Home » Modeling » EMF » Expression syntax for getEObject method
Expression syntax for getEObject method [message #632756] Thu, 14 October 2010 03:43 Go to next message
Originally posted by: templth.yahoo.fr
I wonder which syntax can be used within the parameter of the getEObject
method for the EMF Resource class. Is there a documentation somewhere
describing it?
Thanks very much for your answer!
Thierry
Re: Expression syntax for getEObject method [message #632932 is a reply to message #632756] Thu, 14 October 2010 13:22 Go to previous messageGo to next message
Thierry,
I think if you followed the Javadoc links to methods you'd learn the
syntax for the segments. Looking at ResourceImpl.getURIFragment
illustrates how a fragment path is constructed and
ResourceImpl.getEObject illustrates how it's interpreted.
Thierry Templier wrote:
> Hello,
> getEObject method for the EMF Resource class. Is there a documentation
> somewhere describing it?
> Thierry
Re: Expression syntax for getEObject method [message #634611 is a reply to message #632932] Fri, 22 October 2010 08:39 Go to previous messageGo to next message
Hello Ed,
I looked at documentations you gave me and here are what I understood...
The first level needs to be necessary empty since it corresponds to the
root node of the model. Then you need to explicitly specify complete
path within the model from the top to target node using feature name
with eventually conditions and index.
I use the following model for my sample expressions:
<uml:Model name="TestModel">
<packagedElement xmi:type="uml:Package" name="TestPackage">
<packagedElement xmi:type="uml:Class" name="TestClass"/>
</packagedElement>
</uml:Model>
For example to access the Class with name TestClass, I can use both syntax:
//@packagedElement.0/packagedElement.0
//@packageElement.0/packagedElement[name='TestClass']
//@packageElement[name='TestPackage]/packagedElement[name='T estClass']
Am I right? Is there other features regarding conditions in such
expressions (within [])? Moreover is it possible to specify an
expression to look for an element in the complete model without having
specified its complete path?
Thanks very much!
Thierry
> Thierry,
>> Hello,
>> Thierry
Re: Expression syntax for getEObject method [message #634679 is a reply to message #634611] Fri, 22 October 2010 13:35 Go to previous messageGo to next message
Thierry,
Comments below.
> Hello Ed,
> the root node of the model.
By default it's the index of the root object in Resource.getContents(),
e.g., /0, /1/, /2, but a resource can specialize this to be whatever it
decides is a good thing. It should always accept index-based reference
though. Also, an empty segment implies 0, which is why you see // so
often in full paths.
> Then you need to explicitly specify complete path within the model
> from the top to target node using feature name with eventually
> </packagedElement>
> </uml:Model>
> syntax:
> Am I right?
Yes, it's generally @<feature-name>[.<index-in-feature>]. If the
referenced object has a key, then a key test replaces the index. It
could be a multi-feature key. It's also possible to specialize this
syntax in the model, the way EModelElementImpl does.
> Is there other features regarding conditions in such expressions
> (within [])?
It should be of the form <attributeName>='<string-value>'.
> Moreover is it possible to specify an expression to look for an
> element in the complete model without having specified its complete path?
Yes, ResourceImpl.getEObject can do arbitrary things you implement by
hand, but should always support the default syntax.
> Thanks very much!
> Thierry
>> Thierry,
>>> Hello,
>>> documentation somewhere describing it?
>>> Thierry
Re: Expression syntax for getEObject method [message #635231 is a reply to message #634679] Tue, 26 October 2010 02:19 Go to previous message
Thanks very much, Ed, for these explanations!
Thierry
> Thierry,
> Comments below.
>> Hello Ed,
>> </packagedElement>
>> </uml:Model>
>> syntax:
>> Am I right?
>> (within [])?
>> Thanks very much!
>> Thierry
>>> Thierry,
>>>> Hello,
>>>> Thierry
Previous Topic:Update site for your EMF 2.7 milestone builds?
Next Topic:EMFCompare and compare with Repository
Current Time: Wed Jul 23 12:40:26 EDT 2025
Powered by FUDForum. Page generated in 0.05426 seconds
