Home » Archived » BIRT » WebViewer NullPointerException when using global variables
WebViewer NullPointerException when using global variables [message #539156] Wed, 09 June 2010 14:45 Go to next message
After creating a Report Variable from the Outline I am getting a
NullPointerException error when running BIRT with the WebViewer.
It runs fine when viewing as doc, PDF, html, etc., except for the Web
Viewer.
eclipse Galileo: Build id: 20100218-1602
BIRT Version: 2.5.2.v20090925-7l9V7YFT0z0-DX3kf8ShK8
BIRT Build id: v20100210-0630
XML Source:
<property name="pageVariables">
<variable-element name="rptAUX_Category">
<expression name="value" type="javascript">BirtStr.trim("")</expression>
<property name="type">report</property>
</variable-element>
</property>
Re: WebViewer NullPointerException when using global variables [message #539183 is a reply to message #539156] Wed, 09 June 2010 17:22 Go to previous messageGo to next message
Laurent,
I just tried to reproduce this with 2.5.2 and it did not fail. I just
used a blank report added the page report variable and added the
variable to the master page. Can you try this as well?
Jason
> Viewer.
> XML Source:
> </variable-element>
> </property>
Re: WebViewer NullPointerException when using global variables [message #635913 is a reply to message #539156] Thu, 28 October 2010 11:17 Go to previous messageGo to next message
We are having the same issue. However, we have been able to narrow it down to only files that contain a library. You do not have to be using anything from the library on the report, it's just the existence of the library.
As Laurent mentions, the error only happens in the webviewer.
Can you retry your blank report scenario using a library and advise as to whether or not you can reproduce the issue?
Re: WebViewer NullPointerException when using global variables [message #635930 is a reply to message #635913] Thu, 28 October 2010 11:33 Go to previous messageGo to next message
Is the library referenced in the report at all?
Do you have a resource folder set in the web.xml?
Jason
> library.
> Thanks
Re: WebViewer NullPointerException when using global variables [message #635960 is a reply to message #635930] Thu, 28 October 2010 14:28 Go to previous messageGo to next message
The library is not referenced in the report. This is the only code in the report for the library:
<list-property name="libraries">
<structure>
<property name="fileName">TestLibrary.rptlibrary</property>
<property name="namespace">TestLibrary</property>
</structure>
</list-property>
As far as the web.xml file, there are no hard coded references to the library. This file contains all default values of:
Report resources directory for preview. Defaults to ${birt home}
<context-param>
<param-name>BIRT_VIEWER_WORKING_FOLDER</param-name>
<param-value></param-value>
</context-param>
and
<!-- Resource location directory. Defaults to ${birt home} -->
<context-param>
<param-name>BIRT_RESOURCE_PATH</param-name>
</context-param>
As an additional note, the TestLibrary that I have referenced in my report is completely empty. I was concerned that our current library, which has been carried forward through several upgrades might have been the issue, so I created a new "empty" library.
Re: WebViewer NullPointerException when using global variables [message #635967 is a reply to message #635960] Thu, 28 October 2010 14:49 Go to previous messageGo to next message
Is the library in the same folder as the report design?
Jason
> <structure>
> </structure>
> </list-property>
> <context-param>
> </context-param>
> and
> <context-param>
> </context-param>
Re: WebViewer NullPointerException when using global variables [message #635975 is a reply to message #635967] Thu, 28 October 2010 15:14 Go to previous messageGo to next message
In my test case it is. But, in the actual report I am working on, they are in different locations.
Re: WebViewer NullPointerException when using global variables [message #635977 is a reply to message #635975] Thu, 28 October 2010 15:35 Go to previous messageGo to next message
I will try to reproduce the issue.
Jason
Re: WebViewer NullPointerException when using global variables [message #636225 is a reply to message #635977] Fri, 29 October 2010 14:14 Go to previous messageGo to next message
What type of page variable are you using?
Jason
> Jason
Re: WebViewer NullPointerException when using global variables [message #636230 is a reply to message #636225] Fri, 29 October 2010 14:45 Go to previous messageGo to next message
I currently have it set as a page variable. But, I have tried report variable as well.
Is that what you are asking? Or are you referring to what type of data am I assigning to the variable? If that is the case, I am assigning an integer to be stored as the page number. But, it was my understanding that all variable values are strings???
Re: WebViewer NullPointerException when using global variables [message #636252 is a reply to message #636230] Fri, 29 October 2010 16:08 Go to previous messageGo to next message
I was able to reproduce the issue. This appears to have been a bug.
The issue does not happen in 2.6.1. I tried to come up with a work
around but was not able to.
Jason
> variable as well.
Re: WebViewer NullPointerException when using global variables [message #636529 is a reply to message #636252] Mon, 01 November 2010 13:32 Go to previous messageGo to next message
Is this the same issue that was fixed with bug 312759?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=312759
If so, do you know where the initialization sequence was modified?
Re: WebViewer NullPointerException when using global variables [message #636539 is a reply to message #636529] Mon, 01 November 2010 15:15 Go to previous message
Most likely. Can you add your question to the bug to get more details
on what was fixed?
Jason
> Thanks
Previous Topic:Postscript page count
Next Topic:BIRT Queries
Current Time: Sat Jul 26 12:44:30 EDT 2025
Powered by FUDForum. Page generated in 0.05226 seconds
