Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » XSD To ECore to XML(Genrating XML file from XSD by using ECore)
XSD To ECore to XML [message #634650] Fri, 22 October 2010 11:20 Go to next message
Dear reader,
I'm trying to generate an XML File from it's XSD by using it's associated ecore file but without generating the pojos.
I started by loading the ecore file and then by using ModelDataGenerator I produced my List<EObject>.
Then I wanted to convert this list by using :
EMFModelConverter emfModelConverter = new EMFModelConverter();
List<Object> lo = emfModelConverter.convert(leo);
In order to have the possibility to convert my list of Object by using an ModelXMLSaver.
The trouble is that since I haven't generated the pojos associated to my model there is no ModelPackage registered and then I get an error on the EMFModelConvertion.
Please can you help or give me some advice ... Is there some other way to get a generated XML file from its XSD ? Is it possible to get a dynamic PackageModel in order to register it and having the emfModelConvertion working ...
Thanks in advance for you comments.
[Updated on: Fri, 22 October 2010 11:37] by Moderator
Re: XSD To ECore to XML [message #634658 is a reply to message #634650] Fri, 22 October 2010 11:45 Go to previous messageGo to next message
Hi Jean,
Instead of converting to Texo objects you can also directly store the EObjects in a xml file, try something like this:
Resource res = new XMLResourceImpl(URI.createFileURI("/tmp/test.xml");
res.getContents().addAll(eObjects);
res.save(optionsHashMap);
gr. Martin
On 10/22/2010 05:20 PM, Jean Duracel wrote:
> Dear reader,
> associated ecore file but wihtout generating the pojos.
> an ModelXMLSaver.
> EMFModelConvertion.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: XSD To ECore to XML [message #634667 is a reply to message #634658] Fri, 22 October 2010 12:13 Go to previous messageGo to next message
Hi Martin,
I did that but the result is a little disapointing :
The XSD file was :
<xsd:element name="OrderCancelled" type="OrderCancelled"/>
<xsd:complexType name="OrderCancelled">
<xsd:sequence>
<xsd:element name="justification" type="xsd:string" minOccurs="1" maxOccurs="1"/>
</xsd:sequence>
</xsd:complexType>
And I obtain this :
<?xml version="1.0" encoding="ASCII"?>
<OrderCancelled:DocumentRoot xmlns:OrderCancelled=" file:///C:/apps/java/eclipse/bdd_workspace/EcoreXSD/xsd/Orde rCancelled.xsd">
<orderCancelled justification="String16"/>
String1</OrderCancelled:DocumentRoot>
The ecore file contains :
<eClassifiers xsi:type="ecore:EClass" name="OrderCancelled">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="OrderCancelled"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="justification" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
<details key="kind" value="element"/>
<details key="name" value="justification"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eStructuralFeatures>
</eClassifiers>
Wy is the justification seen as an attribute ? Why did I get a string1 contain ?
Is it due to the fact that I don't use the texo conversion ?
Any idea ?
Thanks in advance.
Jean
Re: XSD To ECore to XML [message #634700 is a reply to message #634667] Fri, 22 October 2010 14:15 Go to previous messageGo to next message
Jean,
Use the generated resource factory to create the resource (or configure
it the way the factory does).
Jean Duracel wrote:
> Hi Martin,
> The XSD file was :
> <xsd:sequence>
> maxOccurs="1"/>
> </xsd:sequence>
> </xsd:complexType>
> And I obtain this :
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> contain ?
> Any idea ?
> Thanks in advance.
> Jean
Re: XSD To ECore to XML [message #634777 is a reply to message #634700] Sat, 23 October 2010 08:30 Go to previous message
Hi Jean,
My initial answer was too short, as Ed says it is better to use the XMLResourceFactoryImpl to create a XML resource.
Resource res = new XMLResourceFactoryImpl().createResource(URI.createFileURI("/tmp/my.xml "));
gr. Martin
Previous Topic:how to load an XML-Instance into Ecore and access its attribute values
Next Topic:Multiple tabs inside an editor
Current Time: Thu Jul 24 23:18:07 EDT 2025
Powered by FUDForum. Page generated in 0.11036 seconds
