XMLBeans dependency [message #633172] |
Fri, 15 October 2010 10:45  |
the context is the following.
I'm trying to install an existing WAR in virgo.
I got a remote virgo repository linked my my local virgo server. I put in the hosted folder the libraries required by my WAR. The WAR is in the local repository/usr folder (but this is not important).
In the manifest.mf file of the WAR there is the following dependencies, besides other declared dependecies:
Import-Bundle: com.springsource.org.apache.xmlbeans;version="[2.4.0,2.4.0] "
Now. If the com.springsource.org.apache.xmlbeans is installed in the local repository/usr the WAR deployment phase goes well. Otherwise, if the jar file is in the remote repository I got a strange error:
[2010-10-15 16:40:18.069] start-signalling-1 org.springframework.web.context.ContextLoader Context initialization failed java.lang.NoClassDefFoundError: org/apache/xmlbeans/XmlException
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2389)
at java.lang.Class.getDeclaredConstructors(Class.java:1836)
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.determineCandidateConstructors(AutowiredAnnotationBeanPostProcessor.java:225)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.determineConstructorsFromBeanPostProcessors(AbstractAutowireCapableBeanFactory.java:909)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:882)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:479)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:450)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:290)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:287)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:189)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:557)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:842)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:416)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:261)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:192)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:47)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4182)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4682)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:546)
at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:120)
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:90)
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:120)
at org.eclipse.virgo.kernel.install.artifact.internal.ArtifactStateMonitor.onStarted(ArtifactStateMonitor.java:205)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:273)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:270)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:223)
at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:140)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:637)
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: org.apache.xmlbeans.XmlException in KernelBundleClassLoader: [bundle=org.springframework.oxm_3.0.0.RELEASE]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:139)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 34 common frames omitted
Caused by: java.lang.ClassNotFoundException: org.apache.xmlbeans.XmlException
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:135)
... 35 common frames omitted
Analyzing the virgo admin application I noticed that, after the installation, some of the required bundle is resolved and installed but XMLBeans is not installed as a bundle.
I also noticed, in an another test case, that if I install the jar inside the repository/usr folder before the startup of the server, when the server is on the admin application reports me that the jar is installed as a JAR.
Can anyone explain me what's the problem? Is the order of the Import-Bundle so important?
-- Marco
FUDForum. Page generated in 0.05381 seconds
