Home » Eclipse Projects » EclipseLink » C++ wth Msqyl-- dyld: Library not loaded: libmysqlcppconn.5.dylib.No image found (C++ MySQL)
C++ wth Msqyl-- dyld: Library not loaded: libmysqlcppconn.5.dylib.No image found [message #633406] Sun, 17 October 2010 10:45 Go to next message
Hello, I am new to eclipse forum. I started using CDT for developing an application in C++. From the app i need to access MySQL Database.
I downloaded the MySQL Connector/C++ binary from the mysql site and placed the lib folder containing libmysqlcppconn.5.dylib and other files of unpacked binary
into /usr/local/mysql/lib and usr/local/mysql-5.1.51-osx10.6-x86_64/lib
From the project properties i set the libarary paths to the above mentioned directories. (For both g++ compiler/Linker and Mac g++ compiler and linker)
I was able to build the project without any issues but when i try to run it as C++ application i am getting the following error :
Referenced from: /workspace/SemPrjCode/Debug/SemPrjCode
Reason: image not found
To make sure, i also included this file specifically in the properties of the project.
Please help me in resolving this.
Thanks in advance.
Re: C++ wth Msqyl-- dyld: Library not loaded: libmysqlcppconn.5.dylib.No image found [message #633626 is a reply to message #633406] Mon, 18 October 2010 11:03 Go to previous message
Does not seem to be a question relating to EclipseLink. Please try another forum.
Previous Topic:Using a fetch group with find
Next Topic:How to use static weaving properly ?
Current Time: Wed Jul 23 10:16:07 EDT 2025
Powered by FUDForum. Page generated in 0.27300 seconds
