Home » Archived » BIRT » Creating a chart using the design engine
Creating a chart using the design engine [message #63349] Mon, 01 August 2005 09:39 Go to next message
Has anyone created a chart programmatically using the design engine API's?
If so, please could you give me an example of how to go about doing so.
Thanks and Regards,
Nathan
Re: Creating a chart using the design engine [message #63574 is a reply to message #63349] Tue, 02 August 2005 00:06 Go to previous messageGo to next message
Hi Nathan,
Attached is a chart example created by using DE API and chart engine API.
I'm sorry that it looks a little bit ugly. However, it is able to make the
chart nicer by setting the relevant properties.
The examples of setting chart properties could be checked out from
org.eclipse.birt.chart.examples plugin.
Cheers.
Nina
"Nathan McKeown" <nathan.mckeown@scapatech.com> wrote in message
news:dcl8as$f3s$2@news.eclipse.org...
> Thanks and Regards,
> Nathan
Re: Creating a chart using the design engine [message #63642 is a reply to message #63574] Tue, 02 August 2005 11:48 Go to previous messageGo to next message
Hi Nina,
Thanks for the help, it allowed me to create a basic line chart without
too much fuss, however I am still having some trouble trying to add a
series grouping key to my chart. Is there a simple way to do this?
Nathan
Nina Li wrote:
> Hi Nathan,
> Cheers.
> Regards,
> Nina
>>Hi,
>>Thanks and Regards,
>>Nathan
Re: Creating a chart using the design engine [message #63803 is a reply to message #63642] Tue, 02 August 2005 23:32 Go to previous messageGo to next message
Hi Nathan,
The series grouping key could be set as follows:
SeriesDefinition seGroup = SeriesDefinitionImpl.create();
Query query = QueryImpl.create("row[\"Month\"]");
seGroup.setQuery(query);
yAxisPrimary.getSeriesDefinitions().add(seGroup);
seGroup.getSeries().add(bs);
------and please delete the following code in the original class------------
SeriesDefinition sdY = SeriesDefinitionImpl.create();
sdY.getSeries().add(bs);
yAxisPrimary.getSeriesDefinitions().add(sdY);
Cheers. ^-^
Nina
news:dco473$kum$1@news.eclipse.org...
> Hi Nina,
> Nathan
> Nina Li wrote:
>> Hi Nathan,
>> the chart nicer by setting the relevant properties.
>> Cheers.
>> Regards,
>> Nina
>>>Hi,
>>>API's?
>>>Thanks and Regards,
>>>Nathan
Re: Creating a chart using the design engine [message #64013 is a reply to message #63803] Wed, 03 August 2005 09:04 Go to previous message
Hi Nina,
That works a treat!
Nathan
Nina Li wrote:
> Hi Nathan,
> Cheers. ^-^
> Regards,
> Nina
>>Hi Nina,
>>Nathan
>>Nina Li wrote:
>>>Hi Nathan,
>>>Cheers.
>>>Regards,
>>>Nina
>>>>Hi,
>>>>API's?
>>>>Thanks and Regards,
>>>>Nathan
Previous Topic:Data Sorting
Next Topic:PDF Images
Current Time: Wed Oct 15 01:37:55 EDT 2025
Powered by FUDForum. Page generated in 0.03286 seconds
