Home » Eclipse Projects » Virgo » dm Server Tools manifest problem
dm Server Tools manifest problem [message #635788] Thu, 28 October 2010 02:47 Go to next message
when deploying a bundle to a Virgo Web Server the existing MANIFEST.MF file seems to be ignored. This results in the deployed bundle having version 0 and no package imports/exports:
Manifest-Version: 1.0
Bundle-SymbolicName: test
Bundle-ManifestVersion: 2
The manifest file I want is in src/main/resources/META-INF/MANIFEST.MF and it is correctly displayed if I select Open MANIFEST.MF from the bundle's context menu in the Server View.
Thanks in advance,
tom
Re: dm Server Tools manifest problem [message #635798 is a reply to message #635788] Thu, 28 October 2010 03:54 Go to previous messageGo to next message
I think that's a tooling glitch, which is unfortunately hard to reproduce, but can be worked around by appropriate Eclipse "dances" such as using "clean..." against the server to clear out the staging area, closing/opening the project, undeploying then redeploying, and ensuring the server is started with the clean option to be on the safe side.
If you can reproduce this predictably, please provide steps to reproduce and kindly raise a bug against the tooling. You can use the Virgo bugzilla as we probably won't be able to fix the bug before the tooling is contributed to Eclipse.
Hope that's some help. I know it's not ideal.
Re: dm Server Tools manifest problem [message #635872 is a reply to message #635788] Thu, 28 October 2010 09:04 Go to previous messageGo to next message
Thanks for your reply. After quite some toying around I think I found the (or at leas a) problem:
The main catch seems to be that previously I had Virgo installed outside of my home dir (/var/tmp).
After reinstalling it in my home dir I still had to perform your suggested "dances" for some bundles (others worked right away). But now everything looks fine.
I will check bugzilla if this is a known problem and create a bugreport if it is not.
Re: dm Server Tools manifest problem [message #635893 is a reply to message #635872] Thu, 28 October 2010 10:11 Go to previous message
Glad you made progress.
Previous Topic:@PostConstruct method is not invoked
Next Topic:How to inject EntityManager in each bundle?
Current Time: Sun Jul 27 09:29:07 EDT 2025
Powered by FUDForum. Page generated in 0.03825 seconds
