| PDT 1.0.2 Milestone 1 is ready! [message #63259] | Tue, 18 December 2007 04:30  |  |
| Eclipse User  |  |  |  |  | Hi all,, Toward PDT 1.0.2 release in mid-January we released yesterday the first
 milesone version.
 Download is available from:
 http://download.eclipse.org/tools/pdt/downloads/?release=S20 071213-M1
 If you want also to have debug capabilities you should refer to:
 http://downloads.zend.com/pdt/all-in-one/
 and download Zend's PDT debugger included (version 1.0.2 of course).
 This release includes more than 100 bug fixes to PDT 1.0 release:
 201079	different behaviour by double clicking variables
 202742	Duplicate value within Hovers preferences
 203084	impossible to create file names with more than one dot
 203312	Copy&Paste of folders throws errors
 203785	New PHP file window does not have a title
 203904	Filename can't have special character
 205664	Unhandled event loop exception occurs using the Explorer view
 205691	An error is logged when a variable(in the include path) is edited
 205799	Opened a file outside the workspace if same name file exists
 206033	In the Navigate manu, we have twice the option Open PHP Element
 206253	Editing templates - tab key deletes multiple lines rather than
 indent
 206466	Missing content assist for "self"
 206997	[Content Type] Option to exclude .tpl from PHP validators
 207691	Removing an included variable from PHP explorer - nothing happens
 208688	[Code Completion] Built-in clas names should be case insensitive
 209216	Changing text encoding to UTF 16 - we see 'garbage'
 141268	There is no way to disable builders (Linux)
 199996	PHP Editor changes the current line highlight color
 202009	New php file cration dialog- does not allow creation of a
 xx.class.php file
 202884	Character check for new PHP file name too restrictive
 203984	Code Completion stopped working in 1.0
 204348	New PHP File Wizard rejects filenames w/ dashes
 205688	no output in the debug output and browser output views
 206265	Autocomplete should be "smarter "?
 209187	enddeclare is completed by the Code Assist with 2 semicolon
 203363	When PHP Explorer is minimized, Eclipse locks up after launch
 207098	Downloads page claims Eclipse ships w/ a JRE when this is patently
 untrue
 211954	Call members of members of an instance reports Syntax Error, but
 this code is valid
 193252	Debug URL Arguments
 201515	Xdebug - debugging against an Xdebug server - and clicking resume
 operation - debugger does not stop in breakpoints
 202147	xdebug causes the existence of 2 identical menu option
 202741	Not possible to debug a file that was opened from network using
 \\SERVER\etc
 203862	Xdebug does not respect breakpoints
 204525	Error in preferences when viewing PHP->PHP Extensions
 204986	Terminate debug session executes script a second time
 205018	Whitespace throws off debugger - lines highlighted and performed
 are different
 205654	Variables View is not refreshed after StepOver with Xdebug
 205754	PDT cannot find the correct php.ini
 208694	In debug/run configuration dialog - the server segment of the url
 should be disabled
 208695	path mapper is "confused" when using 2 similar filenames
 208696	Selection dialog of local resources is displayed - always/and even
 using local debugger
 209481	Error while adding a newly Core php exe
 210195	When ASP tags are on, always debugging as CLI
 210196	Debug as Web page config dialog - An additional slash is needed in
 the host url field
 210197	after adding a wrong "PHP web Page" URL  the read-only section of
 the URL is incorrect
 210198	Path Mapping suggestion pops-up 3 times for same file
 191457	Open Manual, case problem (example PDO required for pdo local file)
 153920	Quick Outline is missing
 163970	Astrisk mark is not removed even if we undo our editing
 201226	Filter Non public members return wrong results
 201656	Autocomplete not working for SPL Exception classes
 202415	Debugger mapping - when an extra directory is added to the project
 - breakpoints are ignored
 202829	Empty constructors in classes throw
 "java.lang.NullPointerException" and fail to open
 204034	null pointer on file open
 204520	CodeAssist does not suggest methods of classes
 204672	It crashes when opening a php file with the PHP Editor
 205946	Cannot create a PHP file with extra periods in the name, i.e.:
 MyClass.class.php
 206089	NPE when editing PHP files (with folding enabled)
 206474	Problems with New PHP File Dialog
 207705	Creating a IPHPRegion interface
 210852	Customized sorting causes incorrect completion
 141209	Code Folding: Bad symbols appears next to every line after
 formatting folded code.
 199960	Code folding indicator stays after unfolding code
 201724	exceptions are thrown during typing
 202360	Folding marker appears on unfoldable one-line block
 203677	zend php editor can not open certain file
 205704	Creating php file with PHP template unchecked - throws error in the
 log
 206245	creating an xhtml file - warnings are displayed (wst?)
 206294	Function descriptions (comments) can't be folded sometimes
 209768	Various issues with code and comment folding
 195600	The operation "undo" did not complete normally.
 198845	Error opening the editor on files with extensions other than .php
 200276	Source hovers don't work in catch statements
 202010	Status bar displays double return type for project outline
 202710	Unexpected unfolding
 202738	first time opening from outline after changing a file in filesystem
 --> log attached below
 203530	Class is show too often.
 203780	Creating new untitled PHP document puts the cursor in the wrong
 location
 204278	[website] Hard to find the all-in-one
 204383	Code folding does not work properly for single line class/function
 204434	Hint doesn't appear well when using code assist
 204474	Red error markers remain in the annotation bar after there are no
 more errors
 204827	Error occurs after closing a project
 205034	code completion after literal operator
 205692	An error is logged after deleting a file in project's include path
 206252	In the class body functi.. suggests function_exists()
 206572	[Code Assist] no code completion for variable variables class name
 207169	constructor of parent classes are ignored
 207562	Wrong behaviour when a folded block is copied/pasted
 207696	Closed PHP projects dont show up when excluding Non-PHP projects
 208038	Argument highlighting not working after $this->
 208042	Code completion for classes returns '__construct' (Nightly Build)
 209171	After formatting a file - I get error in the log
 209200	The value of class constants is not displayed in the description of
 the code assist
 209603	Restore Defaults does not apply for the Open PHP Manual in new
 browser window checkbox
 210148	N builds do not list dependencies
 210150	N builds point to update site on which they do not exist
 210211	[Folding] Should color text of folded block
 139478	"Installed PHP" Preferences section lacks setting location of
 php.ini file
 153820	It is not possible to enter command line arguments for php binary
 and for the script
 158906	Console is always allocated and not terminated
 204084	Enabling the "Use ASP tags as PHP tags" chekbox in the project
 preferences does not take effect.
 209923	PHP Executable table - Defaults are not saved
 210193	Script doesn't run - When adding php arguments in the run/debug
 configuration
 157456	PDO:: constants are not proposed by AutoComplete
 206121	Debugger does not stop at breakpoints on related PHP projects
 210194	Run/debug as php script - fails to include file when path starts
 with ../.
 203738	Adding PHP Doc from Outline view does not work for external files
 203998	NullPointerException when opening a file in a rse enabled folder
 207099	PDT Bugzilla Product does not include Components for Website or Wiki
 208342	Is there a PDT 1.1 Project Plan?
| Re: PDT 1.0.2 Milestone 1 is ready! [message #63514 is a reply to message #63259] | Wed, 19 December 2007 12:09   |  |
| Eclipse User  |  |  |  |  | Thanks very much for this, the debugging changes have helped quite a lot, and I am now reliably stopping at breakpoints with my remote Xdebug
 (though still failing to stop except in the first script when the remote
 debugger is Zend, but I'm not greedy, one debugger will do).
 Andras Janurik has already pointed out that the "Publish to Server"
 checkbox has disappeared, and I'm not clear whether this is an accident
 or part of a master plan that I haven't yet understood.
 To this end, I'm sure it's blindly obvious to the designers, but I'd
 appreciate a simple example of how the new relationships are >supposed<
 to be used, (which I don't think is yet documented?), quite possibly not
 the way I found by experimentation. For example, let's say I have:
 - a local project in %MY_WORKSPACE%\ProjectName
 - a publish target of %XAMPP_HOME%\htdocs\SomeStuff\ProjectName
 - a corresponding URL of http://localhost/SomeStuff/ProjectName
 what would be the standard way to configure the PHP Server parameters?
 Is it ever right to configure the Server URL ("the URL that points to
 the document root of this server") to include "SomeStuff", as some
 people have suggested, or must it be set to the server's actual document
 root? What would be the right way to configure the Path Mapping, and can
 I get the project to be published out to the server like I used to?
| Re: PDT 1.0.2 Milestone 1 is ready! [message #64715 is a reply to message #63813] | Fri, 18 January 2008 20:55  |  |
| Eclipse User  |  |  |  |  | Originally posted by: sal.sal.com
 did you ever get it working? with debug too?
 "Caroline Maynard" <cem@php.net> ha scritto nel messaggio
 news:fkmlfq$7bb$1@build.eclipse.org...
 > Siamak Sarmady wrote:
 >> Hello,
 >> I also had proposed the exact thing you are asking for. It is the most
 >> logical method coming to mind.
 >> I have an "eclipse" folder in my web root and I need all my projects be
 >> published to it and then I can browse them using the URL
 >> http://localhost/eclipse/projectname.
 >> In PDT 1.0 I was not able to do it, so I was forced to forget publishing
 >> and just create the project itself inside the web root (which I do not
 >> like in any way).
 > Thanks for your support - to reiterate, I am not proposing anything. I am
 > requesting clarification as to how I am suppose to configure PDT, and I'm
 > hoping that a PDT developer in this area will give me a definitive
 > response.
 > Though if the response is "Sorry we don't support publishing out to a
 > server any more, you'll need to create a new project inside the document
 > root", I must admit I shall be rather disappointed.
FUDForum. Page generated in 0.03870 seconds
