Home » Eclipse Projects » EclipseLink » DynamicJAXBContext creation fails with NPE
DynamicJAXBContext creation fails with NPE [message #635483] Tue, 26 October 2010 23:22 Go to next message
It seems like I'm missing something obvious, but I've been unable to create an instance of DynamicJAXBContext using EclipseLink 2.1.1, jxc 2.2.1, and these schema files:
http://metadata.dod.mil/mdr/ns/DDMS/2.0/DDMS-v2.0.zip
The calling code:
File schema = new File("src/main/resources/DDMS_2.0/ns/DDMS/2.0/DDMS-v2_0.xsd");
StreamSource ss = new StreamSource(schema);
DynamicJAXBContext c = DynamicJAXBContextFactory.createContextFromXSD(ss, null, null, null);
The stack trace:
Exception in thread "main" java.lang.NullPointerException
	at org.eclipse.persistence.jaxb.javamodel.xjc.XJCJavaClassImpl.isEnum(XJCJavaClassImpl.java:398)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.preBuildTypeInfo(AnnotationsProcessor.java:401)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.buildNewTypeInfo(AnnotationsProcessor.java:3350)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.processXmlJavaTypeAdapter(AnnotationsProcessor.java:1199)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.processPropertyAnnotations(AnnotationsProcessor.java:1668)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.buildNewProperty(AnnotationsProcessor.java:1381)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.getFieldPropertiesForClass(AnnotationsProcessor.java:1309)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.getPropertiesForClass(AnnotationsProcessor.java:1286)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.buildTypeInfo(AnnotationsProcessor.java:523)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.postBuildTypeInfo(AnnotationsProcessor.java:470)
	at org.eclipse.persistence.jaxb.compiler.AnnotationsProcessor.processClassesAndProperties(AnnotationsProcessor.java:176)
	at org.eclipse.persistence.jaxb.compiler.Generator.<init>(Generator.java:100)
	at org.eclipse.persistence.jaxb.dynamic.DynamicJAXBContext.initializeFromXJC(DynamicJAXBContext.java:326)
	at org.eclipse.persistence.jaxb.dynamic.DynamicJAXBContext.initializeFromXSDInputSource(DynamicJAXBContext.java:276)
	at org.eclipse.persistence.jaxb.dynamic.DynamicJAXBContextFactory.createContextFromXSD(DynamicJAXBContextFactory.java:208)
	at foo.FooTest.main(FooTest.java:16)
And the pom.xml
<repositories>
	<repository>
		<id>EclipseLink Repo</id>
		<url>http://www.eclipse.org/downloads/download.php?r=1&amp;nf=1&amp;file=/rt/eclipselink/maven.repo</url>
		<snapshots>
			<enabled>true</enabled>
		</snapshots>
	</repository>
</repositories>
<dependencies>
	<dependency>
		<groupId>com.sun.xml.bind</groupId>
		<artifactId>jaxb-xjc</artifactId>
		<version>2.2.1</version>
	</dependency>
	<dependency>
		<groupId>org.eclipse.persistence</groupId>
		<artifactId>eclipselink</artifactId>
		<version>2.1.1</version>
	</dependency>
</dependencies>
I already set up java.endorsed.dirs to point to the jaxb 2.2.1 api and I've tried various versions of EclipseLink. Nothing seems to work. And the source for XJCJavaClassImpl does not seem to be in maven.
Re: DynamicJAXBContext creation fails with NPE [message #635723 is a reply to message #635483] Wed, 27 October 2010 16:31 Go to previous messageGo to next message
Hello there,
I have looked at this issue, and it is indeed a bug in DynamicJAXB. I have entered a new bug report for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=328888
We should be able to get this fixed soon in an upcoming nightly build of EclipseLink 2.2.
- Rick
Re: DynamicJAXBContext creation fails with NPE [message #636762 is a reply to message #635483] Tue, 02 November 2010 13:03 Go to previous message
This bug has been fixed, please try out the latest EclipseLink 2.2 nightly build (20101102) and let us know if you have any more issues.
http://www.eclipse.org/eclipselink/downloads/nightly.php
Thanks for using EclipseLink Dynamic JAXB!
- Rick
Previous Topic:Validation errors for Eclipselink 2.1.1 project.xml
Next Topic:Weaving and OSGi
Current Time: Sat Jul 26 18:43:54 EDT 2025
Powered by FUDForum. Page generated in 0.05698 seconds
