Home » Archived » M2M (model-to-model transformation) » [ATL] How use UML Primtives Types in Target Model
[ATL] How use UML Primtives Types in Target Model [message #635632] Wed, 27 October 2010 10:48 Go to next message
Hi men,
I try to execute this rule in an ATL Transformation :
rule Property {
from s : UML2!"uml::Property" (
if thisModule.inElements->includes(s) then
s->oclIsTypeOf(UML2!"uml::Property")
else false endif)
to t : UML2!"uml::Property" mapsTo s (
name <- s.name,
type <- s.type,
qualifier <- s.qualifier)
But unfortunately the result is not expected : the target type is always empty even if the source type is an Primitive Type as String.
I think that's an ingenuous question but i'm sorry, I'm newbie in this technologie.
Thank's for your answers.
Re: [ATL] How use UML Primtives Types in Target Model [message #635677 is a reply to message #635632] Wed, 27 October 2010 13:27 Go to previous message
Ok, it's very simple.
If you have the same problem, you have to check the Allow inter-model references in the Advanced Tab of running ATL configuration.
Previous Topic:[ATL] transformation generated automatically
Next Topic:[QVTo] Use of extended metamodels in transformations
Current Time: Sat Jul 19 03:48:26 EDT 2025
Powered by FUDForum. Page generated in 0.06299 seconds
