EXCEPTION_ACCESS_VIOLATION is thrown when i opened 3d editor [message #635237] |
Tue, 26 October 2010 02:52  |
I'm working on Eclipse 3.5, GEF 3.5, LWJGL 2.2.1 and the latest GEF3D. When i opened test.G3D_graph, i got this error:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x69161860, pid=5192, tid=5132
# JRE version: 6.0_18-b07
# Java VM: Java HotSpot(TM) Client VM (16.0-b13 mixed mode windows-x86 )
# Problematic frame:
# C [atioglx2.dll+0x161860]
# An error report file with more information is saved as:
# E:\hxy\eclipse-SDK-3.5-win32_GEF3D\hs_err_pid5192.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Here is the part of hs_err_pid5192.log:
[error occurred during error reporting (printing native stack), id 0xc0000005]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.GL11.nglDrawArrays(IIIJ)V+0
j org.lwjgl.opengl.GL11.glDrawArrays(III)V+20
j org.eclipse.draw3d.graphics3d.lwjgl.font.LwjglVectorFont.ini tialize()V+924
j org.eclipse.draw3d.graphics3d.lwjgl.Graphics3DLwjgl.getVecto rFont(Lorg/eclipse/swt/graphics/Font;CCZ)Lorg/eclipse/draw3d /graphics3d/lwjgl/font/LwjglVectorFont;+51
j org.eclipse.draw3d.graphics3d.lwjgl.Graphics3DLwjgl.deactiva teGraphics2D()Lorg/eclipse/draw3d/graphics3d/RenderImage;+28 1
j org.eclipse.draw3d.Figure3DHelper.paintChildren2D(Lorg/eclip se/draw2d/Graphics;)V+219
j org.eclipse.draw3d.Figure3DHelper.paintChildren(Lorg/eclipse /draw2d/Graphics;)V+2
Re: EXCEPTION_ACCESS_VIOLATION is thrown when i opened 3d editor [message #635903 is a reply to message #635780] |
Thu, 28 October 2010 10:44  |
On 28.10.10 07:37, sunny wrote:
> Thank you very much. I replaced LWJGL 2.2.1 with 2.6 and the error still
> existed.
Hmm... did you adapt GEF3D (i.e. org.eclipse.draw3d.graphics3D and
org.eclipse.draw3d.lwjgl)? As far as I remember some adjustments have to
be made there, since some constant value have changed (our current
version is a terrible hack ;-) ). As discussed in the previous thread
(2Dfied editors do not work with ATI), other problems will occur if you
simply update LWJGL, such as
org.lwjgl.opengl.OpenGLException: Invalid enum (1280)
at org.lwjgl.opengl.Util.checkGLError(Util.java:54)
at org.lwjgl.opengl.GL11.glEnable(GL11.java:1032)
Actually, updating these constants (that is, rewrite GEF3D to not
directly use the integer values of LWJGL) is what I'm planning to do in
November.
Jens
FUDForum. Page generated in 0.04736 seconds
