Home » Eclipse Projects » EclipseLink » mapping custom types
mapping custom types [message #636011] Thu, 28 October 2010 18:52 Go to next message
I created a type in Oracle 11g here is the code:
CREATE OR REPLACE TYPE XILM.cm_info_t
AS OBJECT
created_by VARCHAR2 (30) ,
create_time DATE ,
last_modification_time DATE ,
last_modified_by VARCHAR2 (30)
) NOT FINAL
I want to map this type in my project. I created a class InfoConverter
public class InfoConverter implements StructConverter {
private static final String CM_INFO_T = "xilm.cm_info_t";
private static final Logger LOGGER = LoggerFactory
.getLogger(InfoConverter.class);
public Object convertToObject(Struct mystruct) throws SQLException {
LOGGER.debug("convert called");
Object cols[] = mystruct.getAttributes();
Info info = new Info();
info.setCreatedBy((String) cols[0]);
info.setCreationTime((Date) cols[1]);
info.setModificationTime((Date) cols[2]);
info.setLastModifiedBy((String) cols[3]);
return info;
public Struct convertToStruct(Object arg0, Connection arg1)
StructDescriptor colStructDesc = StructDescriptor.createDescriptor(
CM_INFO_T, arg1);
Info info = (Info) arg0;
Object[] objectArray = new Object[4];
objectArray[0] = info.getCreatedBy();
objectArray[1] = info.getCreationTime();
objectArray[2] = info.getModificationTime();
objectArray[3] = info.getLastModifiedBy();
oracle.sql.STRUCT colStruct = new STRUCT(colStructDesc, arg1,
objectArray);
return colStruct;
public Class<Info> getJavaType() {
return Info.class;
public String getStructName() {
return CM_INFO_T;
My current mapping which uses this type is like
@Entity
@Table(name = "ILM_WORKSPACE")
@StructConverter(name = "infoConverter", converter = "com.globalmaksimum.dao.workspace.jpa.InfoConverter")
public class Workspace implements Serializable {
private static final long serialVersionUID = 1L;
@Id
@GeneratedValue(strategy = GenerationType.SEQUENCE, generator = "SQ_WORKSPACE")
@Column(name = "WORKSPACE#")
@SequenceGenerator(name = "SQ_WORKSPACE", sequenceName = "SQ_WORKSPACE", allocationSize = 1)
private long workspace_;
@Convert("infoConverter")
@Column(name = "CM_INFO")
private Info cmInfo;
private BigDecimal status;
@Column(name = "WORKSPACE_DESC")
private String workspaceDesc;
@Column(name = "WORKSPACE_DOP")
private BigDecimal workspaceDop;
@Column(name = "WORKSPACE_NAME")
private String workspaceName;
// bi-directional many-to-one association to ExecutionInfo
@ManyToOne
@JoinColumn(name = "SCHEDULE#")
private ExecutionInfo ilmSchedule;
// bi-directional many-to-one association to Task
@OneToMany(mappedBy = "ilmWorkspace")
private Set<Task> ilmWorkspaceTasks;
public Workspace() {
public long getWorkspace_() {
return this.workspace_;
public void setWorkspace_(long workspace_) {
this.workspace_ = workspace_;
public Info getCmInfo() {
return this.cmInfo;
public void setCmInfo(Info cmInfo) {
this.cmInfo = cmInfo;
public BigDecimal getStatus() {
return this.status;
public void setStatus(BigDecimal status) {
this.status = status;
public String getWorkspaceDesc() {
return this.workspaceDesc;
public void setWorkspaceDesc(String workspaceDesc) {
this.workspaceDesc = workspaceDesc;
public BigDecimal getWorkspaceDop() {
return this.workspaceDop;
public void setWorkspaceDop(BigDecimal workspaceDop) {
this.workspaceDop = workspaceDop;
public String getWorkspaceName() {
return this.workspaceName;
public void setWorkspaceName(String workspaceName) {
this.workspaceName = workspaceName;
public ExecutionInfo getIlmSchedule() {
return this.ilmSchedule;
public void setIlmSchedule(ExecutionInfo ilmSchedule) {
this.ilmSchedule = ilmSchedule;
public Set<Task> getIlmWorkspaceTasks() {
return this.ilmWorkspaceTasks;
public void setIlmWorkspaceTasks(Set<Task> ilmWorkspaceTasks) {
this.ilmWorkspaceTasks = ilmWorkspaceTasks;
Project is a JPA project which uses spring and eclipselink as JPA provider. But in tests it throws an exception when trying to map Workspace entity here is the stack trace
Test set: org.workspacedao.DaoTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 20.861 sec <<< FAILURE!
testGetExecutionInfo(org.workspacedao.DaoTest) Time elapsed: 20.521 sec <<< ERROR!
Local Exception Stack:
Exception [EclipseLink-3002] (Eclipse Persistence Services - 2.1.1.v20100817-r8050): org.eclipse.persistence.exceptions.ConversionException
Exception Description: The object [[Ljava.lang.Object;@699c9f16], of class [class [Ljava.lang.Object;], from mapping [org.eclipse.persistence.mappings.DirectToFieldMapping[cmInf o-- >ILM_WORKSPACE.CM_INFO]] with descriptor [RelationalDescriptor(com.globalmaksimum.dao.workspace.jpa.W orkspace --> [DatabaseTable(ILM_WORKSPACE)])], could not be converted to [class com.globalmaksimum.dao.workspace.jpa.Info].
at org.eclipse.persistence.exceptions.ConversionException.could NotBeConverted(ConversionException.java:71)
at org.eclipse.persistence.internal.helper.ConversionManager.co nvertObject(ConversionManager.java:169)
at org.eclipse.persistence.internal.databaseaccess.DatasourcePl atform.convertObject(DatasourcePlatform.java:157)
at org.eclipse.persistence.platform.database.oracle.Oracle9Plat form.convertObject(Oracle9Platform.java:358)
at org.eclipse.persistence.mappings.foundation.AbstractDirectMa pping.getAttributeValue(AbstractDirectMapping.java:680)
at org.eclipse.persistence.mappings.foundation.AbstractDirectMa pping.valueFromRow(AbstractDirectMapping.java:1263)
at org.eclipse.persistence.mappings.DatabaseMapping.readFromRow IntoObject(DatabaseMapping.java:1283)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildAttributesIntoObject(ObjectBuilder.java:342)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObject(ObjectBuilder.java:711)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObject(ObjectBuilder.java:504)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObjectsInto(ObjectBuilder.java:904)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLe velReadQuery(ReadAllQuery.java:423)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute DatabaseQuery(ObjectLevelReadQuery.java:1074)
at org.eclipse.persistence.queries.DatabaseQuery.execute(Databa seQuery.java:736)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute (ObjectLevelReadQuery.java:1034)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAll Query.java:380)
at org.eclipse.persistence.internal.sessions.AbstractSession.in ternalExecuteQuery(AbstractSession.java:2392)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1291)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1273)
at org.eclipse.persistence.internal.indirection.QueryBasedValue Holder.instantiate(QueryBasedValueHolder.java:85)
at org.eclipse.persistence.internal.indirection.QueryBasedValue Holder.instantiate(QueryBasedValueHolder.java:75)
at org.eclipse.persistence.internal.indirection.DatabaseValueHo lder.getValue(DatabaseValueHolder.java:83)
at org.eclipse.persistence.internal.indirection.UnitOfWorkValue Holder.instantiateImpl(UnitOfWorkValueHolder.java:160)
at org.eclipse.persistence.internal.indirection.UnitOfWorkValue Holder.instantiate(UnitOfWorkValueHolder.java:220)
at org.eclipse.persistence.indirection.IndirectSet.buildDelegat e(IndirectSet.java:192)
at org.eclipse.persistence.indirection.IndirectSet.getDelegate( IndirectSet.java:343)
at org.eclipse.persistence.indirection.IndirectSet.size(Indirec tSet.java:500)
at org.workspacedao.DaoTest.testGetExecutionInfo(DaoTest.java:3 3)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall( FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(Refl ectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(Fr ameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate( InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(Ru nBefores.java:28)
at org.springframework.test.context.junit4.statements.RunBefore TestMethodCallbacks.evaluate(RunBeforeTestMethodCallbacks.ja va:74)
at org.junit.internal.runners.statements.RunAfters.evaluate(Run Afters.java:31)
at org.springframework.test.context.junit4.statements.RunAfterT estMethodCallbacks.evaluate(RunAfterTestMethodCallbacks.java :82)
at org.springframework.test.context.junit4.statements.SpringRep eat.evaluate(SpringRepeat.java:72)
at org.springframework.test.context.junit4.SpringJUnit4ClassRun ner.runChild(SpringJUnit4ClassRunner.java:240)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:46)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java :180)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java: 41)
at org.junit.runners.ParentRunner$1.evaluate(ParentRunner.java: 173)
at org.springframework.test.context.junit4.statements.RunBefore TestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java :61)
at org.springframework.test.context.junit4.statements.RunAfterT estClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:7 0)
at org.junit.runners.ParentRunner.run(ParentRunner.java:220)
at org.springframework.test.context.junit4.SpringJUnit4ClassRun ner.run(SpringJUnit4ClassRunner.java:180)
at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit 4TestSet.java:59)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.e xecuteTestSet(AbstractDirectoryTestSuite.java:115)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.e xecute(AbstractDirectoryTestSuite.java:102)
at org.apache.maven.surefire.Surefire.run(Surefire.java:180)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInP rocess(SurefireBooter.java:350)
at org.apache.maven.surefire.booter.SurefireBooter.main(Surefir eBooter.java:1021)
I dont understand where i is the mistake?
[Updated on: Thu, 28 October 2010 18:52] by Moderator
Re: mapping custom types [message #636174 is a reply to message #636011] Fri, 29 October 2010 10:26 Go to previous messageGo to next message
The struct name might be wrong, as I believe you have it defined in the value returned by getStructName "xilm.cm_info_t" in lower case while the database will be returning it as "XILM.CM_INFO_T". The lower case string is fine when building a struct as the database is case sensitive, but looking up the converter using the upper case string returned from the database when it is hashed on the getStructName will only work if the case matches exactly.
Best Regards,
Chris
Re: mapping custom types [message #636188 is a reply to message #636174] Fri, 29 October 2010 11:11 Go to previous message
Oh thanks a lot chris. I have struggled with the issue for two days:)
Previous Topic:connecting an application to two different JNDI datasources
Next Topic:Validation errors for Eclipselink 2.1.1 project.xml
Current Time: Sat Jul 26 19:09:44 EDT 2025
Powered by FUDForum. Page generated in 0.04243 seconds
