle">solid</property>
            <property name="borderRightWidth">1pt</property>
            <property name="borderTopColor">#CCCCCC</property>
            <property name="borderTopStyle">solid</property>
            <property name="borderTopWidth">1pt</property>
        </style>
        <style name="crosstab" id="6">
        </style>
    </styles>
    <page-setup>
        <simple-master-page name="Simple MasterPage" id="2">
            <page-footer>
                <text id="3">
                    <property name="contentType">html</property>
                    <text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
                </text>
            </page-footer>
        </simple-master-page>
    </page-setup>
    <body>
        <text id="599"/>
        <text-data id="600">
            <expression name="valueExpr">"Start = " + params["Year"].value + " " + params["Month"].value</expression>
        </text-data>
    </body>
    <property name="pageVariables">
        <variable-element name="CurrentYear">
            <expression name="value" type="javascript">parseInt(BirtDateTime.year(BirtDateTime.now())).toFixed(0)</expression>
            <property name="type">report</property>
        </variable-element>
        <variable-element name="mList">
            <expression name="value" type="javascript">["Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"];</expression>
        </variable-element>
    </property>
</report>
Re: Cascading parameter default value problem [message #637241 is a reply to message #637211] Thu, 04 November 2010 13:02 Go to previous messageGo to next message
This appears to be a bug. Can you log it? As a work around use a
getDefaultValueList script on the parameter. And enter the following script:
importPackage( Packages.java.util );
cal = Calendar.getInstance();
tyear = cal.get(Calendar.YEAR);
tyear;
See attached modified example
Jason
id="1">
<parameters>
<parameters>
<expression name="labelExpr">row["year"]</expression>
<method
name="getDefaultValueList"><![CDATA[importPackage( Packages.java.util );
tyear;]]></method>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
</parameters>
<data-sources>
]]></method>
</data-sources>
<data-sets>
<structure>
</structure>
</list-property>
<structure>
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<method name="open"><![CDATA[flag=false;]]></method>
row["year"] = 2001;
flag = true;
return true
}else{
return false;
}]]></method>
</script-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<data id="620">
<structure name="numberFormat">
<property name="category">Custom</property>
<property name="pattern">#0</property>
</structure>
<list-property name="boundDataColumns">
<structure>
<property name="name">Year</property>
<expression name="expression"
type="javascript">params["Year"]</expression>
<property name="dataType">string</property>
</structure>
</list-property>
<property name="resultSetColumn">Year</property>
</data>
</body>
type="javascript">parseInt(BirtDateTime.year(BirtDateTime.now())).toFixed(0) </expression>
</variable-element>
</variable-element>
</property>
</report>
> id="1">
> Build <2.6.1.v20100915-1750></property>
> <parameters>
> <parameters>
> </scalar-parameter>
> </parameters>
> </parameters>
> <data-sources>
> ]]></method>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> row["year"] = 2001;
> flag = 1;
> return truel
> }]]></method>
> </script-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <text id="599"/>
> </text-data>
> </body>
> </variable-element>
> </variable-element>
> </property>
> </report>
Re: Cascading parameter default value problem [message #638052 is a reply to message #637211] Tue, 09 November 2010 13:42 Go to previous messageGo to next message
I've never logged a bug here. How do I do it?
Re: Cascading parameter default value problem [message #638063 is a reply to message #638052] Tue, 09 November 2010 14:45 Go to previous message
Yuri,
Take a look at the bugzilla entry on this page:
http://www.eclipse.org/birt/phoenix/community.php
Jason
Previous Topic:Retrieve Column Index
Next Topic:Paperclips: The import net cannot be resolved
Current Time: Thu Jul 24 23:19:32 EDT 2025
Powered by FUDForum. Page generated in 0.10149 seconds
