Home » Archived » Tycho » IllegalAccessErrors Running JUnit Tests During Build(Tests pass using JUnit Runner but fail when doing maven/tycho/surefire build.)
IllegalAccessErrors Running JUnit Tests During Build [message #634067] Wed, 20 October 2010 08:54 Go to next message
I have a plugin (org.a.test) that is used to test another plugin (org.a). Both plugins have the same Java packages defined. The classes being tested in org.a have "protected" and package private methods. When I do a build using Tycho both jars (org.a, org.a.test) build fine.
However, during the build when the JUnit tests are run I get a runtime java.lang.IllegalAccessError whenever a test plugin class calls one of these protected methods. All the tests run successfully within Eclipse using the JUnit runner. I have Eclipse's compiler setting for "forbidden reference access rules" set to be an error.
Any ideas?
Thanks!
Re: IllegalAccessErrors Running JUnit Tests During Build [message #634156 is a reply to message #634067] Wed, 20 October 2010 11:52 Go to previous messageGo to next message
you need to use a test fragment instead of a test plugin in order to access
package-private members
This is not a tycho issue but rather how OSGi behaves at runtime
Jan
"elvisisking" <dflorian@redhat.com> wrote in message
news:i9mojo$m85$1@news.eclipse.org...
> Any ideas?
> Thanks!
Re: IllegalAccessErrors Running JUnit Tests During Build [message #634453 is a reply to message #634156] Thu, 21 October 2010 14:39 Go to previous messageGo to next message
So by your response you're saying when I use the JUnit runner within Eclipse to run the tests (which all pass), that OSGi is not being used then. I thought Eclipse used the OSGi framework. Is that not the case?
Does anyone know the steps to convert a plugin to a fragment?
Thanks!
Re: IllegalAccessErrors Running JUnit Tests During Build [message #634630 is a reply to message #634453] Fri, 22 October 2010 09:25 Go to previous message
Run As > Junit test runs plain Junit tests, Run As > Junit plugin tests runs Junit inside OSGI (which is what tycho also does)
Previous Topic:Downloading Tycho / Maven
Next Topic:Has anyone successfully built a RAP app using Maven Tycho?
Current Time: Fri Jul 25 18:18:43 EDT 2025
Powered by FUDForum. Page generated in 0.32551 seconds
