Home » Eclipse Projects » Plugin Development Environment (PDE) » Question about using plug-in fragments
Question about using plug-in fragments [message #634755] Sat, 23 October 2010 02:05 Go to next message
I use plug-in fragments for interface implementations. I have a plug-in defining a public API with interfaces, and a fragment that implements these interfaces. Instances are created using Java reflection.
What I need is to provide a fragment to the users that contains a simple implementation first. Later, I have to implement my interfaces by another way, so I'd create another fragment. Then, I need to exchange the fragments using the Eclipse Update Mechanism.
And there's my question: Is it possible to provide an Update Site with a feature that instructs the platform to uninstall the old fragment and to install the new one? (If so, how? If not, what should I do instead?)
I cannot have both fragments in the same platform because of classloader issues.
Thanks!
Re: Question about using plug-in fragments [message #634939 is a reply to message #634755] Mon, 25 October 2010 03:44 Go to previous message
I think that using versionning of fragments can do the trick. Simply create an update site containing your fragment in a higher version, and once installed, this one should be used by your host bundle.
Le 23/10/2010 08:05, Ralf Zahn a écrit :
> issues.
> Thanks!
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/BPM_download.php
Previous Topic:Splash screen doesn't appear in the exported product
Next Topic:OSGi debug - updating saved resources and refreshing bundles
Current Time: Sun Jul 27 01:51:10 EDT 2025
Powered by FUDForum. Page generated in 0.32323 seconds
