Home » Modeling » EMF » Teneo(Basic Tutorial)
icon13.gif  Teneo [message #633182] Fri, 15 October 2010 11:07 Go to next message
I am trying the examples from
org.eclipse.emf.teneo.hibernate.examples
How to run for the
Dynamic.java
QuickStart.java
Tutorial.java
It complains of main method not found, though there is indeed main, i tried putting them in classpath too but not of any value.
What i am missing?By default, are they on the classpath?
or somewhere we have to do some minor tweaking ?
Which ways to run them?
Thanks.
Re: Teneo [message #633192 is a reply to message #633182] Fri, 15 October 2010 11:16 Go to previous messageGo to next message
Yes there is a main method in these classes, I have no idea why this happens, is the project indeed a java plugin
project? Do you have automatic build flagged in the project properties?
Which version of Eclipse are you using?
gr. Martin
> How to run for the Dynamic.java
> QuickStart.java
> Tutorial.java
> Thanks.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo [message #633501 is a reply to message #633192] Mon, 18 October 2010 05:16 Go to previous messageGo to next message
Background
I downloaded as java project for the teneo project.
Difficulties i encountered, ie by default, it was not being recognized for run configuration. I then imported it as java project in the workspace and pointed out QuickStart as main. But i get errors here ie(those are not found)
import org.eclipse.example.library.Book;
import org.eclipse.example.library.BookCategory;
import org.eclipse.example.library.LibraryFactory;
import org.eclipse.example.library.LibraryPackage;
import org.eclipse.example.library.Writer;
I think the examples are not properly set up or if have any working examples , plz let me know.
Much Thanks.
Re: Teneo [message #633687 is a reply to message #633501] Mon, 18 October 2010 16:52 Go to previous messageGo to next message
The examples project in HEAD has these imports:
import org.eclipse.emf.teneo.hibernate.examples.extlibrary.Book;
import org.eclipse.emf.teneo.hibernate.examples.extlibrary.BookCate gory;
import org.eclipse.emf.teneo.hibernate.examples.extlibrary.Extlibra ryFactory;
import org.eclipse.emf.teneo.hibernate.examples.extlibrary.Extlibra ryPackage;
import org.eclipse.emf.teneo.hibernate.examples.extlibrary.Library;
import org.eclipse.emf.teneo.hibernate.examples.extlibrary.Writer;
So afaics you have not downloaded the HEAD version. I already pointed this out several times to you...
Please read my replies more carefully and read a tutorial on cvs, it will save you and others a lot of time...
gr. Martin
On 10/18/2010 11:16 AM, tenor wrote:
> Background
> examples , plz let me know. Much Thanks.
The Netherlands
[Teneo] java.lang.SecurityException [message #634499 is a reply to message #633687] Thu, 21 October 2010 20:23 Go to previous messageGo to next message
I'm using Teneo with Spring. When I try to create a org.eclipse.emf.teneo.hibernate.HbSessionDataStore bean, I get a java.lang.SecurityException (Pasted stack trace below). I'm using the following teneo jars:
<dependency>
<groupId>org.eclipse.emf.teneo</groupId>
<artifactId>hibernate</artifactId>
<version>1.1.1</version>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>annotations</artifactId>
<version>1.1.0</version>
</dependency>
<dependency>
<groupId>org.eclipse.emf</groupId>
<artifactId>teneo</artifactId>
</dependency>
<dependency>
<groupId>org.eclipse.emf.teneo.hibernate</groupId>
<artifactId>mapper</artifactId>
</dependency>
Any ideas?
TIA,
- Ole
java.lang.SecurityException: Invalid signature file digest for Manifest main attributes
at sun.security.util.SignatureFileVerifier.processImpl(Signatur eFileVerifier.java:239)
at sun.security.util.SignatureFileVerifier.process(SignatureFil eVerifier.java:193)
at java.util.jar.JarVerifier.processEntry(JarVerifier.java:294)
at java.util.jar.JarVerifier.update(JarVerifier.java:205)
at java.util.jar.JarFile.initializeVerifier(JarFile.java:338)
at java.util.jar.JarFile.getInputStream(JarFile.java:403)
at sun.misc.URLClassPath$JarLoader$2.getInputStream(URLClassPat h.java:706)
at sun.misc.Resource.cachedInputStream(Resource.java:77)
at sun.misc.Resource.getByteBuffer(Resource.java:160)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:266)
at java.net.URLClassLoader.access$000(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:212)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at org.springframework.util.ClassUtils.forName(ClassUtils.java: 242)
at org.springframework.beans.factory.support.AbstractBeanDefini tion.resolveBeanClass(AbstractBeanDefinition.java:383)
at org.springframework.beans.factory.support.AbstractBeanFactor y.resolveBeanClass(AbstractBeanFactory.java:1135)
at org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.predictBeanType(AbstractAutowireCapableBean Factory.java:524)
at org.springframework.beans.factory.support.AbstractBeanFactor y.isFactoryBean(AbstractBeanFactory.java:1174)
at org.springframework.beans.factory.support.DefaultListableBea nFactory.getBeanNamesForType(DefaultListableBeanFactory.java :222)
at org.springframework.context.support.AbstractApplicationConte xt.invokeBeanFactoryPostProcessors(AbstractApplicationContex t.java:506)
at org.springframework.context.support.AbstractApplicationConte xt.refresh(AbstractApplicationContext.java:363)
at org.springframework.context.support.ClassPathXmlApplicationC ontext. <init>(ClassPathXmlApplicationContext.java:139)
at org.springframework.context.support.ClassPathXmlApplicationC ontext. <init>(ClassPathXmlApplicationContext.java:83)
at com.pyramidetechnologies.persistance.learning.tests.AccountD AOTest.setUp(AccountDAOTest.java:17)
at junit.framework.TestCase.runBare(TestCase.java:125)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:197)
Re: [Teneo] java.lang.SecurityException [message #634500 is a reply to message #634499] Thu, 21 October 2010 21:02 Go to previous messageGo to next message
Just wanted to mention that I also tried a HbSessionDataStore load test like this:
import junit.framework.TestCase;
import org.eclipse.emf.teneo.hibernate.HbSessionDataStore;
public class TeneoLoadTest extends TestCase
public void testClassLoad()
HbSessionDataStore hb = new HbSessionDataStore();
assertTrue(true);
And I still get the same exception.
- Ole
Re: [Teneo] java.lang.SecurityException [message #634516 is a reply to message #634500] Fri, 22 October 2010 00:33 Go to previous message
OK - Never mind - I upgraded the dependencies to 1.1.2 and now everything works fine.
Ole
> like this:
> assertTrue(true);
> - Ole
Previous Topic:Good idea to inherit from ENamedElement and EModelElement?
Next Topic:Read referenced resource programatically
Current Time: Thu Jul 24 21:46:31 EDT 2025
Powered by FUDForum. Page generated in 0.08135 seconds
