Home » Eclipse Projects » Eclipse Platform » Having a hard time installing plug-ins via a *.zip file with Eclipse 3.5.X
Having a hard time installing plug-ins via a *.zip file with Eclipse 3.5.X [message #633694] Mon, 18 October 2010 19:00 Go to next message
I have a distributable plug-in set that is organized as a .zip file with
the 'features' and 'plugins' directories that contain all the .jar files.
I can't seem to instruct Eclipse 3.5.0, which I use on Ubuntu, to
install my plug-in set.
Here is what I do. Please advise the correct solution.
1. Help -> Install New Software
2. Click on "Add"
3. Click on "Archive"
4. Select the *.zip file
5. The "Location:" text field fo the "Add Site" dialog shows
"jar:file:/home/me/myfile.zip!/"
When I do a "Test Connection" on the site, Eclipse shows the below text
in the pop-up dialog.
"No repository found at "jar:file:/home/me/myfile.zip!/.
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception "
Thanks for any help.
Re: Having a hard time installing plug-ins via a *.zip file with Eclipse 3.5.X [message #633905 is a reply to message #633694] Tue, 19 October 2010 14:39 Go to previous messageGo to next message
you can create a zipped p2 site (it will include a content.jar and
artifacts.jar as well) and install it the way you would like.
File>Export...>Deployable Plug-ins and Fragments will generate a p2
update site, and you can instruct PDE build to do that as well.
Otherwise you have to install it through dropins:
http://wiki.eclipse.org/Equinox_p2_Getting_Started#Dropins
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Having a hard time installing plug-ins via a *.zip file with Eclipse 3.5.X [message #634243 is a reply to message #633905] Wed, 20 October 2010 17:58 Go to previous messageGo to next message
> PW
Hey Paul,
The above step only spits out the "plugins" directory with the plugins
(the jar files) or into a .zip file. it does not create content.jar and
artifacts.jar or even a "features" directory in the output.
I did the above stop on my site project.
Please advise if I am missing some steps.
My goal is to be able to point Eclipse to the zip file to install my
plugins.
Re: Having a hard time installing plug-ins via a *.zip file with Eclipse 3.5.X [message #634244 is a reply to message #634243] Wed, 20 October 2010 18:02 Go to previous messageGo to next message
>> PW
> Hey Paul,
> plugins.
> Thanks
Ah...It's "Export Deployable Features" that will include the content.jar
and artifacts.jar files not "Deployable Plug-ins and Fragments"
Thanks!
Re: Having a hard time installing plug-ins via a *.zip file with Eclipse 3.5.X [message #634245 is a reply to message #634244] Wed, 20 October 2010 18:18 Go to previous messageGo to next message
>>> PW
>> Hey Paul,
>> plugins.
>> Thanks
> Thanks!
Arggg...Spoke too soon. Ok, created the *.zip with all stuff inside it,
artifacts.jar/content.jar/etc., but still can't install the plugins via
the *.zip file. Got the same original errors when I do a "Test
Connection" on the site, Eclipse shows the below text in the pop-up dialog.
Why does the location of the site have the "!/" at the end of path?
Re: Having a hard time installing plug-ins via a *.zip file with Eclipse 3.5.X [message #634434 is a reply to message #634245] Thu, 21 October 2010 12:52 Go to previous message
So myfile.xip contains:
content.jar
artifacts.jar
plugins/plugin1.jar
plugins/plugin2.jar
features/feature1.jar
Just like that. content.jar and artifacts.jar have to be at the root of
the p2 site.
That's supposed to be there. A URI to a file in a jar is
jar:file:/tmp/myfile.zip!/subdir/file.txt
PW
Paul Webster
Previous Topic:Cut and Paste Keys in Dialog
Next Topic:Should path variables be handled per workspace or per resource?
Current Time: Wed Jul 23 05:41:43 EDT 2025
Powered by FUDForum. Page generated in 0.06564 seconds
