PDE Headless build migration to Helios problems. [message #634242] |
Wed, 20 October 2010 18:27  |
Hi all,
I have successfully been using every version of the PDE headless build
since eclipse 3.4. Today I migrated to helios from 3.5.2 to 3.6.1 and I
can not build my feature based RCP product anymore.
I extracted the delta pack into the eclipse folder itself as usual, but
I have this error (I am building from a Linux box)
BUILD FAILED
[java]
/eclipse_target/plugins/org.eclipse.pde.build_3.6.1.R36x_v20 100823/scripts/productBuild/productBuild.xml:39:
The following error occurred while executing this line:
[java]
/eclipse_target/plugins/org.eclipse.pde.build_3.6.1.R36x_v20 100823/scripts/productBuild/productBuild.xml:69:
Unable to find plug-in:
org.eclipse.equinox.launcher.win32.win32.x86_0.0.0. Please check the
error log for more details.
If I change the config parameter to build only for my platform "configs
= linux, gtk, x86" Then I have this error :
[java] BUILD FAILED
[java] ........
[java] java.io.FileNotFoundException:
/build/compile.org.eclipse.pde.build.container.feature.xml (No such file
or directory)
I have some files in the build folder :
compile.org.eclipse.pde.build.container.feature.all.xml and
compile.org.eclipse.pde.build.container.feature.linux.gtk.x8 6.xml
I didn't change anything to my build.properties file and it was building
before.. I spent few hours trying new things and looking if something
had changed in Helios without any success.
Any Ideas ?
Thanks.
Laurent Marchal.
Re: PDE Headless build migration to Helios problems. [message #634717 is a reply to message #634461] |
Fri, 22 October 2010 16:07  |
Found the second problem : my delta pack zip was corrupted...
Le 10/21/2010 02:26 PM, Laurent Marchal a écrit :
> I found one solution for the java.io.FileNotFoundException
> I had "topLevelElementId" defined in my build.properties file.
> and the documentation says
> "The id of the feature being built.
> This property is new in 3.4 and depends on the use of the 3.4
> allElements.xml file. Build configurations using older style
> customTargets.xml and/or allElements.xml files should not use this
> property."
> But I still have problems with the delta pack.. Specified with
> "pluginPath" or extracted over the eclipse folder I still have
> Le 10/20/2010 05:27 PM, Laurent Marchal a écrit :
>> Hi all,
>> BUILD FAILED
>> [java]
>> [java]
>> [java] BUILD FAILED
>> [java] ........
>> or directory)
>> Any Ideas ?
>> Thanks.
>> Laurent Marchal.
FUDForum. Page generated in 0.03492 seconds
