Home » Modeling » EMF » Error while generating model
Error while generating model [message #636233] Fri, 29 October 2010 15:21 Go to next message
Hi All,
I had an existing model which was working fine.
I made some changes to the ecore, now when i try to generate the model code.
I get 'Problem encountered while generating model code'.
This is what i get in the stack trace
!ENTRY org.eclipse.emf.codegen.ecore 2 0 2010-10-30 00:39:51.564
!MESSAGE org.eclipse.emf.common.util.DiagnosticException: A problem was detected while parsing a Java file
!STACK 0
org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.common.util.DiagnosticException: A problem was detected while parsing a Java file
	at org.eclipse.emf.codegen.merge.java.facade.ast.ASTFacadeHelper.createCompilationUnit(ASTFacadeHelper.java:285)
	at org.eclipse.emf.codegen.merge.java.facade.ast.ASTFacadeHelper.createCompilationUnit(ASTFacadeHelper.java:1)
	at org.eclipse.emf.codegen.merge.java.JMerger.createCompilationUnitForContents(JMerger.java:381)
	at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.generateJava(AbstractGeneratorAdapter.java:998)
	at org.eclipse.emf.codegen.ecore.genmodel.generator.GenClassGeneratorAdapter.generateInterface(GenClassGeneratorAdapter.java:123)
	at org.eclipse.emf.codegen.ecore.genmodel.generator.GenClassGeneratorAdapter.generateModel(GenClassGeneratorAdapter.java:106)
	at org.eclipse.emf.codegen.ecore.genmodel.generator.GenBaseGeneratorAdapter.doGenerate(GenBaseGeneratorAdapter.java:221)
	at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.generate(AbstractGeneratorAdapter.java:290)
	at org.eclipse.emf.codegen.ecore.generator.Generator.generate(Generator.java:617)
	at org.eclipse.emf.codegen.ecore.genmodel.presentation.GeneratorUIUtil$GeneratorOperation.execute(GeneratorUIUtil.java:167)
	at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1975)
	at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
I reverted the changes made to the model, but still getting the same error.I ran the validation check on the model its not reporting any errors.I am clueless as what is happening
Thanks and Regards,
Saurav
Re: Error while generating model [message #636237 is a reply to message #636233] Fri, 29 October 2010 15:29 Go to previous messageGo to next message
Saurav,
It sounds like it's generating something with a syntax error or what
it's merging has a syntax error. Not clear why though. In the former
case, you could delete all the files and see which one ends up having a
syntax error...
saurav wrote:
> Hi All,
> code.
> !STACK 0
> at
> org.eclipse.emf.codegen.merge.java.facade.ast.ASTFacadeHelpe r.createCompilationUnit(ASTFacadeHelper.java:285)
> at
> org.eclipse.emf.codegen.merge.java.facade.ast.ASTFacadeHelpe r.createCompilationUnit(ASTFacadeHelper.java:1)
> at
> org.eclipse.emf.codegen.merge.java.JMerger.createCompilation UnitForContents(JMerger.java:381)
> at
> org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAda pter.generateJava(AbstractGeneratorAdapter.java:998)
> at
> org.eclipse.emf.codegen.ecore.genmodel.generator.GenClassGen eratorAdapter.generateInterface(GenClassGeneratorAdapter.jav a:123)
> at
> org.eclipse.emf.codegen.ecore.genmodel.generator.GenClassGen eratorAdapter.generateModel(GenClassGeneratorAdapter.java:10 6)
> at
> org.eclipse.emf.codegen.ecore.genmodel.generator.GenBaseGene ratorAdapter.doGenerate(GenBaseGeneratorAdapter.java:221)
> at
> org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAda pter.generate(AbstractGeneratorAdapter.java:290)
> at
> org.eclipse.emf.codegen.ecore.generator.Generator.generate(G enerator.java:617)
> at
> org.eclipse.emf.codegen.ecore.genmodel.presentation.Generato rUIUtil$GeneratorOperation.execute(GeneratorUIUtil.java:167)
> at
> org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:106)
> at
> org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1975)
> at
> org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:118)
> at
> org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
> Thanks and Regards,
> Saurav
Re: Error while generating model [message #636238 is a reply to message #636233] Fri, 29 October 2010 15:44 Go to previous messageGo to next message
Thanks Ed for the reply.
I was reluctant to delete the model classes since i was depending on them heavily Razz
anyways i took a backup and deleted the files and generated them again ...very strangely the class comment section is generating with an extra '*/', that makes the syntax error.
I am sure i did not touch any templates Razz
Now i removed the syntaxes and the test cases work fine.But i am circumspect that this problem remains.
cheers,
Saurav
Re: Error while generating model [message #636258 is a reply to message #636238] Fri, 29 October 2010 17:58 Go to previous message
Saurav,
That's very strange. I can't imagine how that would happen, except
maybe if you have a model documentation annotation that has such an
extra pair of characters...
> them heavily :p
> I am sure i did not touch any templates :p
> cheers,
> Saurav
Previous Topic:[CDO] cdoPrefetch() Timeout
Next Topic:itemProviderAdapterFactories
Current Time: Fri Jul 18 11:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.06603 seconds
