Home » Language IDEs » ServerTools (WTP) » Pretty print xml
Pretty print xml [message #635523] Wed, 27 October 2010 04:16 Go to next message
I'm building Eclipse plugin that uses StructuredTextEditor
In Structured Text Editor there is Formatting functionality. Could you tell me how to invoke it from code?
I'm adding elements to xml document via DocumentBuilder and it's not formatted in source editor then. I don't want to format it manually because there is such functionality in WTP.
Thank you for your help!
Re: Pretty print xml [message #636033 is a reply to message #635523] Fri, 29 October 2010 02:18 Go to previous message
You can try using org.eclipse.wst.xml.core.internal.provisional.format.FormatP rocessorXML and format the model .This will format based on the preferences. You can also override the preference before formatting.
Previous Topic:Why my Helios is so slow
Next Topic:tomcat 5.5 is not listed in the new server wizard.
Current Time: Fri Jul 18 17:08:43 EDT 2025
Powered by FUDForum. Page generated in 0.12778 seconds
