Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [TEXO] EMF which Code generation
[TEXO] EMF which Code generation [message #635785] Thu, 28 October 2010 02:33 Go to next message
i have a ecore model. From this ecore Model i create a genmodel which generates my Java Code.
Now i create from the ecore a annotationsmodel by Texo.
I want to create the orm.xml But i dont know which Java-Code generation i have to use? The generation from Texo generate Model Code without Interfaces?
Or can I use the genmodel and the annotationsmodel?
Is there a code example in svn or cvs?
Re: [TEXO] EMF which Code generation [message #635820 is a reply to message #635785] Thu, 28 October 2010 05:21 Go to previous message
Hi Wayne,
The Texo orm generation assumes that you generated Texo code and not EMF code. As Texo generates true pojos (with
standard list implementations) the orm mapping is easier and can run on a standard runtime without extra runtime layers
(like Teneo). Here are some special code generation features btw:
http://wiki.eclipse.org/Texo/Code_Generation_Patterns
The Teneo orm generation assumes that you generated code using EMF and genmodel.
Btw, Texo currently has 2 annotation models: 1) for code generation, 2) for orm. My advice is to only fill the
annotations model with the things you want to override from the standard generation, so remove all the other annotations
which you don't want to override.
gr. Martin
On 10/28/2010 08:33 AM, SirWayne wrote:
> Hello,
> Interfaces? Or can I use the genmodel and the annotationsmodel?
> Thanks
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:Multiple tabs inside an editor
Next Topic:Generating java code from ecore by texo outside UI
Current Time: Wed Jul 23 05:25:16 EDT 2025
Powered by FUDForum. Page generated in 0.35457 seconds
