Home » Modeling » Epsilon » Automatic validation.(How can I validate the model when a object or link is created?)
icon5.gif  Automatic validation. [message #633532] Mon, 18 October 2010 06:46 Go to next message
Hello everybody!! First to all, thanks you for your help.
I would like validate my model when a Object or link is created. Anyone knows how can I do it?
I have tried some things, but I did not succeed.
Thanks you very much. Wink
Re: Automatic validation. [message #633533 is a reply to message #633532] Mon, 18 October 2010 06:49 Go to previous messageGo to next message
Is this in the context of a GMF editor?
Dimitris
> Thanks you very much. ;)
Re: Automatic validation. [message #633538 is a reply to message #633533] Mon, 18 October 2010 07:07 Go to previous messageGo to next message
Hello Dimitrios!
Yes, It is.
I would like validate when a object or link is created, similar like now I can validate when the model is saved, but when a object or link is created.
Re: Automatic validation. [message #633544 is a reply to message #633538] Mon, 18 October 2010 07:15 Go to previous messageGo to next message
My - wild - guess is that you'll either have to modify the create
commands in the GMF editor or attach a listener to the resource so that
you get notified when it changes (e.g. something is added/removed) and
then call ValidateAction.runValidation(...) - but I must admit I haven't
done anything like this. Have you perhaps tried asking in the GMF newsgroup?
Dimitrid
Jose Miguel wrote:
> Hello Dimitrios!
> Yes, It is.
> created.
Re: Automatic validation. [message #633552 is a reply to message #633544] Mon, 18 October 2010 07:42 Go to previous messageGo to next message
Hi Dimitrios:
I have tried call ValidateAction.runValidation(...) in the method doExecuteWithResult of my XXXCreateComand, XXXReorientedComand etc. but I don't know How can I get the View Object.
I'll ask in the GMF newsgroup.
Thanks you very much for you help Dimitrios.
Wink
Re: Automatic validation. [message #633556 is a reply to message #633552] Mon, 18 October 2010 07:44 Go to previous messageGo to next message
You're welcome! Please keep us posted if you find a solution for this.
Dimitris
Jose Miguel wrote:
> Hi Dimitrios:
Re: Automatic validation. [message #633728 is a reply to message #633552] Tue, 19 October 2010 02:55 Go to previous message
GMF supports validating the model, so the question is how to trigger it.
A fairly generic solution is listening to changes to the command stack,
and then trigger the validation (that I think normally happens when you
save). Then you know that the command has completed, any model listeners
have reacted to model changes etc.
I think you can get hold of the command stack through the editing
domain. The EMF editor uses this technique to set the dirty flag of the
editor, so it should be fairly easy to find example code.
Hallvard
Previous Topic:switch-case null issue
Next Topic:Modify dynamically the icons of a node
Current Time: Fri Jul 25 22:46:50 EDT 2025
Powered by FUDForum. Page generated in 0.25890 seconds
