Modelling XBRL Taxonomy [message #636468] |
Mon, 01 November 2010 09:49  |
I am not sure if I am expecting too much of the EMF, but in attempting to create an EMF project based on an xbrl taxonomy I am experiencing some errors.
The xsd files are available http://xbrl.iasb.org/repository/2010-04-30/ifrs_20100430.zip and the file I am playing with initially is "ifrs-cor_2010-04-30.xsd".
The ecore model seems to be produced ok but when trying to create the edit code I have problems.
When attempting on a Ubuntu machine I get errors similar to:
"DocumentationTypeItemProvider cannot be resolved to a type"
On a windows vista machine I get error similar to:
"...code of method collectNewChildDescriptors.....is exceeding the 65535 bytes limit"
I suppose the question should be, is EMF suitable for this type of project?
Paul Fraser
Re: Modelling XBRL Taxonomy [message #636498 is a reply to message #636468] |
Mon, 01 November 2010 11:11  |
Paul,
Comments below.
> some errors.
Is that class missing? (You can find it with Ctrl-Shift-T.)
> 65535 bytes limit"
It sounds like you have an incredibly massive model; it's not atypical
that schema designers produce unwieldy things. Even if this works (the
method body wasn't too big), the menu for the set of choices will exceed
the human capacity for choosing from a long menu. You can manually
split it into multiple methods to work around it, but as I said, the UI
will be unwieldy.
> project?
Yes, but Java has limitations, such as method body size. But worse
still, human minds have limitations as well, which suggests that a menu
with hundreds (or perhaps thousands) of child creation choices won't be
suitable.
> Regards
> Paul Fraser
FUDForum. Page generated in 0.24065 seconds
