Home » Newcomers » Newcomers » Missing requirement(requires 'bundle org.eclipse.core.runtime')
Missing requirement [message #630925] Tue, 05 October 2010 11:17 Go to next message
I'm trying to Install the Google Plugin through the Help menus' "Install New Software".
In this sub menu item I am able to query:
http://dl.Google.com/Eclipse/plugin/3.5
and select the plugins. I hit "Next" and the Download and Install begin. After a few minutes I get an error stating that I am missing " bundle org.eclipse.core.runtime " ...
How do I acquire and install the component of Eclipse?
Thank you,
Robert
======= Example of the Error ======
Cannot complete the install because one or more required items could not be found.
Software being installed: Google App Engine Java SDK 1.3.7 1.3.7.v201008311405 (com.google.appengine.eclipse.sdkbundle.e35.feature.1.3.7.fe ature.group 1.3.7.v201008311405)
Missing requirement: Google Eclipse 3.5 Platform Plugin 1.3.3.v201006111302 (com.google.gdt.eclipse.platform.e35 1.3.3.v201006111302) requires 'bundle org.eclipse.core.runtime [3.5.0,3.6.0)' but it could not be found
Cannot satisfy dependency:
From: Google App Engine Java SDK 1.3.7 1.3.7.v201008311405 (com.google.appengine.eclipse.sdkbundle.e35.feature.1.3.7.fe ature.group 1.3.7.v201008311405)
To: com.google.gdt.eclipse.suite.e35.feature.feature.group 1.3.3
From: Google Plugin for Eclipse 3.5 1.3.3.v201006111302 (com.google.gdt.eclipse.suite.e35.feature.feature.group 1.3.3.v201006111302)
To: com.google.gdt.eclipse.platform.e35 [1.3.3.v201006111302]
Re: Missing requirement [message #633004 is a reply to message #630925] Thu, 14 October 2010 22:18 Go to previous messageGo to next message
This also happened to me. I was trying to install the plugin for the wrong version. If you are trying to install the plugin for the Helios version of eclipse you have to change the end of the address to 3.6 (not 3.5).
Hope this helps.
Leo
Re: Missing requirement [message #633545 is a reply to message #630925] Mon, 18 October 2010 07:18 Go to previous messageGo to next message
changing worked for me ! Laughing
Re: Missing requirement [message #756340 is a reply to message #633004] Sat, 12 November 2011 03:34 Go to previous messageGo to next message
i got a same problem.
but it's clear answer for me. thx alot!
Re: Missing requirement [message #1233521 is a reply to message #630925] Sun, 19 January 2014 17:24 Go to previous message
Could you guys suggest solution to similar problem below? I am trying to add GCC Arm cross compiler.
Software being installed: GNU ARM C/C++ Cross Compiler Support 1.7.1.201401111229 (ilg.gnuarmeclipse.managedbuild.cross.feature.group 1.7.1.201401111229)
Missing requirement: CDT Cross GNU ARM compiler support 1.7.1.201401111229 (ilg.gnuarmeclipse.managedbuild.cross 1.7.1.201401111229) requires 'bundle org.eclipse.core.runtime 3.9.0' but it could not be found
From: GNU ARM C/C++ Cross Compiler Support 1.7.1.201401111229 (ilg.gnuarmeclipse.managedbuild.cross.feature.group 1.7.1.201401111229)
To: ilg.gnuarmeclipse.managedbuild.cross [1.7.1.201401111229]
Previous Topic:Adding plugins
Next Topic:Eclipse Line by Line Debugging like C/C++
Current Time: Sun Oct 26 09:46:41 EDT 2025
Powered by FUDForum. Page generated in 0.08578 seconds
