EDataType creation [message #636770] |
Tue, 02 November 2010 13:45  |
Hi Guys,
I have a strange problem. Probably, this was already solved in some previous thread (i checked through most of the forum discussion on this issue).
I do the following in my code.
EcoreFactory theCoreFactory = EcoreFactory.eINSTANCE;
theCoreFactory.setEPackage(EcorePackage.eINSTANCE);
EAttribute tempEAttribute = theCoreFactory.createEAttribute();
EDataType tempEDataType = theCoreFactory.createEDataType();
tempEAttribute.setName(strAttributeName);
tempEDataType.setName("String");
/*The method returns me a Class object*/
Class<?> temp = getMetaGMEElementFieldType(ProjectTypeImpl.class, strAttributeName);
tempEDataType.setInstanceClass(temp);
tempEDataType.setInstanceTypeName("java.lang.String");
tempEDataType.setInstanceClassName("java.lang.String");
tempEDataType.setSerializable(true);
tempEAttribute.setDefaultValue(tempNode.getNodeValue());
Now the setDefaultValue() method throws me a NullPointerException.
I researched a bit, and found that it is the following piece of code
EFactory factory = eType.getEPackage().getEFactoryInstance();
in the setDefaultValue() (defined in EStructuralFeatureImpl class) that throws the exception.
I inspected the eType (EClassifier object) and found that the ePackage=NULL.
How can I solve this problem?
Arun
Re: EDataType creation [message #636827 is a reply to message #636770] |
Tue, 02 November 2010 21:33   |
Arun,
Comments below.
Arun wrote:
> Hi Guys,
> this issue).
Why would you do such a thing?
> strAttributeName);
Mystery method that returns an Class....
Setting the instance class petty much determines the instance type name,
doesn't it?
Given that there are no type arguments, is there any point in setting both?
This is already the default.
What might tempNode be? Is it really the default value, or is it a literal?
You know how to use the debugger, right?
An EDataType that's not in an EPackage is not in a meaningful/complete
context where you should expect to be able to use it. Similarly an
EAttribute that's not in an EClass in an EPackage is also kind of a free
floating bit of meaninglessness.
> ePackage=NULL.
Yep, that's what I'd expect.
What exactly are you trying to accomplish? A complete Ecore model will
definitely require everything to be rooted in an EPackage....
> Regards
> Arun
Re: EDataType creation [message #636931 is a reply to message #636827] |
Wed, 03 November 2010 08:09  |
Hi Ed,
Thanks for the reply. I found the answer in your reply
Quote: |
An EDataType that's not in an EPackage is not in a meaningful / complete context where you should expect to be able to use it. Similarly an EAttribute that's not in an EClass in an EPackage is also kind of a free floating bit of meaninglessness.
I just added the eDataType to a package and it works perfectly.
Thanks again
Arun
FUDForum. Page generated in 0.05276 seconds
