Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » how to load an XML-Instance into Ecore and access its attribute values
how to load an XML-Instance into Ecore and access its attribute values [message #634216] Wed, 20 October 2010 15:34 Go to next message
I am new to EMF/Ecore (and to Eclipse too) and I have small problem.
I convert a XML-Schema to Ecore using this Code:
XSDEcoreBuilder xsdEcoreBuilder = new XSDEcoreBuilder();
ResourceSet resourceSet = new ResourceSetImpl();
final ExtendedMetaData extendedMetaData = new BasicExtendedMetaData(resourceSet.getPackageRegistry());
resourceSet.getLoadOptions().put(XMLResource.OPTION_EXTENDED_META_DATA, extendedMetaData);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xml", new XMLResourceFactoryImpl());
Collection<?> eCorePackages = xsdEcoreBuilder.generate(URI.createFileURI(path_to_xsd_file));
for (Iterator<?> iter = eCorePackages.iterator(); iter.hasNext();) {
	EPackage element = (EPackage) iter.next();
	resourceSet.getPackageRegistry().put(element.getNsURI(), element);
	System.out.println(element.getNsURI());
As far as I see, this works beside the fact, that I have a EClass "DocumentRoot" in the Ecore-Model, which isn't modeled in my XML-Schema.
Furthermore I want to load a XML-Instance-File related to this XSD-File. I am trying it with this code:
HashMap<String, Boolean> options = new HashMap<String, Boolean>();
options.put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
Resource resource = resourceSet.createResource(URI.createFileURI(path_to_xml_file));
resource.load(options);
Now my problem is the following. I want to access the XML-Data in the previously loaded Model and extract the values of the attributes for each EClass. Is there an easy way to achieve this?
Thanks in advance.
Ben.
Re: how to load an XML-Instance into Ecore and access its attribute values [message #634361 is a reply to message #634216] Thu, 21 October 2010 07:53 Go to previous messageGo to next message
Ben,
It's best to use the eclipse.tools.emf newsgroup/forum for questions
about Ecore core.
More comments below.
Ben wrote:
> resourceSet.getLoadOptions().put(XMLResource.OPTION_EXTENDED _META_DATA,
> extendedMetaData);
> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "xml",
> xsdEcoreBuilder.generate(URI.createFileURI(path_to_xsd_file) );
Hopefully this path is absolute...
You've read
http://www.theserverside.com/news/1364302/Binding-XML-to-Jav a to
understand that?
> Resource resource =
> resourceSet.createResource(URI.createFileURI(path_to_xml_fil e));
I'd suggest reading the above article. I think it explains everything
you need to know.
> Thanks in advance.
> Cheers,
> Ben.
Re: how to load an XML-Instance into Ecore and access its attribute values [message #634439 is a reply to message #634361] Thu, 21 October 2010 13:31 Go to previous message
thanks for your answer. This solved my problem.
Ben
Previous Topic:annotation references
Next Topic:XSD To ECore to XML
Current Time: Sun Jul 27 02:25:19 EDT 2025
Powered by FUDForum. Page generated in 0.03844 seconds
