Home » Modeling » Graphiti » filled ellipse renders with small gap
filled ellipse renders with small gap [message #634573] Fri, 22 October 2010 05:22 Go to next message
--------------050903000206000300070406
Content-Type: text/plain; charset=ISO-8859-15
in attached figure the inner GA is a filled ellipse:
Ellipse inset = gaService.createEllipse(invisibleRectangle);
inset.setForeground(manageColor(fill));
inset.setBackground(manageColor(fill));
inset.setLineWidth(LINE_WIDTH);
gaService.setLocationAndSize(inset, 3*size/4, 3*size/4, size/2, size/2);
The rendering leaves a little gap of background color on the upper left
part.
setting the ellipse filled
inset.setFilled(true);
doesn't change the behavior.
I assume, this is a bug?
Henrik
Content-Type: image/gif;
name="filledEllipse.gif"
filename="filledEllipse.gif"
R0lGODlh0ACxAPcAAAQCBISGhERCRCQiJMTGxGRiZBQSFKSmpFRSVDQyNOTm 5HRydAwKDJSW
lExKTCwqLNTW1BwaHLS2tFxaXDw6PPT29Hx6fAQGBIyOjERGRCQmJMzOzGxq bBQWFKyurFRW
VDQ2NOzu7AwODJyenExOTCwuLNze3BweHLy+vFxeXDw+PPz+/Hx+fJ8A6AAA GBAAAJgAVaIA
AbgAnAUAdlD/XwH/4iYAMAABgYgA/uAA/8IA/wUA/wB4AQADaSYAmgAAdihM GoPnzbsBmgUB
dgBEAADmAAAYAAAAAAIwkACDiAC7RgIFAFBEqAH7BCYYKAAAAJjdEYYDAbuM AAV3AHgMALtf
ADLHAAAAA8T+6gD/CSb/AwD/ABA6SAAuBACIpgB3AAAyAQAqACaIAAB3AAAA Q4AAOgAAXAAA
VSj1c4O/ZbsWcgV3cyQAO+cBwRgAFgAAd14AHC4A44gAs3cA9zhwAAHnACYY AAAAADpvAC5g
AIiIAHd3AJh0kH5gFliIKnd3AADMAAB+EABYKgB3AAAAOAAA6CYAGAAAADAA d4MBabsAYwUA
awD1lAC/6AAWGAB3AABIuwDnPwAYHgAAdwD1OAC/ygAWvQB3gHxE/gH7/yYY /wAA/wDdOwAD
wQCMFgB3d1CkeQFUwSbHFgAAd/D+kH7/FsD/KgX/AFCA8wHnoiYYFQAAd4he 3OAa48IUswV3
9wACAAAAACYAAAAAAFAAAAEBACYAAAAAAFWYAADnAAAYAAAAAAAycAC/cgAW bwB3dFA0AQEA
ACYAAADAAAJddADp6AAYGAIAAKgMdQKhaQBPXAAAaXFaRAAA+wAAGHEAAG/A uwDoPwAYHgAA
dw7GgAC/qQAWvgB3gDxw/ue9/xhP/wAA/wOc8wDIogBPFQAAdww0iF8AgccA QgDAAG+8kADn
FgAYKgAAAHEAAAABAAAAAAAAADLnXSq/6YgWGHd3AD4Bi+YAvwgAFtAAd28A uAAA4wAAswAA
94gIi+Dqv8IYFgUAd/guav1nccVpSAVmACH5BAAAAAAALAAAAADQALEABwj/ AFcIHEiwoMGD
CBMqXMiwocOHECNKnEixosWLGDNq3Mixo8ePIEOKHEmypMmTKFOqXMmypcuX MGO+BECzps2b
OHPq3Mmzp8+fQIMKHZoTJtGjSJMqXcr0p9GmUKNKncr0KdWrWLNitaq1q9ev QbmCHUt2rNiy
aNNOPau2rdujbAHInLtSZ1y6eE/anVk0r1+Re10G/kuY42CWhwsrtphYZePF kCE+Rjk5smWF
lU1mvsyZ4GaSnztzDg24r+jTB0mHVI1aMeuPr1v/jd2Rtmy8tjfmvi1zd0bf vPnivBscNfCL
x4vXNd0yufKUzilGf66ZOWLr1CFPl7g9e+nhwm96/7/cXTL28YTLP1SP3vB5 6O/b446vl778
3vZLsr+PcT9D//xVBCBm+QXYXIEjDWhgRAoi1OCCDj1okIQQLkShZwjKFAIK DbCgwocgfrgA
BigoQF6Gq6HYEgocnCBUBykcUMFiFw5U40IhHPCBCEuR0IAJ6akIm5AlbfAB VSB44NeNKzBZ
kAJHZqUCCvOBJxiRIIXAwQVfkQDBXEw6GQILPJJVgInEXWllSyZooJYBVIZn U5osoWDAiyV8
4EAKIJTgZwkkqFCCi0Fd0ICcNdGp0ghc/jRABiAEdcIAQS2gpniI0tTSAj8l QMIDSXVAqU8Z
hHDdmqdimlIIJPikAQKNMv/VgU8PAOkYlu6hapIDPXVAQplRXTArTyeYCp+u tyI7Egc8XfDB
sFcxEGtOKiSr6oHKhtQATyIg8BWwORVw7LWpznkSCtPe5OdY4OJ0aH3Zwkuu SCbcqZMAhI6V
rk0XxKkfrroBDFEIbuqUwb5viYAmaAL/1rBDnOqkAsJvAUBCdfFiPO9HClD8 QL5qUQzABv9m
XPLGHkWMUwcJVAwAxSWcbO6lM4e0AcIXtOryyzpJwLDJP6PMkbc5RbnzTjEn +DBySye0gU4d
QHu0ThgoDbTVQmvEa9FT9zpjild/lzVGCuj0gMhd00SA2DWXm2hII+ikc9o7 ccD22zTj/dHc
NlH/gDbdA9ytaaZyhYRwBnT7RDJIYTZtkAQ6jZr4TgGAPbbMendUQE4lTN4T CJa3vVzYEkld
E+Ke87RwbY5L1/pAEOgUaeo7KTkk6Yy/LpAHOYFMO05V33550KJrtC1OKvy+ 0we54y588Rlt
jhPfyvfd/PBYQ4+RADkRXf1NJ1yvvbzjW5Q8Tqh/jz13ujPYvuQ2na9++QK2 b57zDvlOU8Hz
Zx4w/qwDIEMikBN79W9wHmmcABeiPwDAr3/i85+16EcRCuRkdgcsXALtt572 yS9+GQRABCKI
QGytLyITyAn3MqgBEmrQhBScCAsuGEIEuFBRGzlATvjXP0s9T4LjiqFE/54W wpwc4IaECwkD
cmK67y1ugwvUSHnSZxMefi9wSMxbCTsSN5wssX/iyiIMgZiRsuXki+rzFxRP KEaPWBAnVvzd
Bb72wy2Ojo0RmSFO/kY3G4aOjOQDJEaIiBMCfm8Egnuh2+zYkQf2jwHGauMd hUgRDOjEkL+z
WyJx2JEKtCyDkMyeIDHHyI7wLiftShwLiDdKVpayI5/ESSq7FgE6/vGVgcTl RgiwEz66JXii
1CUpFRkS6vErcQnQGCUlCRIIoFF5PhsmJ0Giw+pVTpmtDCYxRWIB5V0sl9sM YjY3Ysy0PUCc
wnRlOEUSy5z4UisisBU4p0mvJh5tbehc5zxVAv8BA04NkRMc5y31Sa84usUA +AxoOrXZkgp4
7y0akKdCCSpNl3TzLQiw5UTpeZIDPLMsq0yiSF8CAQyOZQBqHONCNykTCTgS KyLAgEZVSlF1
4qUB9gyWBWaqxZoyNC8s8GdUUhBJMHEwQketSAUOMIFZEsUBDVgdXRSIR5Ww 6KU9EUEBjuia
pP7HqxqBwAhYIABQ5SQCAlhAAJ5II7ASKIoVWuMy6+jTuGJzpQO1q1Hh2h+3 6tVCfnVQYP8q
WL4yzbCEZcxgJ7TYxGIIsfWDrGPZJ9mJOOmvVJ3rZP9X1QB2drN9rSxlPwta xYrWfact7VtJ
K8XGbjazAlWtw1LbQdrbypaxtm3IZfUKW7ze9rCsnW1wf4vU3H7VuMTtbV2J a9rhAlezzEWt
c5sL3ejWdrqRxa51catdy7p2ssrdbl5HKl7PVpez5y1vQsKrXvPGlq7tda9v 4Rtf9L5Xrvet
b2G7O9oi+tcphPuvgPkr3QEbmMD3O7CC54vfBQ84Lg72L4QjHMIJU/iAnGEW AHyo3/ackibA
7HB2FAAsEPBUxMHBIAOkiuLi6JEmAG3xc1BgkzDKWDkVgNYJTnxj1MyNAWzt 8W0sWZMQC1k2
EIiVA44cnAqYFQAdYDGTRRIQADs=
--------------050903000206000300070406--
Re: filled ellipse renders with small gap [message #634991 is a reply to message #634573] Mon, 25 October 2010 07:00 Go to previous messageGo to next message
Hi Henrik,
i can not open the image you attached.
Also could you post the full class defining the add feature, such that
i can try to reproduce (a simple example seemed to work correctly)?
Best regards, Tim
Re: filled ellipse renders with small gap [message #635010 is a reply to message #634991] Mon, 25 October 2010 08:12 Go to previous messageGo to next message
--------------000906040000090802030807
Content-Type: text/plain; charset=UTF-8
Hi Tim,
I've attached the image again as gif and also as tif.
For the "inverse" figure it looks similar.
I've also attached some of the source code.
Henrik
I'm using Eclipse 3.6, Build id: I20100608-0911
(the 32bit version running on a 64bit Windows 7)
Graphiti 0.7.0
GEF 3.6.1
Debug output:
Pictogram Model Tree()
*PE* ContainerShapeImpl (active) (visible)
RectangleImpl (360, 0, 80, 80)
RectangleImpl (20, 20, 40, 40)
EllipseImpl (30, 30, 20, 20)
*PE* ShapeImpl (inactive) (visible)
TextImpl (0, 0, 80, 20)
*PE* ChopboxAnchorImpl (inactive) (invisible)
Edit Part Tree()
ContainerShapeEditPart (RectangleImpl)
Figure Tree
GFRectangleFigure (Rectangle(400, 40, 80, 80))
GFRectangleFigure (Rectangle(420, 60, 40, 40))
GFEllipse (Rectangle(430, 70, 20, 20))
GFText (text: fcn) (Rectangle(400, 40, 80, 20))
Am 25.10.2010 13:00, schrieb Tim Kaiser:
> Hi Henrik,
> Best regards, Tim
Content-Type: image/tiff;
name="filledEllipse.tif"
filename="filledEllipse.tif"
SUkqAHivAQD8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz///////////////////////////////////////////// ////////////
///////////////8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///8A AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD////8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz///8AAAAEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQAAAD////8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz///8AAAAE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQAAAD/ ///8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///8AAAAEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQAAAD////8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz/
//8AAAAEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQAAAD////8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///8AAAAEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQAAAD////8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz///8AAAAEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQA
AAD////8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///8AAAAEAgQE AgQEAgQEAgQE
AgQEAgQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAEAgQEAgQEAgQEAgQEAgQEAgQAAAD////8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz///8AAAAEAgQEAgQEAgQEAgQEAgQEAgQAAAD///////// ////////////
//////////////////////////////////////////////////8AAAAEAgQE AgQEAgQEAgQE
AgQEAgQAAAD////8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///8A AAAEAgQEAgQE
/vz8/vz8/vz8/vz///8AAAAEAgQEAgQEAgQEAgQEAgQEAgQAAAD////8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz///8AAAAEAgQEAgQEAgQEAgQEAgQEAgQAAAD/ ///8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///8AAAAEAgQEAgQEAgQEAgQEAgQE AgQAAAD////8
//8AAAAEAgQEAgQEAgQEAgQEAgQEAgQAAAD////8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///8AAAAEAgQEAgQEAgQE AgQEAgQEAgQA
/vz8/vz///8AAAAEAgQEAgQEAgQEAgQEAgQEAgQAAAD////8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz9//3///////////////////////// ////////////
///////////////////////////+//78/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz/ ////////////
///////f4t+eoZ59gH0MEAwTFhMTFhMTFhMTFhMTFhMTFhMNEQ1wbHCQlJDg 5OD/////////
///////////8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz9//3////////////////g5OBgXGAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABGSUa4vLj///////////// ///////8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///////////////+6 vbo4PDgAAAAA
AAAAAAAAAAABAAEEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQC
AAIAAAAAAAAAAAAAAAAtMS2go6D////////////////8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz+//7////////4+/g3OjcAAAAAAAAAAAAAAAADAAMEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQAAAAA AAAAAAAAAAAC
BgLEx8T////////////8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz9//3///////////84OzgAAAAA AAAAAAAEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQAAAAAAAAAAAAUFxTf4t////// ///////8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz9//3/
//////////9fWl8AAAAAAAAAAAAEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQAAAAAAAAAAAAsMCz////////////+//78/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///////////94engAAAAAAAAAAAAE AQQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQA AAAAAAAAAABS
TlL////////////8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz/////
//////8AAAAAAAAAAAADAAMEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQCAAIA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAEE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQAAAAAAAAAAADe4d7////////8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz////////e4d4AAAAAAAAAAAAEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQAAAAAAAAAAAAAAAAYHBhCRkKIjYh0cnSWm5ZN Uk1DR0NESERE
SERARUB8gHxdYl1ESEQrMCsAAAAAAAAAAAAAAAAEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQCAAIAAAAAAACfop/////////8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
//+tsK0AAAAAAAACAAIEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQAAAAAAAAA AAAAAAAzMDNv
dG9SVlIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAsMSw7
ODsAAAAAAAAAAAAAAAAEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAQQAAAAA AABuam7/////
///9//38/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz9//3///////9saGwAAAAAAAAEAQQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQAAAAAAAAAAABLSEt8gXxBP0EAAAAAAAAAAAAAAAAEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQBAAEAAAAAAAAAAAAdIh08OTwAAAAC AAICAAIEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQAAAAAAAAfIx/////////////8/vz8/vz8 /vz8/vz8/vz8
//8qLioAAAAAAAAEAgQEAgQEAgQEAgQEAgQEAgQEAgQCAAIAAAAAAAAtMi2L iIsAAAAAAAAA
AAAAAAAEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQCAAIAAAAAAAAAAAAgJSAAAAACAAICAAIEAgQEAgQEAgQEAgQE AgQEAgQEAgQA
AAAAAAAAAAD////////9//38/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///////8rJysAAAAAAAAEAgQEAgQE AgQEAgQEAgQE
AgQEAQQAAAAAAAAQFBB+gn4ABAAAAAAAAAAEAQQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQCAAICAAIA
BQAgJCABAAEDAAMEAQQEAgQEAgQEAgQEAgQEAgQEAgQAAAAAAAAAAAD///// ///8/vz8/vz8
//9fW18AAAAAAAAEAgQEAgQEAgQEAgQEAgQEAgQDAAMAAAAAAACIjIgQFBAA AAAAAAADAAME
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAQQCAAIBAAEQDhACBwIDAAMD AAMEAgQEAgQE
AgQEAgQEAgQEAgQBAAEAAAAUFxT////////8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz///////+go6AAAAAAAAAEAgQEAgQE AgQEAgQEAgQE
AgQAAAAAAAACBgKHg4cAAAAAAAACAAIEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQDAQMDAAMCAAIRFhECAAIDAAMEAgQEAgQEAgQEAgQEAgQEAgQA AAAAAABSTlL/
///////8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz8/vz8/vz8
///f4t8AAAAAAAAEAgQEAgQEAgQEAgQEAgQEAgQAAAAAAAA+Qj48QDwAAAAA AAAEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQD AAMCAAIRFhED
AAMEAQQEAgQEAgQEAgQEAgQEAgQEAgQAAAAAAACgpKD////////8/vz8/vz8 /vz8/vz8/vz8
/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz9//3///////8AAAAAAAAEAQQEAgQE AgQEAgQEAgQE
AgQAAAAAAABqZmogJCAAAAAAAAAEAgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQEAgQEAgQEAgQEAgQEAgQEAgQEAgQDAAMDAAMDCAMEAQQEAgQEAgQEAgQE AgQEAgQEAgQE
AgQAAAAAAADf4d/////+//78/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8/vz8 /vz
Re: filled ellipse renders with small gap [message #635284 is a reply to message #635010] Tue, 26 October 2010 05:24 Go to previous messageGo to next message
Thanks for the new attachments...i could open your attachment only
with the news reader (outlook express) but not via the web frontend...maybe
a general problem
of the web frontend...
I tried to draw an ellipse with plain draw2d and received similar problems.
I guess it is the usual rounding/pixeling float->int mapping which causes
problems in draw 2d.
The white points appear exactly between the border and the filling.
In my example there were background pixels rendered outside of the
border....
You may open a bug report at the GEF/Draw2D component.
Best, Tim
"Henrik Rentz-Reichert" <hrr@protos.de> wrote in message
news:4CC5743F.8040906@protos.de...
> Hi Tim,
> Regards,
> Henrik
> Graphiti 0.7.0
> GEF 3.6.1
> Debug output:
> Edit Part Tree()
> Figure Tree
>> Hi Henrik,
>> Best regards, Tim
Re: filled ellipse renders with small gap [message #635593 is a reply to message #635284] Wed, 27 October 2010 09:14 Go to previous message
I filed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=328801
for GEF/draw2d
Am 26.10.2010 11:24, schrieb Tim Kaiser:
> a general problem
> border....
> Best, Tim
>> Hi Tim,
>> Regards,
>> Henrik
>> Graphiti 0.7.0
>> GEF 3.6.1
>> Debug output:
>> Edit Part Tree()
>> Figure Tree
>>> Hi Henrik,
>>> Best regards, Tim
Previous Topic:Adding an action to context menu
Next Topic:How to add an ImageDecorator to a connection
Current Time: Thu Jul 24 21:59:46 EDT 2025
Powered by FUDForum. Page generated in 0.47664 seconds
