Home » Modeling » EMF » Creating Children You Didn't Know Existed revisited
Creating Children You Didn't Know Existed revisited [message #636953] Wed, 03 November 2010 10:12 Go to next message
Dear all,
I just followed the instructions at
< http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html>
to generate editors that can be extended with concrete derived classes.
However, I came across one problem with the "Child Creation Extenders"
/ "Extensible Provider Factory" that will explain using the following
example:
Package test.base:
Base class: test.base.Base
Container class: test.base.ContainerInBase (0..* containment of Base)
Extensible Provider Factory: true
Package test.derived
Derived class test.derived.Derived (inherits from test.base.Base)
Child Creation Extenders: true
If I generate an editor for test.base, I can add both Base and Derived
objects to test.base.ContainerInBase (as expected).
Package test.container
Container class 2: test.container.Container (0..* containment of Base)
The editor for test.container allows me to add Base objects only;
Derived objects cannot be added no matter if I turn on "Child Creation
Extenders" or "Extensible Provider Factory" in the corresponding GenModels.
My questions are: Is this behavior expected?
If yes, how can I work around this problem? Modifying
test.container.provider.ContainerItemProvider.collectNewChil dDescriptors
as follows
protected void collectNewChildDescriptors(Collection<Object>
newChildDescriptors, Object object) {
super.collectNewChildDescriptors(newChildDescriptors, object);
newChildDescriptors.add
(createChildParameter
(ContainerPackage.Literals.CONTAINER__REF,
BaseFactory.eINSTANCE.createBase()));
DerivedFactory.eINSTANCE.createDerived()));
works for classes Base and Derived, but will not work for unknown
subclasses of Base (say Derived2).
For your reference, I exported the above test case and uploaded it here
<http://www6.in.tum.de/~barner/children_test.zip>
I debugged a bit into the code, but I do not have the necessary in-depth
knowledge about how the generated edit and editor code is supposed to
work together.
Thanks in advance,
Simon
Re: Creating Children You Didn't Know Existed revisited [message #636962 is a reply to message #636953] Wed, 03 November 2010 10:35 Go to previous messageGo to next message
Simon,
Comments below.
Simon Barner wrote:
> Dear all,
> example:
> Package test.base:
So this model doesn't know about test.derived and test.derived doesn't
know about this model, so it won't know to contribute anything to this
model.
> GenModels.
Yes.
> as follows
You'd need to manually (directly in the *.genmodel) add test.container's
GenPackage as a usedGenPackage for test.derived's GenModel.
> in-depth knowledge about how the generated edit and editor code is
> supposed to work together.
> Thanks in advance,
> Regards,
> Simon
Re: Creating Children You Didn't Know Existed revisited [message #637000 is a reply to message #636962] Wed, 03 November 2010 13:25 Go to previous messageGo to next message
Ed,
thanks for the swift reply.
> model.
Yes, that's what I figured.
Great, that worked perfectly. I did the following:
I opened derived.genmodel in the text editor (is there a more elegant
way of doing this?) and adapted the usedGenPackages attribute as follows:
usedGenPackages="base.genmodel#//base container.genmodel#//container"
I also had to enable "Extensible Provider Factory" for the Container
package in container.genmodel.
For me, this solution is quite acceptable, since the set of container
classes is known in advance, and thus this approach scales well when
more derived classes are added.
Thanks again,
Simon
Tree structures and cycles in genmodel (was: Re: Creating Children You Didn't Know Existed revisited [message #637996 is a reply to message #636962] Tue, 09 November 2010 10:08 Go to previous messageGo to next message
Dear Ed, dear EMF-tools group,
Here a follow-up problem that resulted from further experiments with my
meta-model:
Suppose, I have the following classes:
Package test.base:
Base class: Base
children (containment 0..* of Base)
Derived class Derived (inherits from Base)
Package test.subderived
Derived class Subderived (inherits from Derived)
See <http://www6.in.tum.de/~barner/children_cycle.zip>
Now, the generated editor code (root element: Base) for test.base
behaves as follows:
Type: Base
Child types offered by editor: Base, Derived, Subderived
Type: Derived
Type: Subderived
This is of course expected since Derived does not know about Subderived.
However, manually extending 'usedGenPackage' for Derived will not work
since this would lead to a cycle (effect: code generation for
derived.genmodel fails, i.e. no code is generated at all). It seems,
that cycle is not detected because I see a stack overflow exception when
I generate code using emf.Ecore2Java ant task.
Do you have suggestion how to overcome this problem. My current thoughts
are:
1) Make the lookup of child creating extenders walk up the class
hierarchy to the root class (in our case: from Derived to Base)
2) Now, process the entire tree created by the Extensible Provider
Factory/Child Creation Extender mechanism and collect all possible
children (e.g. for Base, Derived and Subderived).
This approach would have the additional benefit that no manual
modification of the .genmodel is needed.
I would appreciate your comments on this suggestion and possibly
implementation hints. Alternative (simpler ;-) ) ideas are certainly
welcome as well.
Thanks in advance,
Simon
Re: Tree structures and cycles in genmodel [message #638267 is a reply to message #637996] Wed, 10 November 2010 09:41 Go to previous message
Simon,
I'm totally swamped after two weeks in Europe. It's best you open a
bugzilla with your test case so I can analyze it in detail. I can't
promise to get to it quickly. Building the packages from a single
GenModel will of course solve the problem for the time being...
> my meta-model:
> Package test.base:
> Base class: Base
> behaves as follows:
> Type: Base
> Type: Derived
> Type: Subderived
> Subderived. However, manually extending 'usedGenPackage' for Derived
> will not work since this would lead to a cycle (effect: code
> generation for derived.genmodel fails, i.e. no code is generated at
> all). It seems, that cycle is not detected because I see a stack
> overflow exception when I generate code using emf.Ecore2Java ant task.
> thoughts are:
> welcome as well.
> Thanks in advance,
> Simon
Previous Topic:Serialization problem concerning Maps
Next Topic:Access EMF generated classes from JEE remote client
Current Time: Wed Jul 23 07:29:23 EDT 2025
Powered by FUDForum. Page generated in 0.10184 seconds
