Home » Modeling » Epsilon » Installation Error
Installation Error [message #632770] Thu, 14 October 2010 04:50 Go to next message
Hello!
When I try to install Epsilon from the update site to my Eclipse (Helios equipped with several plugins) I get the following error during installation:
An error occurred while installing the items
session context was:(profile=epp.package.modeling, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]org.eclipse.epsilon.antlr 0.8.9.201004151115, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.ac tions.InstallBundleAction).
Error while loading manipulator.
However, I was able to install in a clean and fresh Eclipse installation. How do I get Epsilon installed in my Helios?
Greets,
Henning
[Updated on: Thu, 14 October 2010 04:50] by Moderator
Re: Installation Error [message #632805 is a reply to message #632770] Thu, 14 October 2010 05:35 Go to previous messageGo to next message
Hi Henning,
I've never encountered such an error before so I must admit I don't have
a clue :) It's probably worth posting a question about this to the
eclipse.p2 newsgroup to get some hints about what this error means and
we can then take it from there...
Dimitris
Henning wrote:
> Hello!
> installation:
> Greets,
> Henning
Re: Installation Error [message #633228 is a reply to message #632805] Fri, 15 October 2010 14:50 Go to previous messageGo to next message
Hi Dimitris,
I posted as you suggest a request in the eclipse.p2 forum. You can find it here.
So far so good...
Henning
Re: Installation Error [message #636902 is a reply to message #633228] Wed, 03 November 2010 05:48 Go to previous messageGo to next message
After I posted my stack trace of the error Henrik asked me to post again here, because it seems to be an configuration error or something like it.
Error indicates that there is a mismatch between where configuration
files are expected to be. Suggest asking the Epsilon folks if they have
any ideas what they could be doing to cause this.
Some possible causes could be creating a runnable that is not movable
from its location and then installing someplace else, or perhaps by
using manually added install instructions using some constant value
(instead of actual location).
- henrik
The stack trace is the following:
java.lang.IllegalStateException: The framework persistent data location (/Applications/eclipse/Eclipse.app/Contents/MacOS/configurat ion) is not the same as the framework configuration location (/Applications/eclipse/configuration).
at org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxM anipulatorImpl.checkConsistencyOfFwConfigLocAndFwPersistentD ataLoc(EquinoxManipulatorImpl.java:65)
at org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxM anipulatorImpl.loadWithoutFwPersistentData(EquinoxManipulato rImpl.java:348)
at org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxM anipulatorImpl.load(EquinoxManipulatorImpl.java:319)
at org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManip ulator.loadDelegate(LazyManipulator.java:54)
at org.eclipse.equinox.internal.p2.touchpoint.eclipse.LazyManip ulator.getConfigData(LazyManipulator.java:107)
at org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.I nstallBundleAction.installBundle(InstallBundleAction.java:80 )
at org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.I nstallBundleAction.execute(InstallBundleAction.java:32)
at org.eclipse.equinox.internal.p2.engine.ParameterizedProvisio ningAction.execute(ParameterizedProvisioningAction.java:35)
at org.eclipse.equinox.internal.p2.engine.Phase.mainPerform(Pha se.java:149)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.j ava:78)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(Phas eSet.java:44)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine .java:73)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine .java:44)
at org.eclipse.equinox.p2.operations.ProvisioningSession.perfor mProvisioningPlan(ProvisioningSession.java:174)
at org.eclipse.equinox.p2.operations.ProfileModificationJob.run Modal(ProfileModificationJob.java:79)
at org.eclipse.equinox.p2.operations.ProvisioningJob.run(Provis ioningJob.java:177)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
So where do we take it from here? What information can I provide to solve this?
Henning
Re: Installation Error [message #636937 is a reply to message #636902] Wed, 03 November 2010 08:32 Go to previous message
Hi Henning,
Since Epsilon installs fine in a clean Helios instance could it perhaps
be some other plugin you've already installed that's causing this?
Dimitris
> Quote:
>> have any ideas what they could be doing to cause this.
>> - henrik
> rImpl.java:348)
> se.java:149)
> eSet.java:44)
> ioningJob.java:177)
> solve this?
> Best regards,
> Henning
Previous Topic:Create view linking with editor
Next Topic:Using registered meta model
Current Time: Sat Jul 26 06:21:50 EDT 2025
Powered by FUDForum. Page generated in 0.05305 seconds
