Home » Eclipse Projects » Plugin Development Environment (PDE) » How to enable a command for popups if the children of the selected element have an certain type
How to enable a command for popups if the children of the selected element have an certain type [message #636735] Tue, 02 November 2010 11:24 Go to next message
Originally posted by: formatzeh.gmx.de
I declared a command and a handler for it. Now I want to enable the
command in popups. The point is that the command should be enabled when
right-clicking a folder (for example in the package explorer) and only
if the folder contains files of a certain type (for example a EMF
resource). Is it possible to declare this issue in the plugin.xml?
best regards,
Gilbert
Re: How to enable a command for popups if the children of the selected element have an certain type [message #636871 is a reply to message #636735] Wed, 03 November 2010 04:18 Go to previous messageGo to next message
> best regards,
> Gilbert
Check this:
http://www.eclipse-tips.com/tutorials/1-actions-vs-commands? start=1
- Prakash
Platform UI Team, IBM
Re: How to enable a command for popups if the children of the selected element have an certain type [message #636947 is a reply to message #636871] Wed, 03 November 2010 09:37 Go to previous messageGo to next message
Hi Prakash,
thanks for the link. But what is described there is only how to
determine the explicit elements of the selection. That can be achieved
with that:
<activeWhen>
<with variable="selection">
<iterate operator="or">
<instanceof value="org.eclipse.core.resources.IFolder"/>
</iterate>
</with>
</activeWhen>
But what I need in addition to that is something like the following:
<enabledWhen>
<with variable="children">
<instanceof
value="org.eclipse.emf.ecore.resource.Resource"/>
</iterate>
</with>
</enabledWhen>
The point is that I want to check the children of the selected element.
Can this be achieved anyhow?
>> best regards,
>> Gilbert
> Check this:
Re: How to enable a command for popups if the children of the selected element have an certain type [message #636973 is a reply to message #636947] Wed, 03 November 2010 11:47 Go to previous message
> <enabledWhen>
> <instanceof
> </iterate>
> </with>
> </enabledWhen>
How about writing a property tester for that?
- Prakash
Previous Topic:perspectiveExtension for Property Pages?
Next Topic:Custom compare
Current Time: Sat Jul 26 18:45:06 EDT 2025
Powered by FUDForum. Page generated in 0.04751 seconds
