Home » Archived » Maven Integration (M2E) » How to install Maven-Nar plugin?
How to install Maven-Nar plugin? [message #557532] Tue, 07 September 2010 21:50 Go to next message
Folks,
I am new to Eclipse development environment. I am trying to understand how to add nar plugin for JNI development that is available at http://duns.github.com/maven-nar-plugin/index.html#nar-downl oad.
If I go into "Available Software" and add http://mojo.codehaus.org as a site, I get an error that "No software site found at http://mojo.codehaus.org."
Thank you in advance for your help.
Peter
Re: How to install Maven-Nar plugin? [message #629011 is a reply to message #557532] Sat, 25 September 2010 19:27 Go to previous messageGo to next message
I had the same problem.
the maven-eclipse plugin is at
http://m2eclipse.sonatype.org/sites/m2e
which will do about 1/2 the job; don't know if that helps.
[Updated on: Sat, 25 September 2010 19:38] by Moderator
Re: How to install Maven-Nar plugin? [message #635562 is a reply to message #629011] Wed, 27 October 2010 06:58 Go to previous message
hello there
I am new to Eclipse Helios. I am trying to understand how to add maven that is available at http://m2eclipse.sonatype.org/sites/m2e
I pasted the link at "install new software" install, got the following software "Maven Integration for Eclipse (Required) 0.10.2.20100623-1649". At this level, it seemed that all dependencies were found but it shows the following error message while installing & fetching the software.
Cannot complete the install because one or more required items could not be found.
Software currently installed: Maven Integration for Eclipse (Required) 0.10.2.20100623-1649 (org.maven.ide.eclipse.feature.feature.group 0.10.2.20100623-1649)
Missing requirement: Java EMF Model Utilities 2.0.2.v200802192030 (org.eclipse.jem.util 2.0.2.v200802192030) requires 'bundle com.ibm.icu [3.4.4.1,4.0.0)' but it could not be found
Cannot satisfy dependency:
From: EMF Utilities 1.1.104.v200709131115 (org.eclipse.wst.common.emf 1.1.104.v200709131115)
To: bundle org.eclipse.jem.util [2.0.0,3.0.0)
From: Maven Integration for Eclipse 0.10.2.20100623-1649 (org.maven.ide.eclipse 0.10.2.20100623-1649)
To: bundle org.eclipse.wst.common.emf 0.0.0
From: Maven Integration for Eclipse (Required) 0.10.2.20100623-1649 (org.maven.ide.eclipse.feature.feature.group 0.10.2.20100623-1649)
To: org.maven.ide.eclipse [0.10.2.20100623-1649]
Thanks in advance
Previous Topic:Unable to package project
Next Topic:can't install m2eclipse on Helios
Current Time: Fri Jul 18 08:20:22 EDT 2025
Powered by FUDForum. Page generated in 0.04829 seconds
