Home » Eclipse Projects » Virgo » can't import derbyclient bundle
can't import derbyclient bundle [message #633353] Sat, 16 October 2010 15:56 Go to next message
I am getting exceptions while trying to import derbyclient 10.6.2000001.999685 .
When I do
Import-Bundle: derbyclient
I get
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'com.rits.derby' at vers
ion '1.0.0': Import-Bundle with symbolic name 'derbyclient' in version range '[0.0.0, oo)' could not be satisfied
	at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.getBundlePackageImports(ImportExpansionHandler.java:271)
When I do
Require-Bundle: derbyclient;version="[10.6.2000001.999685]"
I get
ion '1.0.0': Cannot resolve: com.rits.derby
    Resolver report:
        A Require-Bundle could not be resolved. Caused by missing constraint in bundle <com.rits.derby_1.0.0>
             constraint: <Require-Bundle: derbyclient; bundle-version="0.0.0">
	at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.QuasiResolveStage.process(QuasiResolveStage.java:45)
I do have derby client in my maven repository and I've configured virgo to read bundles from it. This works because I import other bundles from it.
			<dependency>
				<groupId>org.apache.derby</groupId>
				<artifactId>derbyclient</artifactId>
				<version>10.6.2.1</version>
			</dependency>
Any ideas?
Re: can't import derbyclient bundle [message #633355 is a reply to message #633353] Sat, 16 October 2010 16:00 Go to previous messageGo to next message
My bundle is attached.
Also, the manifest of derbyclient:
Manifest-Version: 1.0
Ant-Version: Apache Ant 1.7.1
Created-By: 11.3-b02 (Sun Microsystems Inc.)
Bundle-Vendor: Apache Software Foundation
Bundle-Name: Apache Derby 10.6
Bundle-Version: 10.6.2000001.999685
Bundle-ManifestVersion: 2
Sealed: true
Bundle-SymbolicName: derbyclient
DynamicImport-Package: *
Export-Package: org.apache.derby.jdbc
Class-Path: derbyLocale_cs.jar derbyLocale_de_DE.jar derbyLocale_es.ja
 r derbyLocale_fr.jar derbyLocale_hu.jar derbyLocale_it.jar derbyLocal
 e_ja_JP.jar derbyLocale_ko_KR.jar derbyLocale_pl.jar derbyLocale_pt_B
 R.jar derbyLocale_ru.jar derbyLocale_zh_CN.jar derbyLocale_zh_TW.jar
Sealed: false
Sealed: false
Sealed: false
Sealed: false
Sealed: false
Sealed: false
Sealed: false
Sealed: false
Sealed: false
Re: can't import derbyclient bundle [message #633377 is a reply to message #633355] Sun, 17 October 2010 03:56 Go to previous messageGo to next message
Require-Bundle: derbyclient;version="[10.6.2000001.999685]" is invalid syntax. Did you mean Require-Bundle: derbyclient;version="[10.6.2000001.999685, 10.6.2000001.999685]"?
What is the Virgo repository configuration for the Maven repository?
Re: can't import derbyclient bundle [message #633425 is a reply to message #633377] Sun, 17 October 2010 14:44 Go to previous messageGo to next message
Hi, tried with
Require-Bundle: derbyclient;version="[10.6.2000001.999685,10.6.2000001.999685]"
and I got
Caused by: org.osgi.framework.BundleException: The bundle "com.rits.derby_1.0.0 [72]" could not be resolved. Reason: Missing Constraint: Require-Bundle: derbycl
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1317)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1301)
my org.eclipse.virgo.repository.properties :
ext.type=external
ext.searchPattern=repository/ext/{artifact}
usr.type=watched
usr.watchDirectory=repository/usr
mavenrepo.type=external
mavenrepo.searchPattern=${user.home}/.m2/repository/**/{bundle}.jar
mavenrepolibd.type=external
mavenrepolibd.searchPattern=${user.home}/.m2/repository/**/{bundle}.libd
chain=mavenrepo,mavenrepolibd,ext,usr
this should be ok because I am importing other bundles from the mavenrepo. derbyclient is under /home/ariskk/.m2/repository/org/apache/derby/derbyclient/10. 6.2.1 with a filename derbyclient-10.6.2.1.jar .
Cheers
Re: can't import derbyclient bundle [message #633430 is a reply to message #633425] Sun, 17 October 2010 15:18 Go to previous messageGo to next message
Next, let's eliminate the possibility that ${user.home} is not being substituted properly by replacing it in the repository properties file with the value you would expect and restarting Virgo.
(BTW, this isn't relevant to this particular issue, but you should really keep ext and usr at the beginning of the repository chain as these are intended to be relatively stable repositories with ext containing some of Virgo's own dependencies.)
Re: can't import derbyclient bundle [message #633436 is a reply to message #633430] Sun, 17 October 2010 17:29 Go to previous messageGo to next message
Oh, found what was wrong! Sorry for spending your time on this. An oversight on my side, somehow virgo wasn't aware of changes in the .m2 repo. Dunno why the -clean didn't work (I am always running virgo with the -clean). So -clean didn't work but as soon as I deleted everything under the work folder and restarted the server, the derby bundle was located just fine!
I am starting virgo within eclipse with these VM arguments:
-XX:ErrorFile=./serviceability/error.log
-XX:HeapDumpPath=./serviceability/heap_dump.hprof
-Djava.security.auth.login.config=./config/org.eclipse.virgo.kernel.authentication.config
-Dorg.eclipse.virgo.kernel.authentication.file=./config/org.eclipse.virgo.kernel.users.properties
-Djava.io.tmpdir=./work/tmp
-Dorg.eclipse.virgo.kernel.home=.
-Djavax.net.ssl.keyStore=./config/keystore
-Djavax.net.ssl.keyStorePassword=changeit
-Xmx512m -XX:PermSize=256m
and these program arguments:
-config ./lib/org.eclipse.virgo.kernel.launch.properties
-Forg.eclipse.virgo.kernel.home=.
-Forg.eclipse.virgo.kernel.config=./config
-Fosgi.configuration.area=./work/osgi/configuration
-Fosgi.java.profile=file:./lib/java6-server.profile
-clean
I got those back from the springsource dm server days and updated them up to today. Is the -clean still valid?
Re: can't import derbyclient bundle [message #633479 is a reply to message #633436] Mon, 18 October 2010 03:44 Go to previous messageGo to next message
The crucial point here is that an external repository is only scanned when Virgo starts up and Virgo has not already indexed the external repository, so the restart of Virgo with -clean is necessary to delete the index and rescan to pick up the changes. See the user guide for details.
(Watched repositories are actively scanned and pick up changes without having to restart Virgo, but these are flat directories only and therefore not suitable for Maven repositories.)
Glad you are sorted now!
[Updated on: Mon, 18 October 2010 03:49] by Moderator
Re: can't import derbyclient bundle [message #633529 is a reply to message #633425] Mon, 18 October 2010 06:41 Go to previous messageGo to next message
Just a comment -- surely you should have coded:
Require-Bundle: derbyclient;bundle-version="[10.6.2000001.999685,10.6.2000001.999685]"
that is, used the bundle-version attribute and not the version attribute.
That would explain the message:
Missing Constraint: Require-Bundle: derbyclient; bundle-version="0.0.0"
referring to version 0.0.0 (which you 'specified').
I don't think if affects the rest of the discussion, however. Smile
Re: can't import derbyclient bundle [message #633667 is a reply to message #633479] Mon, 18 October 2010 14:56 Go to previous messageGo to next message
Glyn Normington wrote on Mon, 18 October 2010 03:44
I've restarted the virgo server with the -clean but still it couldn't locate the derbyclient bundle. Had the issue for a couple of days and in 2 PC's and I did several restarts. Anyway,I'll give it a try with a new bundle to see if it actually reoccurs.
Re: can't import derbyclient bundle [message #633670 is a reply to message #633529] Mon, 18 October 2010 15:08 Go to previous messageGo to next message
Steve Powell wrote on Mon, 18 October 2010 06:41
I use
Import-Bundle: com.springsource.org.apache.log4j;version="[1.2.15,1.3.0)"
,org.apache.commons.dbcp
,derbyclient
and that works. both versioned and unversioned bundles are loaded (I think unversioned means it will load the max version found)
I don't know the schemantics of Required-Bundle though - I don't use it. I suppose I used it incorrectly.
Re: can't import derbyclient bundle [message #633703 is a reply to message #633667] Mon, 18 October 2010 21:24 Go to previous messageGo to next message
I just wanted to check the operating system of the PCs which were showing this problem as there are certain issues listing files in some circumstances under Windows.
Re: can't import derbyclient bundle [message #633705 is a reply to message #633670] Mon, 18 October 2010 21:31 Go to previous messageGo to next message
Kostas Kougios wrote on Mon, 18 October 2010 20:08
I use
,derbyclient
An unversioned Import-Bundle has the same effect as coding version="0" which represents a range from 0 to infinity. The semantics of Import-Bundle are that it always chooses the highest bundle version available that fits in the specified range, which in this case equates to the highest bundle version available.
Require-Bundle is a little more complicated because its base semantics in OSGi are pretty complex and then there's Virgo's automatic provisioning behaviour as well. However, I don't think using version instead of bundle-version will have helped.
Re: can't import derbyclient bundle [message #633915 is a reply to message #633705] Tue, 19 October 2010 16:19 Go to previous messageGo to next message
Glyn Normington wrote on Mon, 18 October 2010 21:31
I use
Import-Bundle: com.springsource.org...
Thanks, useful info, I was never sure which version will virgo pick up from my .m2 repository - the old jar's are still there after I upgrade to newer version of libs.
Regarding my OS, I am using Ubuntu 10.10, JDK 1.6.0_21. I still didn't replicate the issue due to lack of time but will try in the next few days.
Re: can't import derbyclient bundle [message #633929 is a reply to message #633915] Tue, 19 October 2010 18:26 Go to previous messageGo to next message
Ok, I can verify that -clean doesn't work as (I?) expect...
I've updated to RC1. I have a bundle of my own that imports an other bundle from the maven repository. I delete everything under virgo/work and start the server with the -clean. The bundle loads just fine.
Now I delete all under virgo/work and also delete the bundle under .m2/repository. I start virgo, my bundle can't find the deleted bundle.
I run mvn to re-download the deleted bundle.
I re-run virgo with -clean, my bundle still fails because can't find the bundle under .m2/repository
I delete all under virgo/work and restart virgo. Now all work ok.
Should I enter a bug?
I've attached my bundle. The bundle that I delete is the logback bundle:
maven stuff:
			<dependency>
				<groupId>org.slf4j</groupId>
				<artifactId>slf4j-api</artifactId>
				<version>1.6.1</version>
			</dependency>
			<dependency>
				<groupId>ch.qos.logback</groupId>
				<artifactId>logback-core</artifactId>
				<version>0.9.25</version>
			</dependency>
Re: can't import derbyclient bundle [message #633989 is a reply to message #633929] Wed, 20 October 2010 04:12 Go to previous messageGo to next message
Yes, please log a bug. The strange thing is that -clean is meant to delete the work directory!
Re: can't import derbyclient bundle [message #634222 is a reply to message #633989] Wed, 20 October 2010 16:03 Go to previous messageGo to next message
Glyn Normington wrote on Wed, 20 October 2010 04:12
Ok, before I log a bug... is the -clean handled by the batch file that starts the server or by the java code? I am starting virgo within eclipse using a runconfig, which means java is called with the -clean parameter. So if it is handled by the batch file it is not a bug.
Re: can't import derbyclient bundle [message #634290 is a reply to message #634222] Thu, 21 October 2010 03:34 Go to previous messageGo to next message
It's handled by dmk.sh/dmk.bat. If you use the Virgo tooling, there is an option to clean start the server.
Re: can't import derbyclient bundle [message #634452 is a reply to message #634290] Thu, 21 October 2010 14:36 Go to previous message
Glyn Normington wrote on Thu, 21 October 2010 03:34
aha, thats why it doesn't work for me. I was invoking java straight away with the -clean param. Not a bug then.
Previous Topic:Successful completion of Virgo 2.1.0 Release and Graduation Review
Next Topic:Could Fragment bundles be used on Virgo?
Current Time: Wed Jul 23 23:32:35 EDT 2025
Powered by FUDForum. Page generated in 0.07395 seconds
