Home » Archived » BIRT » How to do Pagination in BIRT(Hi How to do Pagination in BIRT)
How to do Pagination in BIRT [message #636454] Mon, 01 November 2010 08:50 Go to next message
Hi..
Am new to BIRT...
Re: How to do Pagination in BIRT [message #636495 is a reply to message #636454] Mon, 01 November 2010 11:16 Go to previous messageGo to next message
You can set page breaks on many of the elements in BIRT. Look at the
Page Break tab in the general properties of elements like tables and
lists. By default the engine will page break automatically based on the
size of the master page. You can also set page break interval which is
used in tables and list to page break after a certain number of rows.
Jason
On 11/1/2010 8:50 AM, R.Murali wrote:
> Hi..
> Am new to BIRT... How to do Pagination in BIRT
Re: How to do Pagination in BIRT [message #636924 is a reply to message #636495] Wed, 03 November 2010 07:43 Go to previous messageGo to next message
Thank u very much..
Am using a table with 320 rows of data...
Using Page Break Properties i made 20 rows to be displayed in single page.
So that while viewing in Report Viewer i can able to view totally 17 pages onebyone...
Now i want to add an aggregate function (SUM) which should add values of the coulmn(column Name:marks) for everypage and have to print at the end of everypages and also I have to print the grand total of all the 17 pages(marks field) and print in last page.....Pls help me regarding this...
Re: How to do Pagination in BIRT [message #636925 is a reply to message #636495] Wed, 03 November 2010 07:49 Go to previous messageGo to next message
Sir
Until now i know how to design a simple report....
Pls suggest me how to program the report ...ie how to access or create report by java programming....any materials regarding this..
Thank u sir
Re: How to do Pagination in BIRT [message #636926 is a reply to message #636495] Wed, 03 November 2010 07:50 Go to previous messageGo to next message
Sir,
suggest me the basic materials for javascipting in BIRT
Re: How to do Pagination in BIRT [message #636991 is a reply to message #636924] Wed, 03 November 2010 12:42 Go to previous messageGo to next message
Do you have grouping on the report or do you just want a separate sum
per page?
Jason
On 11/3/2010 7:43 AM, R.Murali wrote:
> Thank u very much..
> pages onebyone...
Re: How to do Pagination in BIRT [message #636992 is a reply to message #636925] Wed, 03 November 2010 12:48 Go to previous messageGo to next message
To create reports with Java you need to use the DE API. To run reports
with Java use the RE API There are webinars on these here:
REAPI
http://www.birt-exchange.com/be/info/reportengineapi-websem/
DEAPI
http://www.birt-exchange.com/be/info/designengineapi-websem/
You will need to register on Birt-Exchange, but there are a lot of
examples in the devshare so its good to do anyways and its free.
examples here:
http://www.birt-exchange.org/org/devshare/designing-birt-rep orts/409-deapi-examples-from-birt-exchange-webinar/
Jason
On 11/3/2010 7:49 AM, R.Murali wrote:
> Sir
> report by java programming....any materials regarding this.. Thank u sir
Re: How to do Pagination in BIRT [message #636993 is a reply to message #636926] Wed, 03 November 2010 12:49 Go to previous messageGo to next message
Take a look at this:
http://www.eclipse.org/birt/phoenix/deploy/reportScripting.p hp
Jason
On 11/3/2010 7:50 AM, R.Murali wrote:
> Sir,
Re: How to do Pagination in BIRT [message #637910 is a reply to message #636993] Tue, 09 November 2010 05:24 Go to previous messageGo to next message
Thank you very much sir
Re: How to do Pagination in BIRT [message #637922 is a reply to message #636991] Tue, 09 November 2010 06:17 Go to previous messageGo to next message
i need separate sum per page
Re: How to do Pagination in BIRT [message #637989 is a reply to message #637922] Tue, 09 November 2010 09:56 Go to previous messageGo to next message
Take a look at this example that uses a page variable and page scripts
to do this.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.0.v20100531 Build &lt;2.6.0.v20100609-1613></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<method name="onPageEnd"><![CDATA[var qtys =
this.getInstancesByElementName("qtyelement");
var tmp=0;
if( qtys != null ){
for( var i=0; i< qtys.length; i++ ){
//Instance of DataItemInstance
var qty = qtys[i];
tmp+=parseInt(qty.getValue());
reportContext.setPageVariable("pageqty",tmp);]]></method>
<page-header>
<auto-text id="44">
<property name="backgroundColor">#FF8080</property>
<property name="type">page-variable</property>
<property name="pageVariable">pageqty</property>
</auto-text>
</page-header>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression name="expression"
type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<property name="pageBreakInterval">4</property>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="13">
<label id="14">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="15">
<label id="16">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="21">
<cell id="22">
<data id="23">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="24">
<data id="25">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="26">
<data name="qtyelement" id="27">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="28">
<data id="29">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="30">
<data id="31">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="32">
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
</body>
<property name="pageVariables">
<variable-element name="pageqty">
<property name="type">page</property>
</variable-element>
</property>
</report>
Re: How to do Pagination in BIRT [message #638140 is a reply to message #637989] Wed, 10 November 2010 02:50 Go to previous messageGo to next message
sir
actually for what purpose we are using xml in birt repoting....
whether i have to learn xml for Birt Reporting.....
How to use XML in birt....
Re: How to do Pagination in BIRT [message #638300 is a reply to message #638140] Wed, 10 November 2010 13:07 Go to previous messageGo to next message
That xml was just a birt report. You can copy it and create a new
report in birt select the xml view and paste the xml from the previous post.
Jason
On 11/10/2010 2:50 AM, R.Murali wrote:
> sir actually for what purpose we are using xml in birt repoting....
Re: How to do Pagination in BIRT [message #638416 is a reply to message #638300] Thu, 11 November 2010 04:20 Go to previous messageGo to next message
yes..Sir i got sum for everypage....
how to get sum of all the pages as grand sum in last page....
Re: How to do Pagination in BIRT [message #638527 is a reply to message #638416] Thu, 11 November 2010 10:03 Go to previous messageGo to next message
You could just add an aggreation report item to the table footer or use
a report variable in addition to the page variable. I have modified the
example to show both. The blue row rows the aggregation report item and
the orange shows the report variable. The value of the report variable
is set in an oncreate script of the aggregation report item.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
2.6.1.v20100902 Build &lt;2.6.1.v20100915-1750></property>
<data-sources>
<oda-data-source
id="7">
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
var tmp=0;
if( qtys != null ){
var qty = qtys[i];
<page-header>
<auto-text id="44">
</auto-text>
</page-header>
<page-footer>
<auto-text id="47">
<property name="backgroundColor">#FF8040</property>
<property
name="pageVariable">totalForAllPages</property>
</auto-text>
</page-footer>
</page-setup>
<body>
<table id="9">
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<property name="name">Aggregation</property>
<property name="aggregateFunction">SUM</property>
<list-property name="arguments">
<structure>
<property name="name">Expression</property>
<expression name="value"
type="javascript">row["QUANTITYORDERED"]</expression>
</structure>
</list-property>
</structure>
</list-property>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
</label>
</cell>
<cell id="13">
<label id="14">
<text-property
</label>
</cell>
<cell id="15">
<label id="16">
<text-property
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="21">
<cell id="22">
<data id="23">
<property
</data>
</cell>
<cell id="24">
<data id="25">
<property
</data>
</cell>
<cell id="26">
<property
</data>
</cell>
<cell id="28">
<data id="29">
<property
</data>
</cell>
<cell id="30">
<data id="31">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="32">
<property name="backgroundColor">#004080</property>
<cell id="33"/>
<cell id="34"/>
<cell id="35">
<data id="45">
<property name="color">#FFFFFF</property>
<method
name="onCreate"><![CDATA[reportContext.setPageVariable("totalForAllPages ",this.getValue());
]]></method>
<property
name="resultSetColumn">Aggregation</property>
</data>
</cell>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
</body>
</variable-element>
<variable-element name="totalForAllPages">
<property name="type">report</property>
</variable-element>
</property>
</report>
Re: How to do Pagination in BIRT [message #639170 is a reply to message #638527] Mon, 15 November 2010 08:36 Go to previous messageGo to next message
thank u sir...
What is the purpose of .rptdocument
how to create .rptdocument
Am using eclipse 3.6 birt 2.6.1
[Updated on: Mon, 15 November 2010 08:37] by Moderator
Re: How to do Pagination in BIRT [message #639388 is a reply to message #639170] Tue, 16 November 2010 06:24 Go to previous messageGo to next message
No Error..But a small pixel size box appears as my output when i click preview ...
What is the Problem and give me solution...
Re: How to do Pagination in BIRT [message #639389 is a reply to message #636454] Tue, 16 November 2010 06:43 Go to previous messageGo to next message
sir
how to Pass parameter in runtime.
Re: How to do Pagination in BIRT [message #639480 is a reply to message #639388] Tue, 16 November 2010 12:25 Go to previous messageGo to next message
Can you email me a screen shot to jasonweathersby at windstream dot net?
> preview ...
Re: How to do Pagination in BIRT [message #639481 is a reply to message #639389] Tue, 16 November 2010 12:26 Go to previous messageGo to next message
If you are using the viewer, a parameter box should display. If you are
using the RE API just call task.setParameterValue("parmname", value);
Jason
On 11/16/2010 6:44 AM, R.Murali wrote:
> sir
Re: How to do Pagination in BIRT [message #639589 is a reply to message #639480] Tue, 16 November 2010 23:30 Go to previous messageGo to next message
Sorry Sir...
i think some problem with my system....
yesterday i got the error ..
But today it is working fine.....
Thanks for ur response sir....
Re: How to do Pagination in BIRT [message #640442 is a reply to message #639589] Mon, 22 November 2010 02:10 Go to previous messageGo to next message
am having more than one check box and depending on the which check box selected ,corresponding report for the selected check box should be displayed.
How to do tis sir
Re: How to do Pagination in BIRT [message #640646 is a reply to message #640442] Mon, 22 November 2010 11:42 Go to previous messageGo to next message
One way to do this is to create a blank report with a list/combo
parameter with a list of report designs eg
detail.rptdesign
detail2.rptdesign
detail3.rptdesign
then add a text element to the canvas with a script similar to this:
<script type="text/javascript">
function forward() {
var temp = new String(location.href);
var detailReport = "<VALUE-OF>params["reportForward"].value</VALUE-OF>";
var TargetURL = temp.replace(/forwarddetail.rptdesign/, detailReport);
location.replace(TargetURL);
return false;
forward();
</script>
in the above example the forwarddetail.rptdesign is the name of the
blank report.
Jason
> displayed.
> How to do tis sir
Re: How to do Pagination in BIRT [message #640863 is a reply to message #640646] Tue, 23 November 2010 06:23 Go to previous messageGo to next message
Thanks for your response sir.
Without parameter i want to generate the report in which in should contain 3 check boxes and want to get different reports for different check box selected.How to do this sir..
[Updated on: Tue, 23 November 2010 06:24] by Moderator
Re: How to do Pagination in BIRT [message #640984 is a reply to message #640863] Tue, 23 November 2010 13:18 Go to previous messageGo to next message
You want one report that displays 3 check boxes and a submit button? and
when the submit button is pressed display the report with the check box
display? If this is the case you should be able to do this similar to
the previous example I posted using a text element and instead of
running the forward automatically put in a script on the button. Or you
could just add a jsp page to the viewer.
Jason
Re: How to do Pagination in BIRT [message #641056 is a reply to message #640984] Wed, 24 November 2010 02:20 Go to previous messageGo to next message
couldn't able to get your point...can you please provide me with code..
Re: How to do Pagination in BIRT [message #641249 is a reply to message #641056] Wed, 24 November 2010 11:02 Go to previous message
Take a look at this example:
Jason
id="1">
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<text id="7">
<text-property name="content"><![CDATA[<script
function forwardtst(rpt) {
//alert( temp );
var detailReport = rpt;
var TargetURL = temp.replace(/checkboxdriver.rptdesign/, detailReport);
//alert( TargetURL );
return false;
</script>
<table>
Detail.rptdesign: <INPUT TYPE="checkbox" NAME="Item1" VALUE="1"
UNCHECKED onClick="forwardtst('detail.rptdesign')">
<br>
Detail2.rptdesign: <INPUT TYPE="checkbox" NAME="Item2" VALUE="2"
UNCHECKED onClick="forwardtst('detail2.rptdesign')">
</table>
]]></text-property>
</text>
</body>
</report>
Previous Topic:Scripted Data Set Parameters dont work in Designer 2.6.1
Next Topic:SVG on OS X
Current Time: Sun Jul 27 13:46:48 EDT 2025
Powered by FUDForum. Page generated in 0.36111 seconds
