| Please help! [message #633952] |
Tue, 19 October 2010 23:19  |
Ok so heres the synopsis.. i downloaded the JDK 5 for windows 64 bit. i also downloaded the SDK from Android because im going to be creating apps for the Android Market. Only problem is when i downloaded the eclipse 3.5 (Galileo) i saved it to my desktop, exctracted all (files), and clicked the eclipse icon to launch it and it brings up the error code `C:\Program Files\Java\jre6\lib\i386\jvm.cfg' and i have absolutly NO idea why! can anyone please help me? im desperate to get an answer because i want to start writing apps A.S.A.P!
| Re: Please help! [message #634668 is a reply to message #634627] |
Fri, 22 October 2010 11:51   |
On 2010.10.22 7:17, iCode wrote:
> for windows XP it says that you have to go to computer, environmental
> settings, go to PATH and input the java as the JVM and i dont know what
> to write there so that Java becomes my JVM in the PATH set in my
> environmental settings, i.e which or what information do i write when i
> click the edit button on PATH?
I'm an Android developer and long-time Eclipse user and I've never done
that (if I understand what you're saying). You only need your computer
host's PATH environment variable to point to Java if you plan on having
easy access to something Java-ish (like java.exe or javac.exe) from the
command line.
I publish and maintain articles on setting up Eclipse and other topics.
If you like, please peruse this page,
http://www.javahotchocolate.com/tutorials/eclipse-summary.ht ml,
especially the first two articles it links.
Then, if interested in my own Android experience, consider reading
http://www.javahotchocolate.com/tutorials/android.html
| Re: Please help! [message #634748 is a reply to message #634734] |
Fri, 22 October 2010 20:27   |
On 2010.10.22 15:07, iCode wrote:
> where do i find the eclipse.ini file? and how do i tell the java
> executable to run? im really sorry for being such a pain in your butt..
> i just have such a hard time with java for some reason. Objective C
> doesnt require you to do this so i get confused.. ok last time. I have
> Eclipse 3.5 (galileo) downloaded, the Java Environment, the JDK
> 1.5.0_02, and the Android SDK package. All are downloaded for a windows
> 64 bit and i had an error code telling me that eclipse couldnt even find
> a certain java file. So i downloaded the Java Runtime Environment. Now
> it tells me-
> A Java Runtime Environment (JRE) or Java Development Kit (JDK) must be
> available in order to run eclipse. No Java Virtual Machine was found
> after searching the following locations:
> C:\Documents and
> Settings\Owner\Desktop\eclipse-java-galileo-SR2-win32\eclips
> e\jre\bin\javaw.exe in your current PATH
> So from here i have NO idea what to do to change that path, i dont know
> how to tell eclipse to look in a different location to find the proper
> JDK or JRE so that it can run properly. What do i do?
Logan,
Objective C "doesn't require" you to do these things because it's a
narrow environment nearly for one purpose only--the development of
iPhone apps. Apple writes it; it doesn't do anything else; it is what it is.
Welcome to the great big world of the limitless possibilities of open
source software, Java, JEE and all that Eclipse supports including
C/C++, PHP, and countless other technologies.
Two days ago I gave you some references to hand-holding material I've
written and another article written by someone else. If you can now ask
"where is eclipse.ini? how to tell it which Java to run?" it's because
you haven't made any use of the resources and answers offered so far.
At some point, you will have to break down and make Google your friend.
It's what we do before we ask questions in any forum.
In the meantime, read and follow
http://www.javahotchocolate.com/tutorials/eclipse-summary.ht ml and all
your questions will be answered. You haven't yet asked anything that
this article doesn't answer.
Then, when Android gets difficult for you, read
http://www.javahotchocolate.com/tutorials/android.html and you'll
benefit from my own Android start-up experience.
| Re: Please help! [message #635112 is a reply to message #634734] |
Mon, 25 October 2010 12:13  |
For the THIRD time, I'm telling you to read the "sticky" messages at the
top of this forum group - they even have the text "READ THIS FIRST" in
their titles. If you're note willing to do a little of the research
yourself, you're not going to go very far in this community.
Eric
FUDForum. Page generated in 0.08629 seconds
