Home » Modeling » OCL » OCL standard library
OCL standard library [message #63458] Tue, 28 October 2008 12:40 Go to next message
--------------010406090106050308090808
I'm trying to use OCL in a standalone way and since I've had the problem
I was wondering wether there is a way to register the standard library
without accessing discouraged classes. What I have donne for now :
resourceSet.getPackageRegistry().put("http://www.eclipse.org/ocl/1.1.0/oclstdlib.ecore",
OCLStandardLibraryImpl.stdlibPackage);
This doesn't strike me as good programming : I couldn't access the
Standard library's NS URI + I couldn't access an instance of it. Did you
design any better way of doing this?
Laurent Goubet
Obeo
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr/">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------010406090106050308090808--
Re: OCL standard library [message #63482 is a reply to message #63458] Tue, 28 October 2008 13:15 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Laurent,
I use URI mappings for this purpose. This is from the
orge.eclipse.ocl.standalone.tests.AllTests class, which I use for
running the OCL test suites in an Eclipse-free environment:
uriMap.put(
URI.createURI("http://www.eclipse.org/ocl/1.1.0/oclstdlib.ecore"),
URI.createURI(PLATFORM_PLUGIN +
"org.eclipse.ocl.ecore/model/oclstdlib.ecore"));
uriMap.put(
URI.createURI("http://www.eclipse.org/ocl/1.1.0/oclstdlib.uml"),
"org.eclipse.ocl.uml/model/oclstdlib.uml"));
You may find other handy set-up tips in there, besides.
HTH,
Christian
laurent Goubet wrote:
> Laurent Goubet
> Obeo
Re: OCL standard library [message #63550 is a reply to message #63482] Wed, 29 October 2008 05:15 Go to previous messageGo to next message
--------------070005050805040403010008
Thanks Christian, I had forgotten these standalone tests :(.
Laurent Goubet
Obeo
Christian W. Damus a
Re: OCL standard library [message #63573 is a reply to message #63550] Wed, 29 October 2008 06:08 Go to previous messageGo to next message
--------------060902090300070908030308
Christian,
using URIMaps as you hined towards did the trick, yet I'd still like to
be able to get both the standard library NsURI and the OCLEcore plugin
id without hard-coded Strings or discouraged accesses.
Something like this
resourceSet.getURIConverter().getURIMap().put(URI.createURI( "http://www.eclipse.org/ocl/1.1.0/oclstdlib.ecore"),
URI.createURI(Platform.getBundle(OCLEcorePlugin.getPluginId( )).getEntry( "/model/oclstdlib.ecore").toString()));
presents both the need of no hard-coded String (the NsURI of the
standard library could evolve) and the discouraged access
(org.eclipse.ocl.ecore plugin ID cannot be accessed without it).
There may be things in OCLEcorePlugin that you don't want as API, but I
think providing access to these Strings would really be helpful (for
now, I'll stick with the discouraged access).
Laurent Goubet
Obeo
laurent Goubet a
Re: OCL standard library [message #63595 is a reply to message #63573] Wed, 29 October 2008 10:49 Go to previous messageGo to next message
Hi, Laurent,
You're quite right. These stdlib URIs should be available in the
EcoreEnvironment and UMLEnvironment classes.
Would you mind raising an enhancement request?
Christian
> Christian,
> Something like this
> Laurent Goubet
> Obeo
>> Laurent Goubet
>> Obeo
>> Christian W. Damus a écrit :
>>> Hi, Laurent,
>>> uriMap.put(
>>> uriMap.put(
>>> HTH,
>>> Christian
>>>> Hi,
>>>> problem I was wondering wether there is a way to register the
>>>> standard library without accessing discouraged classes. What I have
>>>> donne for now :
>>>> you design any better way of doing this?
>>>> Laurent Goubet
>>>> Obeo
Re: OCL standard library [message #63618 is a reply to message #63595] Wed, 29 October 2008 11:08 Go to previous message
--------------000306010409070405080909
Done with bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=252600 .
Thanks for your answers so far :).
Laurent Goubet
Obeo
Previous Topic:Validation menu option and OCL on UML
Next Topic:Importing Rose Model with OCL Constraints?
Current Time: Thu Sep 04 01:53:57 EDT 2025
Powered by FUDForum. Page generated in 0.07923 seconds
