Home » Language IDEs » ServerTools (WTP) » [SOLVED] Attribute 'attrname' is not allowed to appear in element 'elem'
[SOLVED] Attribute 'attrname' is not allowed to appear in element 'elem' [message #634043] Wed, 20 October 2010 07:24
Q:
Attribute 'attrname' is not allowed to appear in element 'elem', XML Catalog
A:
1) Eclipse is right, fix your XML
2) If you really need to keep this bad xml, download the xsd, add missing attr into it, go to preferences, XML Catalog,
add your modified xsd there
key type: Namespace Name
key : the original xsd url (if xsi:schemaLocation="a b", use "b" or try both)
Real life example, jboss tools installed, pages.xml :
<pages xmlns="http://jboss.com/products/seam/pages"
       xsi:schemaLocation="http://jboss.com/products/seam/pages http://jboss.com/products/seam/pages-2.2.xsd"
       login-view-id="/login.xhtml" no-conversation-view-id="/login.xhtml" >
    <page view-id="/pages/foo.xhtml" login-required="true" on-postback="false">
        <rewrite pattern="/foo"/>
    </page>
validation error: Attribute 'on-postback' is not allowed to appear in element 'page'. pages.xml
1) I download http://jboss.com/products/seam/pages-2.2.xsd
2) find node and add missing attribute "on-postback"
    <xs:attributeGroup name="attlist.page">
        <xs:attribute name="on-postback" default="true" type="pages:tf-boolean"/>
        <xs:attribute name="action" type="xs:token" />
3) Add modified pages-2.2.xsd with key: http://jboss.com/products/seam/pages-2.2.xsd
Previous Topic:Nested lib folder structure at deployment on JBoss AS 5.1 in server view
Next Topic:Throwing an exception from a web service
Current Time: Sun Aug 31 00:23:34 EDT 2025
Powered by FUDForum. Page generated in 0.05803 seconds
