Home » Eclipse Projects » Virgo » [SOLVED] java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper(Error while trying to add a MappingJacksonHttpMessageConverter to s spring MVC osgi webapp)
| [SOLVED] java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper [message #634843] |
Sun, 24 October 2010 10:44  |
Hi all,
I'm facing a problem with an osgi webapp in Virgo (got same error in spring DM server).
I had a spring MVC webapp running withtout problem, serving jsp. I wanted to add ajax capabitlies so i created a controller with a service method annotated with @ResponseBody to write directly into the response.
I'm trying to return java beans to the client as json using MappingJacksonHttpMessageConverter.
The webbundle is correctly installed, but trying to hit the application fails with a server error :
root cause
org.springframework.http.converter.json.MappingJacksonHttpMessageConverter.<init>(MappingJacksonHttpMessageConverter.java:55)
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
java.lang.reflect.Constructor.newInstance(Constructor.java:513)
org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:126)
Here is my application definition. First the controller method :
@RequestMapping(value="/connect.do", method=RequestMethod.POST)
public @ResponseBody ConnectionBean connect(@RequestParam String login, @RequestParam String password) {
return new ConnectionBean(); // No real work here, it's just to send back something to be converted as json
Here's the pom part where i reference those needed jars :
<dependency>
<groupId>org.codehaus.jackson</groupId>
<artifactId>com.springsource.org.codehaus.jackson.mapper</artifactId>
<version>1.4.3</version>
</dependency>
<dependency>
<artifactId>com.springsource.org.codehaus.jackson</artifactId>
</dependency>
I started to declare them with the provided scope but removed it ton include them in the war's lib folder, but it didn't help.
The MANIFEST.MF part importing the needed dependencies:
Import-Bundle: com.springsource.org.codehaus.jackson.mapper;version="[1.4.3, 1.4.3]"
Import-Package: org.eclipse.virgo.web.dm;version="[2.0.0, 3.0.0)",
javax.servlet;version="[2.5, 2.5]",javax.servlet.http;version="[2.5, 2.5]",
javax.servlet.jsp.jstl.core;vers ion="[1.1.2,1.2.0)",org.phoenix.bundles.ssh.service;version="[1.0.0,
1.0.0]",org.phoenix.bundles.svn.service;version="[1.0.0, 1.0.0]",org.
springframework.beans.factory.annotation;version="[3.0, 3.1)",org.spr
ingframework.stereotype;version="[3.0, 3.1)",org.springframework.web.
bind.annotation;version="[3.0, 3.1)",org.springframework.web.context;
version="[3.0, 3.1)",org.springframework.web.servlet;version="[3.0, 3
.1)",org.springframework.web.servlet.mvc.annotation;version="[3.0, 3.
1)",org.springframework.web.servlet.view;version="[3.0, 3.1)"
Excluded-Imports:
org.springframework.test.*,
org.junit.*
And then my webapp-servlet.xml definitiion :
<context:component-scan base-package="myapp.controllers" />
<mvc:annotation-driven/>
<bean id="viewResolver" class="org.springframework.web.servlet.view.UrlBasedViewResolver">
<property name="viewClass" value="org.springframework.web.servlet.view.JstlView" />
<property name="prefix" value="/WEB-INF/jsp/" />
<property name="suffix" value=".jsp" />
</bean>
<bean id="messageAdapter" class="org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter">
<property name="messageConverters">
<util:list>
<bean class="org.springframework.http.converter.StringHttpMessageConverter"/>
<!-- bean class="org.springframework.http.converter.ByteArrayHttpMessageConverter"/>
<bean class="org.springframework.http.converter.xml.SourceHttpMessageConverter"/>
<bean class="org.springframework.http.converter.FormHttpMessageConverter"/-->
<!-- Below the offending resource causing error while initializing spring context -->
<bean class="org.springframework.http.converter.json.MappingJacksonHttpMessageConverter"/>
</util:list>
</property>
</bean>
I'm quite tuck on this, and would appreciate any input on this. Thanks !
[Updated on: Mon, 25 October 2010 07:25] by Moderator
| Re: java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper [message #634962 is a reply to message #634960] |
Mon, 25 October 2010 05:19   |
I didn't see in the log, in fact it was a good idea to try to put bunldes in the usr dir, as the error shows a userregion classloader error.
com.springsource.kernel.osgi.framework.ExtendedClassNotFoundException: org.codehaus.jackson.map.ObjectMapper in KernelBundleClassLoader: [bundle=org.springframework.web_3.0.0.RELEASE]
com.springsource.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:149)
java.lang.ClassLoader.loadClass(ClassLoader.java:248)
But now that my jackson bundles are there, why am i keeping getting this error ?
Oh and another thing, i don't see jackson bundles appear in the server starting trace, but they seem to be here, as my webapp bundle is successfully installed and imports the packages from jackson bundles...
EDIT : FYI, i was using virgo at home and now i was on dmServer, byt in the meantime i installed virgo here and adapted my webapp to use eclipse packages. I put jackson, joda, and two other bundles in virgo repository/usr directory and started with -clean (even it was virgo first start here on this machine). Same error :
org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: org.codehaus.jackson.map.ObjectMapper in KernelBundleClassLoader: [bundle=org.springframework.web_3.0.0.RELEASE]
org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:139)
[Updated on: Mon, 25 October 2010 05:34] by Moderator
| Re: java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper [message #634997 is a reply to message #634962] |
Mon, 25 October 2010 07:24   |
Ok i finally figured this out.
Actually i should have done this a long time ago.
I tried to get some info through the osgi console. Went into the config/.....userregion.properties config file and uncommented the osgi.console=2401 line
Then i connected to it via telnet localhost 2401
The basic osgi commands didn't help a lot but virgo set of commands are quite useful. I used vsh bundle list to see my bundles and saw both org.springframework.web_3.0.0.RELEASE and my jackson 1.4.3 bundles.
But when i used vsh bundle examine on org.springframework.web_3.0.0.RELEASE, i didn't see jackson in the list of imported packages.
I decided then to unjar the org.springframework.web_3.0.0.RELEASE bundle and had a look at its MANIFEST.MF.
As expected (well as you said, Glyn), i found some jackson packages imports, with an optional resolution, but what shocked me (spent a lot of time on this...) was the version range....
it was expecting ranges in [1.0.0, 1.1.0)....and i was providing version 1.4.3.
Full of hope, i went to springsource enterprise bundle repository and downloaded the 1.0.0 version of both jackson core and jackson mapper, removed the 1.4.3 fron repository/usr, put the 1.0.0 in repository/usr and restarted.
Launched my webapp and....bingo ! It works ! (Well i have a 406 HTTP error now when trying to reach the ajax powered controller, but that's another story, the webb app has been launched )
So thanks for your help Glyn, as your optional dependency advice helped me to look in the right direction.
EDIT: just for information. The 406 HTTP error "not acceptable" went away. If <mvc:annotation-config/> is in the servlet config file, and you use @ResponseBody expecing jackson mapper to convert your pojos into json format, then your client must send the request with the following header : "Accept: application/json"
Btw, no need to declare the jackson converter as i did in my first post. The <mvc:annotation-config/> is all it takes to allow jackson mapper to kick in when a json request is received.
[Updated on: Mon, 25 October 2010 08:31] by Moderator
Current Time: Sat Nov 08 09:56:36 EST 2025
Powered by FUDForum. Page generated in 0.04028 seconds
