Home » Eclipse Projects » GEF » How to place Label above Ellipse?(I am trying to place a Label above an Ellipse, but each time refreshVisuals is called from the EditPart the figure shrinks!)
icon5.gif  How to place Label above Ellipse? [message #633546] Mon, 18 October 2010 07:19 Go to next message
Hello Experts Smile
I am trying to place a Label above an Ellipse shape, but each time refreshVisuals is called from the EditPart the figure shrinks. My paintFigure method looks like the following:
Rectangle r = this.getBounds().getCopy();
setConstraint(getLabelFigure(), new Rectangle(0, 0, (int)(r.width*0.9), (int)(r.height*0.1)));
getLabelFigure().invalidate();
// ellipse starts where label ends and fill the rest 90% in height and width
setConstraint(getEllipseFigure(), new Rectangle(0, (int)(r.height*0.1), (int)(r.width*0.9), (int)(r.height*0.9)));
getEllipseFigure().invalidate();
It seems that I can't use the constraints in this way, so how do I place the Label figure right above the Ellipse.
I am using normal draw2D label and a normal draw2D Ellipse shape.
Thanks in advantage.
Regards Mikkel
Re: How to place Label above Ellipse? [message #633548 is a reply to message #633546] Mon, 18 October 2010 07:27 Go to previous messageGo to next message
And also my refreshVisuals method looks like the following:
MyNodeFigure figure = (MyNodeFigure) getFigure();
// set constraints for ellipse
Point location = figure.getEllipseFigure().getLocation();
Dimension size = figure.getEllipseFigure().getSize();
GraphEditPart graph = (GraphEditPart) getParent();
Rectangle constraint = new Rectangle(location, size);
graph.setLayoutConstraint(this, figure, constraint);
Re: How to place Label above Ellipse? [message #633560 is a reply to message #633548] Mon, 18 October 2010 08:19 Go to previous message
I figured out the problem.
Now I am using BorderLayout instead and using constants CENTER and TOP.
Also the problem was not the layout manager itself but the way I updated the constraints in the EditPart.
Previous Topic:Testing and setting workbench button states
Next Topic:mouse-selecting nodes
Current Time: Fri Jul 25 11:05:37 EDT 2025
Powered by FUDForum. Page generated in 0.04619 seconds
