Home » Eclipse Projects » Eclipse Platform » problem in user defined order of jar files during exporting(exporting with runnable jar file)
problem in user defined order of jar files during exporting [message #634565] Fri, 22 October 2010 05:16 Go to next message
Dear All,
I am having problem in handling the order of jar files while exporting the eclipse project to runnable jar file.
I have FOP and SAXON external jar files. I wanted saxon.jar to be before FOP.jar. i have set this order in my classpath definition of eclipse. when i export the project to runnable jar file then the order of the jar files are changing and i am having problem in run time.
any suggestions please. Looking forward for your valuable reply.
Ven
Re: problem in user defined order of jar files during exporting [message #634607 is a reply to message #634565] Fri, 22 October 2010 08:32 Go to previous messageGo to next message
You mean if eclipse generates the MANIFEST.MF for your jar, it generates
the Class-Path: header in the wrong order?
If that's the case 1) open a bug against Eclipse JDT/UI -
https://bugs.eclipse.org/bugs and 2) a workaround is for you to supply
the MANIFEST.MF yourself.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: problem in user defined order of jar files during exporting [message #635044 is a reply to message #634607] Mon, 25 October 2010 10:17 Go to previous messageGo to next message
Hi Paul,
If i generate Runnable Jar file using Eclipse then there is not Manifest file generated. In this case the order of the jar files are in alphabetical order.
In the case when i generate jar file only then it asks me where to generate the manifest file and i selected the placeholder with the name of the manifest but the manifest does not have any classpath information.
Could you please help in guiding me how to generate normal jar file with the classpath order jar files in eclipse and the steps i need to take care.
because when i try to generate the output, what i got is not related to what i want. The order of the jar files in alphabetical order.
Thank you in advance.
Ven
Re: problem in user defined order of jar files during exporting [message #635097 is a reply to message #635044] Mon, 25 October 2010 11:48 Go to previous messageGo to next message
Below is my manifest file
Manifest-Version: 1.0
Class-Path: .
../TACommon/libs/avalon-framework-4.2.0.jar
../TACommon/libs/batik-all-1.7.jar
../TACommon/libs/saxon9he.jar
../TACommon/libs/fop.jar
../TACommon/libs/jdom-1.1.jar
../TACommon/libs/junit-4.8.2.jar
../TACommon/libs/serializer.jar
../TACommon/libs/xsltc.jar
../TACommon/libs/xmlgraphics-commons-1.4.jar
../TACommon/libs/xstream-1.3.1.jar
../TACommon/libs/xstream-benchmark-1.3.1.jar
../TACommon/libs/commons-io-1.4.jar
Main-Class: com.ssc.ta.dgc.SampleTest
i could not find the library jar files while running after jar file creation, these library files are mentioned in the manifest. But these library jar files are in TACommon folder outside the project .
Re: problem in user defined order of jar files during exporting [message #635121 is a reply to message #635097] Mon, 25 October 2010 12:46 Go to previous messageGo to next message
Supply your own manifest, then it will do what you want.
See http://download.oracle.com/javase/tutorial/deployment/jar/ for
working with MANIFESTs and Class-Path.
PW
Paul Webster
Re: problem in user defined order of jar files during exporting [message #635147 is a reply to message #635121] Mon, 25 October 2010 14:35 Go to previous messageGo to next message
Dear paul,
The Manifest mentioned in the above posting is the supplied one.
Basically the question on my side is . How to access the libraries that are out side the project folder.
example in my case . I have project A and project B in eclipse. My building jar file of project B which uses project A and libraries which are in the libs folder of project A. Building of jar file on project B is successful , but when i run project B then it completes that the classes used from libraries in projects A are not found. When i open the project B jar file then i see the libraries are in the jar file.
Could you please help me . I tried all the possible ways which i can think off.
Ven
Re: problem in user defined order of jar files during exporting [message #635259 is a reply to message #635147] Tue, 26 October 2010 04:19 Go to previous messageGo to next message
Small corrections in the example given.
When exporting project B to jar file, i have fed the manually written manifest file as mentioned in the below posting. after exporting project B to jar file , i opened the jar file to check the contents of the jar file. In the project B jar file i can see all the jar files that i have been using from the project A folder structure. But when i run project B it complaints that it could not find the classes from the jar files that are in the project A.
Here is sample exception
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/fop/apps/FopFactory
This exception arised because it could not find the FOP.jar which is mentioned in classpath of project B and the jar file is inside project A folder structure.
Re: problem in user defined order of jar files during exporting [message #635341 is a reply to message #635259] Tue, 26 October 2010 09:40 Go to previous messageGo to next message
And how are you running project B? What's the command line?
PW
Paul Webster
Re: problem in user defined order of jar files during exporting [message #635342 is a reply to message #635341] Tue, 26 October 2010 09:54 Go to previous messageGo to next message
java -jar B.jar
the main class of B project is Main-Class: com.ssc.ta.dgc.SampleTest
as mentioned in manifest file.
Re: problem in user defined order of jar files during exporting [message #635576 is a reply to message #635342] Wed, 27 October 2010 07:50 Go to previous messageGo to next message
ven chowdary wrote:
> java -jar B.jar
Then if you have Class-Path: ../lib/lib1.jar it expects to find that jar
relative to B.jar
PW
Paul Webster
Re: problem in user defined order of jar files during exporting [message #635854 is a reply to message #635576] Thu, 28 October 2010 07:29 Go to previous message
Dear paul
Thank you for your support.
I could find the problem on my side.
The problem is " Space after the jar file". I did not leave a space after the jar file text information but i left in front. some times silly problems create hell
../TACommon/libs/avalon-framework-4.2.0.jar<SPACE>
../TACommon/libs/batik-all-1.7.jar<SPACE>
../TACommon/libs/saxon9he.jar<SPACE>
../TACommon/libs/fop.jar<SPACE>
../TACommon/libs/jdom-1.1.jar<SPACE>
../TACommon/libs/junit-4.8.2.jar<SPACE>
../TACommon/libs/serializer.jar<SPACE>
Previous Topic:How to contribute configurations programmatically
Next Topic:Removing updatesite fix
Current Time: Fri Jul 18 21:56:38 EDT 2025
Powered by FUDForum. Page generated in 0.07592 seconds
