Home » Archived » BIRT » ViewerException in IE
ViewerException in IE [message #636013] Thu, 28 October 2010 19:26 Go to next message
BIRT 2.6.1
IE 8
Tomcat 6 and Websphere 6
URL https://localhost:8443/spear/frameset/admin?__showtitle=fals e&__locale=en_AU&__report=admin/organisationSummary. rptdesign
When I generate a report using the above URL, it renders fine, however I notice the following exceptoin in the logs. Doesn't happen if I'm using Chrome. Any ideas?
Thanks, Josh.
org.eclipse.birt.report.exception.ViewerException: There is no report design object available.
at org.eclipse.birt.report.context.ViewerAttributeBean.__init(V iewerAttributeBean.java:226)
at org.eclipse.birt.report.context.BaseAttributeBean.init(BaseA ttributeBean.java:233)
at org.eclipse.birt.report.context.ViewerAttributeBean.<init>(ViewerAttributeBean.java:118)
at org.eclipse.birt.report.context.BirtContext.__init(BirtConte xt.java:44)
at org.eclipse.birt.report.context.BaseContext.<init>(BaseContext.java:69)
at org.eclipse.birt.report.context.BirtContext.<init>(BirtContext.java:30)
at au.gov.vic.dse.lx.spear.web.servlets.BirtViewerServlet.__get Context(BirtViewerServlet.java:141)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(BirtSoapMessageDispatcherServlet.java:151)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil .java:244)
at javax.security.auth.Subject.doAsPrivileged(Subject.java:517)
at org.apache.catalina.security.SecurityUtil.execute(SecurityUt il.java:276)
Re: ViewerException in IE [message #636218 is a reply to message #636013] Fri, 29 October 2010 12:40 Go to previous messageGo to next message
Josh,
Are you using a modified version of the Viewer?
admin is not a servlet mapping in the viewer.
Jason
On 10/28/2010 7:26 PM, Josh wrote:
> BIRT 2.6.1
> IE 8
> URL
> Chrome. Any ideas?
> Thanks, Josh.
> at
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at java.security.AccessController.doPrivileged(Native Method)
> il.java:276)
Re: ViewerException in IE [message #636406 is a reply to message #636218] Mon, 01 November 2010 01:38 Go to previous messageGo to next message
Hi Jason,
Yes, it is a *slightly* modified version of the viewer application. The reports are secured via standard web.xml <security-constraint> entries, hence the url relating to 'admin'. The reports there are for admin only.
Having now put in some more logging, I can see the errors are due to the browser (IE) calling back (after the initial call) for the *.js resources, as per:-
https://localhost:8443/spear/frameset/birt/ajax/ui/dialog/Bi rtSimpleExportDataDialog.js
Because the 'frameset' is in those URL's, the ViewServlet gets invoked and it goes off looking for report parameters in the URL, which it can't find.
The interesting thing is that the callbacks are not shown in my logging when using Chrome, which explains the difference.
All that said, I'm still at a loss as to (a)how to get rid of these errors, and (b)why the behavior if different between browsers.
Thanks. Josh.
Re: ViewerException in IE [message #636494 is a reply to message #636406] Mon, 01 November 2010 11:13 Go to previous messageGo to next message
The AJAX framework is using web service calls back to the viewer servlet
to get the parameter data. I believe the chrome issue may have already
been reported:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=326295
Jason
On 11/1/2010 1:38 AM, Josh wrote:
> Hi Jason,
> resources, as per:-
> find.
> Thanks. Josh.
Re: ViewerException in IE [message #636807 is a reply to message #636494] Tue, 02 November 2010 17:03 Go to previous messageGo to next message
I was aware of that Chrome bug, however I don't think it's related to this issue. In fact, as mentioned, Chrome is working fine, it's actually IE that's reporting the errors.
Re: ViewerException in IE [message #636817 is a reply to message #636807] Tue, 02 November 2010 18:40 Go to previous messageGo to next message
I've found that if I add the following to org.eclipse.birt.report.servlet.ViewerServlet, the errors are no longer reported:-
	public void service(ServletRequest req, ServletResponse res) throws ServletException, IOException
		if (!((HttpServletRequest)req).getRequestURL().toString().endsWith(".js"))
			super.service(req, res);
Is this something you might like committed?
Re: ViewerException in IE [message #636994 is a reply to message #636817] Wed, 03 November 2010 12:50 Go to previous messageGo to next message
Can you open a bugzilla entry and suggest this mod?
Jason
> reported:-
> @Override
> if (!((HttpServletRequest)req).getRequestURL().toString().endsW ith( ".js"))
Re: ViewerException in IE [message #637034 is a reply to message #636994] Wed, 03 November 2010 17:29 Go to previous message
Done. https://bugs.eclipse.org/bugs/show_bug.cgi?id=329403
Regards, Josh.
Previous Topic:Data source URL
Next Topic:Font size handling in IE different
Current Time: Fri Jul 18 20:07:42 EDT 2025
Powered by FUDForum. Page generated in 0.05032 seconds
