Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Acceleo as standalone(How to run Acceleo as a standalone Java application)
[Acceleo] Acceleo as standalone [message #635753] |
Wed, 27 October 2010 21:10  |
Hi happy designers,
I would like try to test something with which I would need Acceleo to be used as a standalone Java application : would give it two arguments, target directory and M2T source file, launch from command line (this is what I would like to get).
I had a look at the doc, but there was just really few things about this topic in Acceleo's doc.
It says nothing about what Java compiled files I have to copy outside of Eclipse, and I failed with a test.
This test, which suggested by the doc, is to run a transformation from Eclipse, and to run it as a Java application instead of as a plug-in.
When I do so, I have a message box with a progress bar, which reach the end, but then does not close, what ever the time I wait (even multiple minutes). I have to manually close the Eclipse process, otherwise, the whole Eclipse does not respond any more.
As this test fails, does that means I cannot use Acceleo standalone ?
Surprisingly, the process seems to complete in some way, as files in the target folder appears to be really generated ; this is just that it does not close at the end.
Here is the state of my attempts.
Any hint or tip, or links to doc, to use Acceleo as a Java standalone application, welcome.
Re: [Acceleo] Acceleo as standalone [message #636319 is a reply to message #636309] |
Sat, 30 October 2010 16:39   |
Hi once again Mr Laurent,
Laurent Goubet wrote on Sat, 30 October 2010 12:44 | However as Simon mentionned, if we did have standalone generation in
mind while designing Acceleo, we did not expect that there would also be
such a need for standalone compilation, and you'll have to take a look
at his advice as we haven't made progress in this field since then.
Yes, "standalone" and "portable" is a famous requirement nowadays (and to talk about Java applications, there exist some very lightweight JVM now) .
Just let me explain why I was thinking about it, so it does not look like an unjustified or silly expectation : I though about it because a process may rely on an external compiler and an external UML editor (I am balancing TopCased and ArgoUML, while ArgoUML does not work fine in Eclipse), so that most of the process is done outside of Eclipse. That was why I though about running Acceleo outside of Eclipse if possible.
Laurent Goubet wrote on Sat, 30 October 2010 12:44 | As for the documentation, looking at your comment I do believe we'll
have to update it with a dedicated "standalone" section .
I guess you have many pending job, so please, don't bother too much (except if someone with a commercial support request the same).
Re: [Acceleo] Acceleo as standalone [message #636321 is a reply to message #636309] |
Sat, 30 October 2010 16:49   |
Hi Laurent,
I think, the use case of standalone compilation is an important one.
Most companies use the Hudson Buildserver to build their products. For this occasion, the standalone-compilation is neccessary to build the fully functional product, execute test cases, etc.
It would be great, if some documentation would be provided. Maybe, with an example how to call the compiler. Is it possible to provide something myself? I do not know how the contribution guidelines are for the Acceleo Project.
And currently, the presented AcceleoCompiler Class only puts its output in the source directory. It is currently not possible to specify a target directory. This contradicts to the normal java compilation mechanism, as it compiles from src to bin. Something like this would also be preferred, I think.
Also, at default, the mtl files are copied to the bin directory. By adding Acceleo to the project, this could automatically be excluded.
The last two aspects just came into mind.
Simon
Re: [Acceleo] Acceleo as standalone [message #636334 is a reply to message #636319] |
Sat, 30 October 2010 21:03   |
Yannick Duchene (Hibou57) wrote on Sat, 30 October 2010 16:39 | Just let me explain why I was thinking about it, so it does not look like an unjustified or silly expectation : I though about it because a process may rely on an external compiler and an external UML editor (I am balancing TopCased and ArgoUML, while ArgoUML does not work fine in Eclipse), so that most of the process is done outside of Eclipse. That was why I though about running Acceleo outside of Eclipse if possible.
I'm pretty sure now. After some tests, pretty sure ArgoUML is the UML editor to recommend. Papyrus let you draw erroneous diagrams (you have to manually validate all the time with another tool), has trouble with XMI imports. TopCased is a validating editor, but suffers from too much "pointer error" and also have real troubles with XMI imports. The only one which does not crash while running, validates during edition, and imports XMI without a trouble, is ArgoUML. As said before, as it has failure with its Eclipse variant (ArgoEclipse), and works fine outside of Eclipse, then no more reasons to use Eclipse, except for Acceleo.
TBH: ArgoUML only have experimental support for UML2, and cannot draw state diagrams (which I need) in UML mode. But it seems the more promising of all the ones I tried.
This was my off-topic about what is the most recommended validating UML editor
Have a nice time all.
Re: [Acceleo] Acceleo as standalone [message #636354 is a reply to message #636334] |
Sun, 31 October 2010 06:31   |
--------------060706080407040409030000
Hi Yannick,
Comparison between UML modelers seem to be a reccurent topic :). It's a
wonder no studies are yet out on this ^^.
Laurent Goubet
Obeo
> editor :p
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------060706080407040409030000--
Current Time: Sat Jul 19 03:50:27 EDT 2025
Powered by FUDForum. Page generated in 0.06335 seconds
