Home » Eclipse Projects » Rich Client Platform (RCP) » Table Double Click another view has to Change
Table Double Click another view has to Change [message #634534] Fri, 22 October 2010 02:57 Go to next message
Can any one tell how to implemnt :
When user Double Click the TableViewer in one View (Source view)
another view shld update based the on Source View only on double Click
Ashok
Re: Table Double Click another view has to Change [message #634612 is a reply to message #634534] Fri, 22 October 2010 08:42 Go to previous messageGo to next message
you'll have to supply a double click listener (there's an add in the API).
You'll have to wire up the views yourself. You can find other open
views from the getSite().getPage()
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Table Double Click another view has to Change [message #634614 is a reply to message #634612] Fri, 22 October 2010 08:40 Go to previous messageGo to next message
Another convenient method is to attach an IOpenListener which also
reacts when pressing the Carriage Return on an item.
Tom
Am 22.10.10 14:42, schrieb Paul Webster:
> PW
Re: Table Double Click another view has to Change [message #634703 is a reply to message #634534] Fri, 22 October 2010 15:06 Go to previous messageGo to next message
Can one give me the code snipphet plz
Re: Table Double Click another view has to Change [message #635020 is a reply to message #634703] Mon, 25 October 2010 08:31 Go to previous message
No, but you can read the javadoc for your viewer (find the double-click
listener and IOpenListener) and also read the API/javadoc for
IWorkbenchPage to find your view.
PW
Paul Webster
Previous Topic:Eclipse RCP
Next Topic:GradLayout set first two columns equal width to last two columns
Current Time: Sun Aug 31 06:14:47 EDT 2025
Powered by FUDForum. Page generated in 0.03976 seconds
