Home » Archived » BIRT » Change an image properties before the report generation
Change an image properties before the report generation [message #635451] Tue, 26 October 2010 16:24 Go to next message
I am generating a report using Report Engine classes and I would like to change the url of an image inserted in the report using BIRT Report Designer.
Is it possible to access this item and change its properties before the generation?
this is a sample of my code :
IReportEngine engine = null;
engine = Engine.getInstance().getEngine();
IReportRunnable design = null;
// Open the report design
try {
    design = engine.openReportDesign(report.getSource());
} catch (EngineException e) {
        LoggerBI.getInstance().fatal("", e);
        return false;
IRunAndRenderTask runtask = engine.createRunAndRenderTask(design);
ULocale lc = new ULocale(task.getLocale());
runtask.setLocale(lc);
runtask.setParameterValues(reportParams);
try {
     runtask.run();
     LoggerBI.getInstance().error("", e);
      return (false);
runtask.close();
Thanks!
Re: Change an image properties before the report generation [message #635691 is a reply to message #635451] Wed, 27 October 2010 13:51 Go to previous messageGo to next message
Yes this is possible. You can also change it in script.
In Java like this:
ReportDesignHandle report = (ReportDesignHandle) design.getDesignHandle( );
ImageHandle myimage =(ImageHandle)report.findElement("MyImage1");
myimage.setURL("\"http://tomcat.apache.org/images/tomcat.gif\"");
In the above example note that the image element has been named in the
general properties for the image.
in Script
//beforeFactory script
var img1 =reportContext.getDesignHandle().findElement("MyImage1");
img1.setURL("\"http://tomcat.apache.org/images/tomcat.gif\"");
Jason
On 10/26/2010 4:25 PM, FrenchGuy wrote:
> Designer.
> generation?
> try {
> return false;
> try {
> runtask.run();
> return (false);
> runtask.close();
> Thanks!
Re: Change an image properties before the report generation [message #635860 is a reply to message #635451] Thu, 28 October 2010 07:52 Go to previous message
Ok. Thanks!
I'll try this.
Previous Topic:Is it possible to change a grid in its grid event handler (java)
Next Topic:How to create powerpoint and excel exports?
Current Time: Sat Jul 19 00:04:12 EDT 2025
Powered by FUDForum. Page generated in 0.04167 seconds
