Provisioning project dependencies in Virgo [message #633283] |
Fri, 15 October 2010 20:40  |
Greetings,
I'm new to Virgo and am working to get a better understanding of the provisioning process. I've read the documentation thoroughly and have looked through the forums, but still not understanding some details.
Specifically, it seems that I should be able to provision Virgo using a Maven repository (making transitive dependencies much easier and more reliable). I see Pax Runner, but it seems oriented toward a bare metal provisioning of it's supported containers, not toward Virgo Server. I also looked extensively at the remote provisioning repositories, but these are other Virgo severs, not just simply a remote Maven repository. The only other option for provisioning the first container seems to be to manually copy dependencies in.
What am I missing here? [1] states that "when a bundle is deployed dm Server will automatically satisfy the bundle's dependencies by installing additional bundles from the repository", but I am assuming this is referring to *another* Virgo server, not the first Virgo server. Is there no way around manually provisioning the first repository? No way to connect to the Spring EBR and use that?
FWIW, I read somewhere about issues with optional dependencies and Maven repositories. For this reason, I was going to front-end the Maven repositories with Nexus, so I could filter out the unwanted dependencies. It might be a good practice that allows Maven repositories to be used reliably as provisioning repositories.
Thanks for any advice!
Brian
[1] http://forum.springsource.org/showthread.php?t=80326
Re: Aha! (Re: Provisioning project dependencies in Virgo) [message #633316 is a reply to message #633290] |
Sat, 16 October 2010 06:43  |
The way to make a production Virgo server provision its dependencies in a predictable way is not to change the contents of the configured repositories. If the content changes, then there is always the possibility that a "better" solution will be found to the provisioning/wiring problem than was found last time Virgo started.
Does that answer your question?
FUDForum. Page generated in 0.05343 seconds
