Home » Archived » BIRT » Accessing remote birt designs in BIRT Viewer(Accessing remote birt designs in BIRT Viewer)
Accessing remote birt designs in BIRT Viewer [message #633734] Tue, 19 October 2010 03:37 Go to next message
Hi All,
We are trying to access birt reports "remotely" hosted in a separate application in the birt viewer app. We access the report something like :
http://localhost:8080/birtviewer/run?__report=http://localho st:8080/app1/test1.rptdesign
This works perfectly fine .. However, when security is enabled, the birt engine fails to find and load the report design from a "secure" remote server.
This fails when the birt viewer and the app that serves the report design are installed on the same application server. We are trying with a URL like below.
https://localhost:8443/birtviewer/run?__report=https://local host:8443/app1/test1.rptdesign
> Any ideas as to how can we get this to work ?
> What are the recommended practices for storing report designs for the birt viewer ?
Cheers, DKN
Re: Accessing remote birt designs in BIRT Viewer [message #633870 is a reply to message #633734] Tue, 19 October 2010 12:02 Go to previous messageGo to next message
Are you getting anything in the log file?
Jason
On 10/19/2010 3:37 AM, dkn wrote:
> Hi All,
> server.
> a URL like below.
>> birt viewer ?
> Cheers, DKN
Re: Accessing remote birt designs in BIRT Viewer [message #633968 is a reply to message #633870] Wed, 20 October 2010 02:21 Go to previous message
Hi Jason ,
The logs do not show any entries , However on the browser the following errors are seen
Error Stack Trace
The report file : https://server:9443/ReportRetriever/render/test.rptdesign does not exist or contains errors.
org.eclipse.birt.report.exception.ViewerException: The report file : https://server:9443/ReportRetriever/render/test.rptdesign does not exist or contains errors.
at org.eclipse.birt.report.context.ViewerAttributeBean.getDesig nHandle(ViewerAttributeBean.java:647)
at org.eclipse.birt.report.context.ViewerAttributeBean.__init(V iewerAttributeBean.java:224)
at org.eclipse.birt.report.context.BaseAttributeBean.init(BaseA ttributeBean.java:233)
at org.eclipse.birt.report.context.ViewerAttributeBean.<init>(ViewerAttributeBean.java:118)
at org.eclipse.birt.report.context.BirtContext.__init(BirtConte xt.java:44)
at org.eclipse.birt.report.context.BaseContext.<init>(BaseContext.java:69)
at org.eclipse.birt.report.servlet.ViewerServlet.__getContext(V iewerServlet.java:150)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(BirtSoapMessageDispatcherServlet.java:151)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:718)
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:831)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(Servl etWrapper.java:1589)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(Servl etWrapper.java:1523)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(We bAppFilterChain.java:131)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:68)
at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilte r(FilterInstanceWrapper.java:188)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(We bAppFilterChain.java:116)
at com.ibm.ws.webcontainer.filter.WebAppFilterChain._doFilter(W ebAppFilterChain.java:77)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter( WebAppFilterManager.java:885)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest (ServletWrapper.java:865)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest (ServletWrapper.java:475)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleReq uest(ServletWrapperImpl.java:175)
at com.ibm.ws.webcontainer.webapp.WebApp.handleRequest(WebApp.j ava:3799)
at com.ibm.ws.webcontainer.webapp.WebGroup.handleRequest(WebGro up.java:276)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContai ner.java:930)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebCo ntainer.java:1583)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChanne lLink.java:182)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleD iscrimination(HttpInboundLink.java:455)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleN ewInformation(HttpInboundLink.java:384)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.ready(H ttpInboundLink.java:272)
at com.ibm.ws.ssl.channel.impl.SSLConnectionLink.determineNextC hannel(SSLConnectionLink.java:1016)
at com.ibm.ws.ssl.channel.impl.SSLConnectionLink$MyReadComplete dCallback.complete(SSLConnectionLink.java:639)
at com.ibm.ws.ssl.channel.impl.SSLReadServiceContext$SSLReadCom pletedCallback.complete(SSLReadServiceContext.java:1772)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.future Completed(AioReadCompletionListener.java:165)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(Abstract AsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(As yncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:2 04)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(Result Handler.java:775)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1550)
Previous Topic:Export in .doc without page breaks
Next Topic:Report parameters
Current Time: Sat Jul 26 17:02:11 EDT 2025
Powered by FUDForum. Page generated in 0.07212 seconds
