Home » Eclipse Projects » Mylyn » bad_record_mac while setting up crucible repository
bad_record_mac while setting up crucible repository [message #633013] Fri, 15 October 2010 02:21 Go to next message
Hi Guys
I'm a newbie to this space and i'm facing trouble while trying to configure my Crucible repository in Eclipse 3.5 (Eclipse Galileo) in windows.
This is what i was trying.
1. Installed the eclipse atlassian connector provided at http://update.atlassian.com/atlassian-eclipse-plugin/e3.5
2. From the "Task Repositories" view, i clicked on "Add Task Repository" , selected "Crucible" and entered the following details
Server: https://mysvn.com/fisheye
Label: MyCrucibleRepository
Username: validusername
password: validpassword
Checked "Crucible server contains fisheye instance"
3. When i click on "Validate settings", I'm getting an error message saying
"https://mysvn.com/fisheye: Received fatal alert: bad_record_mac"
I have googled around for "bad_record_mac" without much help.
Is this an exisitng defect in myln integration with Eclipse 3.5 and is there a patch available? Is it worth trying out in eclipse 3.6 or 3.7?
Can someone help me some inputs? Thanks in anticipation.
A R Mahendran
Re: bad_record_mac while setting up crucible repository [message #633457 is a reply to message #633013] Mon, 18 October 2010 01:30 Go to previous messageGo to next message
Hi Guys
Any inputs on the above?
Re: bad_record_mac while setting up crucible repository [message #633941 is a reply to message #633013] Tue, 19 October 2010 20:07 Go to previous message
I would recommend filing a support request against Atlassian to get help
with the Crucible connector.
It sounds similar to this problem which is related to your SSL
configuration:
207175: error "Received fatal alert: bad_record_mac" when using https with
SSLv3
https://bugs.eclipse.org/bugs/show_bug.cgi?id=207175
Steffen
A R Mahendran wrote:
> Hi Guys
> windows. This is what i was trying.
> saying "https://mysvn.com/fisheye: Received fatal alert: bad_record_mac"
> there a patch available? Is it worth trying out in eclipse 3.6 or 3.7? Can
> A R Mahendran
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Previous Topic:[CDT] Mylyn automatically add all includes path in the context of the task
Next Topic:Can I use WikiText for the Trac Wiki rather than the tickets
Current Time: Sat Jul 26 18:44:22 EDT 2025
Powered by FUDForum. Page generated in 0.04255 seconds
