Home » Eclipse Projects » EclipseLink » Trouble converting SQL into JPQL with OUTER JOIN
Trouble converting SQL into JPQL with OUTER JOIN [message #634733] |
Fri, 22 October 2010 17:00  |
I'm using EclipseLink 2.1.1 on GlassFish 3.0.1. I'm having a hard time converting a SQL query into JPQL. The SQL works as expected. I guess the thing I'm struggling with is that I'm using a JoinTable on one of my objects that is not represented by an entity.
Below you will find my Entities that are involved in the SQL and the working SQL that returns the correct values.
Any help you can provide me with is greatly appreciated. Thank you for your effort.
Organization Entity:
@Entity
@Table(name = "Organization")
public class Organization implements Serializable {
@Id
@Column(name = "OrganizationId", nullable = false)
@GeneratedValue(strategy = GenerationType.IDENTITY)
private Integer id;
@Column(name = "Name", nullable = false, length = 128)
private String name;
@Column(name = "Level", nullable = false)
private int level;
@Column(name = "Alias", nullable = false, length = 50)
private String alias;
@JoinTable(name = "OrganizationAncestry",
joinColumns = {
@JoinColumn(name = "Ancestor", referencedColumnName = "OrganizationId", nullable = false)
inverseJoinColumns = {
@JoinColumn(name = "Descendent", referencedColumnName = "OrganizationId", nullable = false)
@ManyToMany(fetch = FetchType.EAGER)
private Collection<Organization> descendents;
@ManyToMany(mappedBy = "descendents", fetch = FetchType.EAGER)
private Collection<Organization> ancestors;
DocumentType entity:
@Entity
@Table(name = "DocumentType")
public class DocumentType implements Serializable {
@Id
@Column(name = "DocumentTypeID", nullable = false)
private Integer id;
@Column(name = "TypeName", nullable = false, length = 40)
@Column(name = "Alias", nullable = false, length = 40)
@Column(name = "Description", length = 256)
private String description;
@Column(name = "IsActive", nullable = false)
private boolean active;
@JoinColumn(name = "OrganizationID", referencedColumnName = "OrganizationID")
@ManyToOne(fetch = FetchType.LAZY)
private Organization organization;
My SQL:
SELECT
t1.*
FROM
DocumentType AS t1
JOIN
OrganizationAncestry AS t2
ON
t1.OrganizationId = t2.Ancestor
JOIN
Organization AS t3
ON
t3.OrganizationId = t2.Descendent
LEFT OUTER JOIN (
OrganizationAncestry AS t4
JOIN
Organization AS t5
ON
t4.Descendent = t5.OrganizationId
JOIN
DocumentType AS t6
ON
t5.OrganizationId = t6.OrganizationId
ON
t2.Ancestor = t4.Ancestor
AND
t4.Ancestor <> t4.Descendent
AND
t1.Alias = t6.Alias
WHERE
t1.IsActive = 1
AND
t3.Alias = 'IWT'
AND
t6.Alias IS NULL
[Updated on: Fri, 22 October 2010 18:37] by Moderator
Re: Trouble converting SQL into JPQL with OUTER JOIN [message #635156 is a reply to message #635092] |
Mon, 25 October 2010 15:21   |
I've implemented a closure table pattern in a few of our applications. It's worked out very well. We use this for an Organization structure to represent different business units within the company. I have the closure tables implemented and an adjacent table (PartyDocumentType) that references the PartyDocumentOrganization table. The intent is that Organizations can have different document types. DocumentTypes can be inherited from the parent Organization but can also be overridden at the child Organization. So the child Organization's DocumentType has priority over the parent.
The SQL statement returns all the DocumentTypes for a given Organization, including those defined in the parent Organizations, but excluding the duplicates found in the parent organizations (if any, based upon the DocumentType's Alias column).
I have entities defined for the Organization and the DocumentType but not the OrganizationAncestry as it is defined as a JoinTable.
I've provided the DDL for my tables, seed data to populate them and a sample SQL statement.
Thank you for the help...
Chris
DDL:
CREATE TABLE [dbo].[PartyDocumentOrganization] (
[PartyDocumentOrganizationId] int IDENTITY(1,1) NOT NULL,
[Level] int NOT NULL,
[Alias] varchar(50) NOT NULL,
[Name] varchar(128) NOT NULL,
[UUID] varchar(36) NOT NULL,
[WhenCreated] datetime NOT NULL CONSTRAINT [DF__PartyDocu__WhenC__26D2223A] DEFAULT (getdate()),
[WhenModified] datetime NOT NULL CONSTRAINT [DF__PartyDocu__WhenM__27C64673] DEFAULT (getdate()),
[ModifiedById] varchar(15) NOT NULL CONSTRAINT [DF__PartyDocu__Modif__28BA6AAC] DEFAULT (suser_sname()),
[Version] int NOT NULL CONSTRAINT [DF__PartyDocu__Versi__29AE8EE5] DEFAULT ((0)),
CONSTRAINT [PK__PartyDoc__40493131220D6D1D] PRIMARY KEY([PartyDocumentOrganizationId])
GO
CREATE TABLE [dbo].[PartyDocumentOrganizationAncestry] (
[Ancestor] int NOT NULL,
[Descendent] int NOT NULL,
CONSTRAINT [PK__PartyDoc__D7F327222E734402] PRIMARY KEY([Ancestor],[Descendent])
GO
ALTER TABLE [dbo].[PartyDocumentOrganizationAncestry]
ADD CONSTRAINT [rgnztnncstrDscndnt]
FOREIGN KEY([Descendent])
REFERENCES [dbo].[PartyDocumentOrganization]([PartyDocumentOrganizationId])
ON DELETE NO ACTION
ON UPDATE NO ACTION
GO
ADD CONSTRAINT [rgnztnncestryncstr]
FOREIGN KEY([Ancestor])
ON DELETE NO ACTION
ON UPDATE NO ACTION
GO
CREATE TABLE [dbo].[PartyDocumentType] (
[PartyDocumentTypeID] int IDENTITY(1,1) NOT NULL,
[TypeName] varchar(40) NOT NULL,
[Description] varchar(256) NULL,
[WhenCreated] datetime NOT NULL CONSTRAINT [DF_PartyDocumentType_WhenCreated] DEFAULT (getdate()),
[IsActive] bit NOT NULL CONSTRAINT [DF_PartyDocumentType_IsActive] DEFAULT ((1)),
[PartyDocumentOrganizationID] int NULL,
[Version] int NOT NULL CONSTRAINT [DF__PartyDocu__Versi__39E4F6AE] DEFAULT ((0)),
[Alias] nvarchar(225) NOT NULL CONSTRAINT [DF__PartyDocu__Alias__3AD91AE7] DEFAULT (''),
CONSTRAINT [PK_PartyDocumentType] PRIMARY KEY([PartyDocumentTypeID])
GO
ALTER TABLE [dbo].[PartyDocumentType]
ADD CONSTRAINT [fk_artyDocumentType_PartyDocumentOrganizationID]
FOREIGN KEY([PartyDocumentOrganizationID])
ON DELETE NO ACTION
ON UPDATE NO ACTION
GO
Seed Data:
INSERT IGNORE INTO [dbo].[PartyDocumentOrganization]([Level], [Alias], [Name], [UUID])
VALUES(1,'INTRAXINC','Intrax Inc','137B3E7D-4938-4746-8AB5-4F7EC834F4AB' )
GO
VALUES(2,'ICD','Intrax Career Development','1B912F25-538F-4CCC-AC46-40AD3D44A866' )
Go
VALUES(3,'IWT','Intrax Work Travel','D0440813-31C9-450E-903B-39754EB6CD27' )
GO
VALUES(3,'ICT','Intrax Career Training','F32C35C8-F29A-4B88-AFF9-278D1C96355B' )
GO
INSERT IGNORE INTO [dbo].[PartyDocumentOrganizationAncestry]([Ancestor], [Descendent])
VALUES(1,1)
GO
VALUES(1,2)
GO
VALUES(1,3)
GO
VALUES(1,4)
GO
VALUES(2,2)
GO
VALUES(2,3)
GO
VALUES(2,4)
GO
VALUES(3,3)
GO
VALUES(4,4)
GO
INSERT IGNORE INTO [dbo].[PartyDocumentType]([TypeName], [Description], [PartyDocumentOrganizationID], [Alias])
VALUES('Participant Eligibility Form','Participant Eligibility Form',3,'ParticipantEligibilityForm')
GO
VALUES('University Letter','University Letter',3,'UniversityLetter')
GO
VALUES('University Letter (Translation)','University Letter (Translation)',3,'UniversityLetterTranslation')
GO
VALUES('Other','Other',3,'Other')
GO
VALUES('Program Agreement','Program Agreement',3,'ProgramAgreement')
GO
VALUES('Other','Other',2,'Other')
GO
Current Time: Sat Jul 26 13:18:13 EDT 2025
Powered by FUDForum. Page generated in 0.06875 seconds
